08-19-2019, 04:47 PM | #1 |
Rep 112
Stainless Steel Brake Lines for M2 Comp
Planning to upgrade the brake lines for my M2C. Found Goodridge, Turner Motorsport, Stoptech and ECS all have that. Prices from $106-165.... Are they pretty much the same thing? Anyone has any experience with these brands? Thanks
08-20-2019, 05:16 PM | #3 |
Rep 112
08-20-2019, 07:56 PM | #4 |
Car Guy
38
Rep 115
I've used Goodridge in the past and had great success with them. I am going with these on my M2 as well.
2018 BMW M2 Long Beach Blue
2022 Lexus IS 350 F Sport |
08-21-2019, 11:49 AM | #5 |
Rep 112
09-05-2019, 04:27 PM | #8 |
Almost completely sane
694
Rep 1,080
Supposedly Spiegler uses thicker stainlesss steel wire gauge for the sheath.
Also, their swiveling banjo bolt can supposedly eliminate any twisting in the line that might cause extra stress. Haven't installed any teflon + SS lines in any of my cars since 20+ years ago, so I can't speak from actual current experience. But I'm thinking about installing lines because of a low pedal on my most recent track day at Laguna. Update: Low pedal issue solved by switching from Ate Typ 200 to Castrol SRF. Did an event at Laguna Seca and pedal height and firmness are still fine.
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace) Last edited by Bosozoku; 07-27-2020 at 04:50 PM.. |
09-06-2019, 06:56 AM | #9 |
Car Guy
38
Rep 115
This was many years ago and I bought them in the US at the time. Apparently they have a Canadian Distributor. https://marcor.ca/product-lines/goodridge/
09-06-2019, 11:36 AM | #10 | |
Rep 112
09-06-2019, 12:47 PM | #11 | |
Rep 14
Bosozoku693.50 |
09-06-2019, 01:24 PM | #12 |
Rep 7
I read somewhere that in order to do a proper bleed for the brake system, one needs to connect a diagnostic computer to run the ABS DSC pump in order to ensure that there will be absolutely no air bubbles in the system. Theoretically all the shops do this on a total system bleed. Does anyone know if this is true? Has anyone done steel lines then subsequently bled the system and found no air in the system?
I just did a bleed myself from factory fluid to Castrol SRT, so it was not a full system bleed. That being said, both of my front calipers had air in the brake lines right as I started bleeding them... has anyone seen this? |
09-10-2019, 01:57 PM | #13 |
1019
Rep 839
Spiegler lines are the highest quality available, and they are what we use in our complete AP Racing Competition Brake Kits. Spiegler's owner is a German engineer who owns and operates the business in Ohio. The fittings are from Switzerland, are far nicer than the competition, they have swivel fittings which takes tension out of the lines, and they have a tighter weave with a sheath over them. They are slightly more expensive than other options, but still cheaper than a set of good race pads. Spiegler also has incredibly stringent testing procedures for their lines, and they are DOT compliant. There's therefore no reason to skimp on lines. They are a critical brake component, and there are none nicer than the Spiegler ones!
Front lines for the M2 and M2 Comp= https://www.essexparts.com/spiegler-...mw-m2-m3m4-f80 Rear lines for the M2 and M2 Comp= https://www.essexparts.com/spiegler-...m4-f80-f82-f87 Loads of details on the Spiegler lines here: https://www.essexparts.com/brake-lines |
09-17-2019, 02:42 AM | #16 |
Rep 4,496
braided SS hoses will not make that much difference on a modern performance car with decent Kevlar flexi hoses, like BMW fit oem to F8x cars.
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT |
4
09-17-2019, 12:41 PM | #17 |
Rep 660
09-24-2019, 12:44 PM | #18 |
Rep 433
I noticed on the IND website they have two different listings for the Goodridge SS lines for the the M2 and M2C
M2 https://ind-distribution.com/collect...el-brake-lines M2C / M3 / M4 https://ind-distribution.com/collect...el-brake-lines Not sure if there is any difference between the two options |
10-21-2019, 02:07 AM | #19 | |
Rep 176
