09-26-2022, 04:46 AM | #1 |
Rep 2,505
Anyone using MHD rather than BM3?
Seems like MHD is popular among the M3/M4 and Supra Folks. Apps user interface is very good and your actual map is downloaded onto your device unlike BM3 it is stored on the cloud and many folks say it’s a generic map that is stored and not your vehicles OEM map.
Main reason the transition to MHD from BM3 is when you flash back to stock CALID and CVN numbers match your original maps numbers. These two numbers are used to determine tampering. BM3’s when you flash back to stock your numbers remain different and you will fail inspection and create a entire host of problems paying someone to update your DME and then it will be locked again creating more and more issues. I’m on the old DME istep version that you can flash without doing a bench unlock. That being said anyone using MHD on you M2c? Seems like it’s a upgrade to BM3.
2011 BMW M3 Sedan Alpine White Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD** Last edited by chmura; 09-26-2022 at 05:08 AM.. |
09-27-2022, 05:31 PM | #2 |
Rep 4,714
There's a YouTuber Thicwhips that used BM3 and then switched to a different tuner. I thought it might have been MHD. Could be worth checking out he's got multiple BMWs on his channel.
11-22-2022, 03:48 PM | #3 |
Rep 1
I am running MHD only on my M2 N55 and I'm pretty happy with it, never compared with BM3, but to return to stock maps it works good as I still use the official service from time to time.
11-23-2022, 09:02 PM | #5 |
Rep 932
I run both and its no upgrade. I prefer BM3 for so many reasons.
For warranty and that ISTEP CVN stuff if you flash with relock with BM3 you get your actual stock file back on the car. When I was looking to buy a tune I actually did a ton of research on it and this was one of the things I looked into and BM3 doesn’t even met you activate if it doesn’t have a matching stock file. You get this message that says “Data Support”. So you only are able to even activate if they got your stock file match. When you relock your DME with the stock tune it flashes the car literally to that stock file and I verified with ISTA that CVN and CAL ID match. It even resets your flash counter to zero. Warranty wise though BMW can use whatever they feel like to void warranties so whatever anyone says its always up in the air when it comes to what they say. Pay to play LOL |
11-28-2022, 11:00 AM | #6 | |
Rep 1,813
MHD just does it a little differently than BM3.
11-30-2022, 09:21 PM | #7 | |
Rep 1,074
Instagram: M2_Medusa
