M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Bimmercode topics
      03-20-2017, 06:39 AM   #353
DivideBYZero
DivideBYZero's Avatar
484
Drives: F87 M2<E92 M3<E46 M3
Has anyone coded out the hazard lights on hard braking? These brakes are pretty good and i'm constantly setting the f*ckign things off. It's a little annoying. I'd rather just have brake flashing, not hazards.
Note: This probably only relates to UK/EMEA cars, not US models.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT
2016 F22 M235i Coupe, MW, ZF8
      03-20-2017, 04:10 PM   #354
ried
ried's Avatar
Drives: F31, F80
Originally Posted by ric124 View Post
Could you add apple CarPlay as well?
Only if you want to get this app banned. That's one surefire way to get BMW and subsequently Apple's attention: Start cutting into their bottom line.
      03-20-2017, 05:43 PM   #355
mjsaville
101
Drives: M2 LLB - Arrived 4th Mar 2017
Originally Posted by Dabozo View Post
In expert mode, (I have not done myself however...)-
FEM Body 3040
- CLM_HORN_AT_SECURING
I've tried this tonight only to discover the option is already active, (which makes no sense) as no sound is emitted from the car when its locked. I've raised a support request with Bimmercode. Lets see what they come back with.
MJ
      03-20-2017, 06:36 PM   #356
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
I would pay for it but every time I call they say they not sure on an exact date as yet.
      03-20-2017, 07:33 PM   #357
Em-too
Em-too's Avatar
Drives: 2016 M2
Originally Posted by mjsaville View Post
Hi All,
Just started using the app today. Seems good so far, can someone advise on how to code: horn acknowledgement on locking ?
thanks in advance....
MJ
Are you asking about this or are you actually wanting the cars horn to honk at locking? I could be wrong but I don't think you have an option for the horn to sound when locking rather only the acoustic signal/beep.
      03-20-2017, 08:42 PM   #358
zenmaster
Drives: '17 M2
You can't simply "code it on". You need to install a license just as you do with maps.
      03-21-2017, 11:01 AM   #359
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
found this on F30 code list...but i think it just has to do with brake lights and not hazards...
FEM_BODY 3060 ESS_AKTIVIERBARER_AUSGANG bremslicht_blinkend flachenvergroesserung
Change Emergency brake light from Inner Brake Lights to Flashing Lights.
      03-21-2017, 11:14 AM   #360
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Originally Posted by oscarin View Post
Thank you!!!!!
I will try with the application
Re
On bimmercode, expert mode, you could try (have not done myself)-
FEM Body 3040
how did it turn out with the "horn on locking" coding....did it work for you??
      03-21-2017, 01:38 PM   #361
oscarin
Re
FEM Body 3040
I have not yet done it, next week I have the 2000 revision, I have the application bought, waiting, as soon as I do it, I indicate the result. Thank you.
      03-21-2017, 02:35 PM   #362
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
FYI update to the app hit the store. BimmerCode can you comment on what changes are included?
      03-21-2017, 02:57 PM   #363
Mayhemx80
Drives: Bmw
I just turn off my sidemarker lights and now I'm getting an error, "your right and left turn signal malfunction!!". Any have the same problems?
      03-21-2017, 05:15 PM   #364
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
I turned mine off with no issue.
Are you in USA/Canada or euro?
MY?
      03-21-2017, 05:43 PM   #365
mjsaville
101
Thanks for this, yes you are right it's the locking / unlocking Beep. I received feedback from Stephan @ Bimmercode - super fast reply , he also told me to code "Checkbox acoustical lock confirm“ in the head unit module. Then go into settings for the door, and tick the accoustic sig loc/unlock.
thanks again
MJ
Dabozo624.50
Em-too279.50
      03-21-2017, 05:47 PM   #366
DivideBYZero
484
I have coded the beep on. It's odd as the sounder is at the back of the car.
      03-21-2017, 05:52 PM   #367
PiK
PiK's Avatar
Poland
61
Drives: M2 6MT
According to the changelog - bug fixes.
I've noticed the following option (I think it wasn't available in the previous releases):
Settings > Adapter > Slow communication
      03-21-2017, 10:44 PM   #368
Mayhemx80
Drives: Bmw
MY?
Bmw m4
I'm in the us.
It's turns of the side maker lights, but I get a left right turn signal malfunction with the exclamation.
      03-22-2017, 08:22 AM   #369
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
MY?
Bmw m4
I'm in the us.
Do your turn signals still work (is it a false message)?
      03-22-2017, 12:50 PM   #370
Mayhemx80
Drives: Bmw
No my turn signal doesn't work. Just the blinkers on my side mirrors work.
      03-22-2017, 06:24 PM   #371
Em-too
Em-too's Avatar
Drives: 2016 M2
That's odd. Did you replace with LED or are they factory? I'd recommend doing a restore and testing to make sure they work, then try again.
      03-25-2017, 02:12 PM   #372
lyric911
Drives: 2017 M2
Anyone else have really crappy connection to the iCar 2? Symptoms I've experienced:
1) Wifi will be connected, but BimmerCode can't connect (times out)
2) Wifi will be connected, but BimmerCode can't connect (Socket error)
3) Wifi will disconnect quite often
Just got it today, was able to get most of the coding I wanted done, but not without lots of cursing and bad times.
      03-25-2017, 02:15 PM   #373
lyric911
Drives: 2017 M2
Originally Posted by Leduardol View Post
I coded iDrive 6 with the new release last night. Worked seamlessly.
My car shows both idrive 6 lite and idrive 6 as options. Which should I choose?
      03-25-2017, 04:43 PM   #374
mjsaville
101
I sometimes get symptom 1, but usually because the icar 2 interface didn't have a valid IP address but never symptoms 2 & 3 - perhaps your device is faulty?
MJ
