BIMMERPOST Universal Forums > Professional Motorsport Racing Discussion (IMSA, DTM, Formula 1, Grand-AM, Le Mans, IRL, WRC, etc..) > What Formula 1 Needs
      06-27-2019, 09:48 PM   #1
yco
i'm just saying
yco's Avatar
5735
Drives: E71 X6M '10 (sold)
Question What Formula 1 Needs
ideas will be sent to FIA, hoping they consider..
thought it can be interesting to gather ideas..
even if im super happy with Merc's dominance in recent years, there can be things to boost racing without slowing the cars down.. some may sound extreme or easy to do..
1. longer straights that forces teams to use lower downforce setup.. cause each meter after reaching top speed makes the leading car vulnerable.. and heavy braking zone is a big overtake advantage..
2. adding 1-2 less than 60-70kmh corners can avoid aero grip and using mechanical grip only.. not even mentioning the braking zone before the corner to widen the chance of an overtake.. closing the gap in the corner will allow the follower car to exit the corner closer..
3. DRS duration can vary on each team.. there should be more advantage on slower cars.. equal on each car is not fair.. it can be based on the recent constructor points..
4. wider tracks.. wider tracks and turn combinations will alter different racing lines on the corners to avoid aero grip lose for following the car in front.. and the next idea is necessary to complete this one..
5. cleaning the track before the GP weekend.. nothing high tech about this.. 3-5 or more vehicle that each municipality uses for cleaning the streets can be useful to clean the track also.. overtaking almost always requires going off the racing line and if there is dust things are getting even harder.. drivers shouldnt hesitate to use different lines because sticking dirt to their tires..
6. mild banking on mid speed corners.. 1-2 on each track.. banking will allow to keep the mechanical grip in the game a bit more and take off some the disadvantage of following a car..
7. not changing the regulations of cars and engines regularly.. cause each big regulation change is leading one team shine more than others.. keep the regs longer or changing them smaller will give time to other teams and gaps will be much smaller..
8. im not sure it can work but like we re using in prokart or other series that adding weight to faster car to create a handicap based on the previous race.. even if probably big teams will produce cars according the max handicap weight, it still can be useful..
9. longer braking distances.. like 25-30% longer braking.. cause most of the overtakes finish in the following corner and recently F1 cars almost brake at the entry of the corner.. braking distance is too short.. this can be achieved by thinner discs or smaller disc diameter easily.. i guess all the teams are customers of Brembo..
10. like DRS based on the constructor points more electric juice on slower cars to compensate the power difference..
these are the initial ideas i have for some time.. what do you guys suggest or think to boost the competition among drivers?
"Race car driving is like sex. All guys think they're good at it." Jay Leno
      06-28-2019, 06:44 AM   #2
madmax240
Drives:
better tracks (more like Spa, Silverstone)
V12s and no traction control
cars are too big for tracks. hard to make tracks bigger, easier to make cars smaller.
Bartledoo2691.50
gatorfast4994.50
Robin_NL8717.00
      06-28-2019, 12:06 PM   #3
Pauldunlop13
Drives: M4 Convertible
I like number 5. The Toronto Indy cleans the track during races, every time there is a caution lap. Jet blower mounted to the back of a truck comes out and blows the marbles off the track. Leading to more passing during a race. I always wondered why F1 doesn’t do this. It would work on the CF bits that they spend time picking up by hand and shorten the amount of caution laps I think.
2019 YMB ZCP convertible with Dinan Exhaust
2011 Ducati Diavel Carbon Edition
2015 BSM M4 Convertible - 2018-2019
2016 228Xi - 2017-2018
2003 Acura RSX Type S 2003-2017
clee1982797.50
      06-28-2019, 12:44 PM   #4
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
I would like to add two pit stop related ones:
1. Refueling - Technology can be advanced to make it safer I would say. Less fuel/smaller fuel tanks might also result in faster lap times. Also adds a bit of strategy, although I assume everyone will find the optimum theoretical strategy pretty quickly. Still.
2. Minimum pit stop times, the minimum limit would be a second or two more than adding a splash of fuel, but less than a full refuel. This way during a Safety car (or even not during a SC) there's an additional strategy component.
      06-28-2019, 02:14 PM   #5
mindspin311
Drives: BMW
Just reduce aero by 50%, leave the rest the same.
2012 Space Grey 128i
      06-28-2019, 02:49 PM   #6
Run Silent
Run Deep
Run Silent's Avatar
Drives: Back and Forth To Work
I think the comment about the longer straights needed and the fact the tracks are too narrow are probably the most viable when it comes to where the biggest issues are related to watch-ability of current F1.
Passing is extremely difficult due to the size of the cars vs. the width of the tracks. As mentioned by a poster above, widening tracks may be too difficult, so making the cars smaller is another alternative option.
In addition, the longer straights will automatically dictate longer braking zones at the end, there by negating your point about extending braking zones via car manipulations. Longer straights and higher speeds will allow longer braking at the end, to wit more opportunity for passing.
These are some good points you mention - unlikely to come to fruition though in reality. Which is sad.
Don't sweat petty things....or pet sweaty things.
      06-29-2019, 08:03 AM   #7
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
I agree making the cars smaller seems like the simplest solution compared to widening tracks.
      06-29-2019, 10:47 AM   #8
wdb
dances with roads
wdb's Avatar
4722
Drives: '07 E86, '02 996, '95 Seven
I know it will never happen but, immensely simplify the rules. Set a few minimums and maximums, then let chassis builders and engine builders have at it. It won't do much to trim costs but it might make for some pretty innovative solutions. Look at the Delta Wing car for example; half the horsepower, no wild airplane parts hanging off front or rear, still fast and competitive. I'm still enamored of that car and what it could represent if the rules were just simplified to allow minds to truly be creative.
Run Silent15127.00
MKSixer34184.50
      06-30-2019, 02:39 PM   #9
MKSixer
MKSixer's Avatar
34185
Drives: 2015 BMW i8, E63 M6, 328d
2016 M4 GTS (Allotted)  [0.00]
2013 BMW 328d  [0.00]
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
All too complicated. Here is how you fix F1:
15% of the aero from a mandated 2 element wing.
75% of the aero from the floor. Diffusers of any type allowed.
10% of the aero from the rear wing.
Cars can follow. Cars can pass. Cars won't experience aero wash out when their path is cut across by another car.
Shall I send my bill to the FIA and Jean Todt? Who has their address?
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion.
      06-30-2019, 03:58 PM   #10
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
How about reverse placing? So after qualifying whoever is in P1 actually starts P20 and has to work their way up
      06-30-2019, 04:11 PM   #11
MKSixer
MKSixer's Avatar
34185
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
Not a fan of this. Too gimmicky.
If the floor is responsible for most of the aero then the mechanical grip will move back to the fore. This single change will fix the following problem as well as reduce the cost of development.
      06-30-2019, 05:40 PM   #12
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
Ha I was suggesting this in jest although it may make for an interesting race.
MKSixer34184.50
      06-30-2019, 09:53 PM   #13
yco
i'm just saying
yco's Avatar
5735
well actually the ratios that creates the downforce is like this almost.. most of the downforce is being created by the floor.. and one way or another bursting air out to disrupt the follower car is inevitable still with this setup.. maybe Murray's banned fan car can be the solution.. each car sucks itself to the ground..
wdb4721.50
MKSixer34184.50
Poiseuille5392.50
      07-01-2019, 10:28 AM   #14
dtla1
dtla1's Avatar
828
I've got a new suggestion for this thread.
All future races in Austria, clone Max, Charles, Albon, Lando, Sainz, Lewis, Kimi, and Valterri; put them all in identical cars and let the race.
      07-01-2019, 11:34 AM   #15
RS DAVE
101
Drives: E91 335D M SPORT
Take the cars back to the 80's 90's spec when the drivers had to drive the fucking car, not pushing buttons like a play station game.
NickyC17473.50
MKSixer34184.50
Poiseuille5392.50
      07-01-2019, 02:31 PM   #16
Timujin
Timujin's Avatar
352
Drives: GMC Sierra
2010 BMW M3  [0.00]
DRS should be unlimited during race.
We grow food to feed the animals so we can eat the animals
      07-01-2019, 03:00 PM   #17
Bartledoo
Driver
Bartledoo's Avatar
2692
Drives: 2011 E90 M3 6MT
They may as well not have it at all then...
E90M 6MT Slicktop Single Humper in need of a diet
      07-01-2019, 03:08 PM   #18
MKSixer
MKSixer's Avatar
34185
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
Thanks for the information. Under the current F1 regulations the floor creates only about 60% of the downforce. Increasing the amount of downforce created by the floor by 25% would be a massive improvement.
On the subject of Gordon Murray's Fan Car...it's funny, we were actually discussing this over the weekend with a friend of mine who is getting a T50 (name?) and has a follow-up meeting with Mr. Murray this month.
I also thought the car was banned but it was actually voluntarily withdrawn by Mr. Ecclestone. The teams all got together and told him that if he ran the car in the next race, they would all withdraw and they'd be left alone to drive in in circles on an empty track. Good ole' F1 history from the horses mouth, once removed.
Great post!!
Cheers-mk
Appreciate 4
dtla1827.50
Timujin351.50
wdb4721.50
Poiseuille5392.50
      07-01-2019, 03:27 PM   #19
yco
i'm just saying
yco's Avatar
5735
Great post!!
Cheers-mk
that sounds pretty cool.. wondering if he can pick up some information about the engine.. im guessing engine will need to be replaced every 30-40k km but it may surprise also.. and for the name i believe it include some F1 in the end or something.. he ll connect the car with McLaren F1 somehow..
MKSixer34184.50
      07-01-2019, 04:35 PM   #20
E90SLAM
Supreme Allied Commander
E90SLAM's Avatar
Hong Kong
1963
Drives: A BBS WHORE
"Default, Menu, P, 2"
"strat, mode 4"
Timujin351.50
MKSixer34184.50
      07-01-2019, 04:51 PM   #21
Timujin
Timujin's Avatar
352
Drives: GMC Sierra
2010 BMW M3  [0.00]
"strat, mode 4"
Web 😤vs. Vet 😗
MKSixer34184.50
      07-01-2019, 05:50 PM   #22
NickyC
NickyC's Avatar
17474
Drives: M4 CS. Former G82, x2 F82, F80
V12s, kill the aero at least 50%, bring back manual gearboxes, full pit stops again with fueling, on and on. Drop the dumbass tire regs too, you can run whatever kind of tire you freaking want at anytime.
What I'd really like to see are stock V12s given to every team from a sole supplier, and then the chasis/gearboxes are left up to the teams. If they insist on having different engines by manufacturer, put a cap on HP levels so all engines for all teams must be within 1-2% max hp of each other. So for instance we'd be detuning the Mercs which should have happened years and countless boring races ago.
None of this will ever happen in F1 of course.
Bartledoo2691.50
