M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > OEM Size RE71 vs Wider PS4S
      08-29-2019, 04:38 PM   #1
PLF69
PLF69's Avatar
508
My 255/275 Cup 2's are at the end of there life and I have been brainstorming on my next tire setup for a few weeks.
I did run RE71 on my M235i and I am well aware that they are terrible street tires. I never ran PS4S but from friends and forums they seem to be capable of track duty if you take care of them. No doubt Cup 2's will be faster but you still have to be gentle or you can destroy them in no time..
So I'm wondering, PS4S on wider wheels (19inch) lets say 275/30F-295/30R or even 305/30R. Would they offer close to Cup 2's or RE71 grip in 255/35F-275*285/35 format ?
I don't really want to invest on another wheel set but If I can get good performance and smoother road manners at the same time maybe I could live with the compromise of concentrating on my driving, taking care of my tires and relying less on grippy tires.
Cup 2 price is just a little too high to live with the delicatess they require, yes they are livable on the street but don't be fooled they are stiff and no PS4S. I think they make much more sense on the GT3/4 and these kind of ''track ready'' cars.
Another option would be to slap 255/275 PS4S or my oem wheels and buy another cheap set of 437M's to put 255/285 RE71 on for more serious track days. Good idea or waste or $ and time ?
please share your thaughts
Toy: 2018 M2
SOLD: 2015 M235i Xdrive M Performance Edition 1/50
SOLD: 2008 135i 550whp
Daily: 2014 Q5 TDI
      08-29-2019, 05:34 PM   #2
Anthony1s
Drives: 2018 Mineral Grey M2
I don't know what your suspension situation is like, but it's much better to dial in more traction with coilovers, sway bars, etc than to upgrade tire width.
Click "Appreciate" on my post if I was helpful. Thanks!
      08-29-2019, 05:38 PM   #3
PLF69
PLF69's Avatar
508
I was not expecting this answer...
I am about to swap out my Dinan HAS for Ohlins.
Toy: 2018 M2
Daily: 2014 Q5 TDI
      08-29-2019, 08:22 PM   #4
ZM2
Drives: 2017 LBB M2
I’ve run similar times on track with 265/35/18 square RE-71R and 265/285/35/19 PS4S, but they drive completely differently.
The 71R setup was better under braking and to apex, but the staggered PS4S is better balanced on corner exit and allows nice throttle control & four wheel drift to maximize speed onto the straight making time back up.
PS4S gets greasy after 15-20min but you can’t kill them if you have proper camber. 71R will last if you keep hot PSI below 35 and don’t slide them.
255/285/35/19 71R on OEM wheels is the fastest tire combo you can put on an M2 bc you get the grip and staggered benefit. Only slicks or 265/35 305/30/19 71R on wider wheels are quicker.
5.M0NSTER1535.00
atc549.00
      08-29-2019, 09:46 PM   #5
gphung
72
Drives: 2018 M2 LBB - 6MT
Isn't 285 on a barely 200tw tire like the RE71R too wide for 10" wide wheels? Doesn't seem like they'll offer any benefit over 275s.
      08-29-2019, 10:15 PM   #6
ZM2
Drives: 2017 LBB M2
More lateral and corner exit grip with the 285, fits the 10” fine. Altho, if you’re dropped more than 20mm you’ll rub the height of the tire under heavy compression.
      08-30-2019, 01:30 AM   #7
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2017 BMW M2 6MT Drivers Pack
This. The balance is a big part of the reason a lot of people here buy the M2. Going square adversely influences that balance. Unless you like a very tail happy car.
OP, I'd suggest OEM size RE71s. This is also my plan next year when the factory MPSS are done.
2017 BMW M2 German Spec
6MT, Driver's Package
"Redline a day keeps the mechanics away"
      08-30-2019, 05:50 AM   #8
PLF69
PLF69's Avatar
508
The question remains..
street: PS4S even in larger size 275/305-30 should be confortable, maybe little more tramlining ? Anyone can confirm ?
Track: RE71 for sure but oem wheel size 255/285-35 still that big of a gap vs above ?
Keep in mind all track sessions I run are 20min max and I often have to drive 3 hours just to get to the track.
Toy: 2018 M2
Daily: 2014 Q5 TDI
      08-30-2019, 06:19 AM   #9
ZM2
Drives: 2017 LBB M2
Sounds like youíll have to try it and let us know.
Iím guessing your experience will be similar to what I mentioned, and the times will be similar, too. Regardless of sizes, the 71R will be better under braking and to midcorner bc of itís softer compound and it can consistently hold 1.0-1.1g. The 4S is 0.9-0.95g.
But the much larger contact patch of the wider 4S setup will be as good or better coming off the corners, which is the most important point on the track to make up time.
As I mentioned, the setups drive completely differently. Youíll have to be very patient in the corners with the 4S and will get frustrated as the guys around you on stickier rubber will pull away. But if you drive to the tireís capabilities youíll figure out how to best exploit it.
I will say big fat rubber like youíre thinking is no fun on the street. It makes the car feel heavy and less responsive.
You probably know a lot of this, so youíll have to run the experiment and let us know the outcome. The best thing about tires is you can resell them or burn them up and try others.
PLF69508.00
      08-30-2019, 06:40 AM   #10
PLF69
PLF69's Avatar
508
I've run similar times on track with 265/35/18 square RE-71R and 265/285/35/19 PS4S, but they drive completely differently.
PS4S gets greasy after 15-20min but you can't kill them if you have proper camber. 71R will last if you keep hot PSI below 35 and don't slide them.
Did you run 265/35F 285/35R PS4S on OEM wheels ?
much worse turn in that 255 ? Any rubbing at the front ?
Toy: 2018 M2
Daily: 2014 Q5 TDI
      08-30-2019, 06:47 AM   #11
ZM2
Drives: 2017 LBB M2
I did. Went back to 255. Turn in with the 265 on the 9” rim was lazy, plus the 265 4S is meant to be a rear tire and has less rain grooves.
The 265 does have more ultimate grip on track, but the 255 is much more responsive and hydroplanes less.
And, the 265 does rub under compression until you wear some of the tire or fender liner down.
      08-30-2019, 06:55 AM   #12
PLF69
PLF69's Avatar
508
I did. Went back to 255. Turn in with the 265 on the 9" rim was lazy, plus the 265 4S is meant to be a rear tire and has less rain grooves.
If you combine the 255 fronts with 285 rears it makes for a 3.5% difference. OEM is around 1.9%
Any chance this would affect the DSC in MSM mode ?
Toy: 2018 M2
Daily: 2014 Q5 TDI
      08-30-2019, 07:06 AM   #13
ZM2
Drives: 2017 LBB M2
Nope, works fine. The most important rule is to keep rear tire height larger than the front.
The only time Iíve had weird DSC intervention was after a day of running 265/35 295/30/19 R7ís at the track and then driving home on my 265/285/35/19 4Sís. A few times going home the DSC would cut power around corners even when going slow. After driving for a day the car adapted and everything was fine.
This year I ran 265/35 305/30/19 71Rís and then switched to 255/285/35/19 4S the next day. No DSC interventions at all.
That 295/30 R7 is slightly shorter than the 265/35 R7, so thatís what made the car unhappy for a bit after switching. Was fine on track with DSC off, tho.
PLF69508.00
      08-30-2019, 12:16 PM   #14
Kuervers
Drives: 19 M2C HS,6sp 16 X5 35i
Is it easy to overdrive the 265 fronts with all the grip of the 305 re-71 in the rear on track?
Was planning on 265/285 re-71 on 9.5/10.5 wheels but not all that experienced so looking for feedback (FBO m2c).
255/275 best for stock wheels (street tires)to retain playfulness at low speeds, thinkong about trying some Firehawks for next set of street tires
      08-30-2019, 01:15 PM   #15
ZM2
Drives: 2017 LBB M2
It definitely shifts the balance to a setup more prone to understeer, and you have to make sure not to overdrive the fronts. But, there’s a ton a grip in the rear and you can use more throttle to help rotate the car. Both are good skills to have.
I’ve only done one open track day on this setup and will do another soon to decide if I’ll stick with these sizes or drop to 285.
I’m guessing the balance with the 255/265 and the 285 will feel better, but the reality is the more tire you have the more available grip there is and if you drive the 265 fronts and 305 rears to their limits, they will be quicker than 255/265 and 285.
Worth it to sacrifice some handling balance? Not sure, yet.
      08-30-2019, 01:24 PM   #16
Kuervers
It definitely shifts the balance to a setup more prone to understeer, and you have to make sure not to overdrive the fronts. But, there's a ton a grip in the rear and you can use more throttle to help rotate the car. Both are good skills to have.
I've only done one open track day on this setup and will do another soon to decide if I'll stick with these sizes or drop to 285.
I'm guessing the balance with the 255/265 and the 285 will feel better, but the reality is the more tire you have the more available grip there is and if you drive the 265 fronts and 305 rears to their limits, they will be quicker than 255/265 and 285. Worth it to sacrifice some handling balance? Not sure, yet.
interesting
thought thought of doing 275 295/305 30 ad08r
Ya think I'd rather have oversteer but also only handful not track days in car so
      08-30-2019, 02:43 PM   #17
ZM2
Drives: 2017 LBB M2
275/295 will be a nice balanced setup.
275/305 will be quicker if you’re comfortable at the limit using the throttle to help rotate the car in the corner.
      08-30-2019, 08:35 PM   #18
gphung
72
Originally Posted by Kuervers View Post
interesting
AD08R has an extremely blocky shoulder design for a 200tw tire. If we're still talking about the stock 9"/10" wide wheels front and back, 275 and 295/305 is way oversized. I feel like that's pushing it even for a 9.5"/10.5" setup, too (especially for the fronts).
      08-31-2019, 10:35 AM   #19
ZM2
Drives: 2017 LBB M2
It’s not as impt to have the rear tire on a 19x11, 10.5 is good enough. Plus, the clearances would be super tight with a 19x11 and you would need the wheel offset to be millimeter perfect to run a 305 in the rear.
But, a front 275/30 will drive better on a 19x10. Likely would need at least ET22-24 depending on setup, which means it’ll be sticking out from the fender some and will throw more stuff up on the side of the car.
      08-31-2019, 01:58 PM   #20
Kuervers
interesting
interesting
yes this would be on 9.5/10.5 wheel.
so your suggestion would be a 265/295 30r19
for ad08r for proper fit. getting camber plates also
      08-31-2019, 02:35 PM   #21
gphung
72
interesting
interesting
Yup that's as far as I'd go with 9.5s and 10.5s. My concern wasn't so much with fitment under the arches per se, but more about usability of the tire widths for the given wheel widths.
      09-01-2019, 08:56 AM   #22
dcmac
dcmac's Avatar
405
Drives: '18 LCI M2
Iím running 265/35/18 71Rís square this season and I donít think the car is tail happy. Sure, it rotates easier and I have to be careful with throttle on exit, but the turn in and mid corner grip is so worth it. I suspect staggered is a little quicker but for pure enjoyment and dancing with the car Iíve really enjoyed going square this year.
Also to the OP - why do you think the 71R is a horrible street tire? I love it on the street, gonna use em on my OEMís next summer.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
