BMW M2 Forum > Regional Forums > CANADA > TPMS for Canadian cars
      08-30-2019, 11:12 AM   #1
MetalMK
229
Drives: BMW
I saw this post: https://f30.bimmerpost.com/forums/sh....php?t=1575298
The thread stated that all newer BMW's come with TPMS standard, but just not showing pressure and temperature on the idrive screen. Is that true? Has anyone successfully coded tire pressure and temperature to be displayed on the idrive screen on a Canadian M2?
      08-30-2019, 08:02 PM   #2
Kothar
175
Drives: 20 m235i gran coupe
Canadian cars dont have tpms sensors...only a cheaper system that uses hub sensor for tire pressure. Not sure we can see individual pressures but the system will show low tires ...as I had a nail and it auto picked up the lower pressure on idrive.
      08-30-2019, 08:07 PM   #3
FreeDarko
Drives: F80
I heard BMW did go this route but not sure if it's applicable to the F series or only G series.
      08-30-2019, 08:11 PM   #4
Drop the hammer
Drives: '17 F87 M2 AW, Dct
My Canadian f87 does not have sensors in the wheels. It just uses the wheel hub speed sensor to determine if a tire is low. I have 3 sets of rims and interchange them, no sensors in any of them. You can code it on but you would have to install the sensors in each rim.
      08-31-2019, 07:36 AM   #5
FreeDarko
Drives: F80
Which year? I believe they installed TPMS for 2020 models.
OP I'll be removing my summers off the OEM wheels in a month after the car comes in but it's a 2019 model. Will let you know here either way.
      08-31-2019, 08:10 AM   #6
tux2005
234
Drives: 2017 M2
2016 and 2017 definitely do not have TPMS, I'm not sure if any of the 2018s did have it or not but I do know that it has been confirmed on here that Canadian cars did start getting TPMS. I think all M2Cs have TPMS but I don't know if the last of the original M2s also got it or not.
The easy way tell if your car has TPMS is to look at the valve stems, if they are rubber then you have FTM while metal stems indicate TPMS.
FreeDarko217.00
      08-31-2019, 03:38 PM   #7
MetalMK
229
Drives: BMW
My valve stems are definitely metal but they do not have TPMS inside. How?
      09-04-2019, 08:55 PM   #8
Ceridan
Ceridan's Avatar
26
Drives: 2018 M2 LCI
2008 BMW M6  [0.00]
2018 BMW M2  [0.00]
Soon as I got my '18 M2 I swapped the stock tires for Michelin PS4S, and it definitely didn't have TPMS sensors. I likely would have removed them if it did, just one more expensive thing to go wrong I don't need...
      09-05-2019, 10:21 AM   #9
twboy1999
Drives: 1994 honda accord
2019 got Tpms
2019 M2 HS 10000km and counting
      06-26-2020, 11:49 AM   #10
KevM2
KevM2's Avatar
BMW M2 Competition  [0.00]
  [0.00]
How can this be retrofitted on a Canadian car? Anyone done it?
      07-12-2020, 10:46 PM   #11
gwng8
Drives: bm
i'd be interested as well
      09-11-2020, 02:17 PM   #12
seaman
seaman's Avatar
34
Drives: BMW M3 2017
Hey guys, I have a 2020 M2C Canadian car, and there’s TPMS installed from factory. Now for winter wheels, do you know an aftermarket brand I can buy ? Thanks !
BMW M2C 2020 - Porsche 944 1985 - Chevrolet Camaro RS 1969 Daytona Yellow - Tesla model 3 Performance 2020
      09-15-2020, 11:53 AM   #13
M2Cmtl
Drives: 21 Q7 & 22 4XE
Any good tire shop should be able to sell you some sensors
