08-03-2019, 11:20 PM | #1 |
Rep 328
Bought a new OG M2, what should I take care of
Hi all, I am new to this forum.
I just purchased a "new" 2018 M2 with about 130km (80mi) on the car. The car is in pretty good condition aside from being built in February 2018 and have sat for over 16 months. My sales tell me they move cars around quite often so it would not be a problem. But this is my first time buying a car that's not really driven when new, so what should I check upon delivery? Also should I ask them to do the break in service now and again at 2000km? Any information appreciated. |
08-03-2019, 11:37 PM | #2 |
Rep 507
I would get an oil change done. Oil changes are typical recommended yearly at minimum. I imagine it went threw a winter and sat outside so maybe check the tires for any cracks. Other than that enjoy.
Present: 21 M2C 6MT/Ford something
Past: M2 Mineral Grey 6MT Past: BMW e30 m52 turbo 628whp/558wtq |
MetalMK228.50 JackyStuntin154.50 |
08-04-2019, 03:42 AM | #3 |
Rep 1,823
Don’t baby it. Drive it and drive it hard. Try not to redline more than a few times in the first 500 miles. Then do your break in oil change and enjoy.
One trick to help the piston seals seat properly is to apply throttle hard till about 6500 RPM then step off the throttle and let the rpm come down on their own. The change in pressure this generates helps seat the piston ring seals. Last edited by 5.M0NSTER; 08-04-2019 at 03:51 AM.. |
08-04-2019, 09:43 AM | #4 | |
Rep 6,936
Drives: 2018 M2 AW DCT
Have fun with it. |
MDuckie93.00 |
08-04-2019, 11:39 AM | #5 | |
Rep 328
08-04-2019, 12:01 PM | #6 |
Rep 1,823
It runs great. 0 oil consumption even with 4-5 track days per year and driving it in winter too. Same with my last car. Drive it like a hooligan. That’s what performance cars are built for.
Just stay up on the maintenance and it will reward you with a big smile daily. Last edited by 5.M0NSTER; 08-04-2019 at 12:25 PM.. |
MetalMK228.50 |
08-04-2019, 04:30 PM | #7 |
Rep 408
I didn't break in past 5500, but did rev up and let the revs drop down automatically throughout whatever gears possible.. My car doesn't burn a drop of oil either.
08-04-2019, 04:35 PM | #8 |
Rep 339
The car's not going to use a drop of oil if you pound it early and often or run it like a grandma...as long as it's warmed up.
08-04-2019, 07:01 PM | #9 |
Rep 328
Do you mind explaining what "let the revs drop down automatically throughout whatever gears possible" mean? For example, I'm going 70km/h in 4th at 3500rpm, I just let go of the throttle and let the car coast?
08-05-2019, 08:49 AM | #10 | |
4693
Rep 2,541
Yes that is what they are talking about - get to desired rpm and then lift & let the engine slow itself down, do not apply any braking during that time. What is being described is a "hard" vs "soft" break-in for the motor. Lot of opinions about it on both sides. I have done both depending on the car. For whatever it's worth (not much) I have just driven fairly moderately during break-in on any of my new M cars - staying within BMW's recommendations & haven't had any issues with oil burning. Also keep in mind the engine isn't the only thing being broken in.
MetalMK228.50 |
08-05-2019, 11:34 AM | #11 |
Rep 3,842
My break-in procedure is to drive through mountain passes. Up through the gears then down through the gears. That way you get acceleration and deceleration using the engine. Personally I wouldn't be doing any redlining.
08-05-2019, 01:41 PM | #13 | |
Rep 132
MetalMK228.50 |
08-07-2019, 08:38 AM | #15 | |
Rep 1,823
Redline-a-day keeps the mechanics away.
2017 BMW M2 German Spec
Ian ///M491.00 |
08-07-2019, 08:52 AM | #16 |
Rep 6,936
08-09-2019, 06:08 AM | #19 |
Rep 656
maybe its just car to car, i just wanted to post that to back up the guy above that recommends a slightly grittier break in that he probably isnt completely wrong.
I just roll thru my dealer for oil pit stops. about every 3-4k or so i get a oil at minimum warning. (weekend car- so the time gaps when they pop up arent annoying) they just top it off and let me roll out |
5.M0NSTER3353.50 |
08-09-2019, 11:55 AM | #20 | |
Rep 1,823
Ian ///M491.00 |
08-09-2019, 01:09 PM | #21 | |
Rep 656
5.M0NSTER3353.50 |
08-11-2019, 05:23 PM | #22 | |
Rep 328
