03-10-2019, 12:06 PM | #45 |
Rep 5,369
I'm in the same boat. I continue to eye ball 2018 M2s though I still love my M235. I'm really not interested in the M2C because like you, I like wrenching on my cars and the S55 is at a different level of complexity and potential expense. Don't get me wrong, the S55 is a gem but it's running costs can be frightening.
M2driverWV50.00 termigni1081.00 |
03-10-2019, 12:56 PM | #46 | |
Rep 3,842
03-10-2019, 01:37 PM | #47 | |
Rep 13,100
///M is art ↔ Artemis
03-10-2019, 01:56 PM | #48 |
Rep 571
Which of those issues are as much age-related as mileage related? Asked differently, for those of us who may not be driving as much as expected which of those items will need to be replaced due to age even if the actual mileage on the car is much lower? TIA.
03-11-2019, 09:04 AM | #49 | |
Rep 3,695
03-11-2019, 09:14 AM | #50 |
4069
Rep 1,970
So I just spoke to Brent about this and he confirmed this as well.
03-11-2019, 09:42 AM | #51 |
Rep 3,695
03-11-2019, 09:54 AM | #52 |
4069
Rep 1,970
03-11-2019, 11:44 AM | #53 |
Rep 459
Drives: 2023 M3 Competition xDrive
Yeah I just spoke to one of the techs at my local dealership a few days ago when I picked my car up. He said he spends less time on N55 variants than any other engine and the time he does spend on them is usually for minor repairs.
termigni1081.00 |
03-11-2019, 01:36 PM | #54 | |
Rep 929
The 0W oil is great for the cold however, if you're only driving short trips, the amount of water condensation increases because the engine doesn't get a chance to burn off the water. So now you got water mixed in the oil which can freeze and depending on how much water, that can be a huge problem. Not to mention, the amount of fuel mixing with the oil will be higher in winter too so that's another reason to change the oil more frequently in extreme cold. |
03-11-2019, 01:56 PM | #55 | |
4069
Rep 1,970
If your leasing to return may not be worth it, holding N55 M2 long term change oil in spring and fall, garage it and when driving it take the long way home. |
AlpsRider2865.00 |
09-18-2019, 06:30 PM | #56 |
Rep 17
M2 lci from 2018. Stage 2 with 450hpmand 655nm. Wagner decat and Eventuri intake. 20.000km.
Hard drive and a lot revving at meetings. In the beginning some misfires but after changing the sparkling plugs, never any problems again. |
termigni1081.00 |
09-18-2019, 08:16 PM | #57 |
Rep 533
09-18-2019, 11:17 PM | #59 |
Rep 7,429
I believe the issue is caused by changing oil filter housings and not having the oil system primed before starting causing there to be a period of time where the engine is "running dry" of oil. This causes the crank to become seized to the bearings and it can even snap according to posts on a different forum.
09-19-2019, 06:25 PM | #60 | |
Rep 660
09-19-2019, 07:00 PM | #61 | |
Rep 328
09-19-2019, 10:04 PM | #62 | |
Rep 7,429
There is a whole post about how the priming is done and the method was derived from an official BMW SIB document for the OFHG job, but a quick summary is to unplug the injectors and let the motor crank for 10 seconds 3 times with 20 second breaks in between for the starter to cool.
09-19-2019, 10:48 PM | #63 | ||
Rep 6,635
Perhaps an independent shop would be different. |
09-20-2019, 12:46 AM | #64 | ||
Rep 7,297
09-20-2019, 01:07 AM | #65 | |
Rep 7,429
Do some research then and you'll see a large number of n55's having locked up engines in particular right after the OFHG replacement. So far it doesn't seem like a coincidence. Also it's not an issue of not filling up the oil filter housing there's also oil coolers and oil cooler lines to consider. And an oil change doesn't empty the oil coolers and all the lines, it only empties the sump which is quickly refilled when you put new oil in, that's the difference. They believe it could have been caused by a few issues: 1) the OFHG change introduces bubbles into the loop that cannot be purged and these bubbles can interrupt oil flow to the crank. 2) when the gasket fails and is replaced coolant leaks over into the oil side and contaminates the oil tract and ends up degrading the oil. When the car starts it eventually makes it's way to the crank causing it to sieze. I'm not sure why this is the issue but there have been alot of reports of failure occuring right after these types of services to warranty suspicion. Plus BMW even released an SIB stating to prime the motor after major services to the oil system such as oil cooler swaps, OFHG replacements etc.
09-20-2019, 06:18 AM | #66 | |
Rep 533
