M2 Technical Topics > Track / Autocross / Dragstrip > Do I have another track day on these tires?
      08-06-2023, 12:02 PM   #23
AlpinewhiteM2C
AlpinewhiteM2C's Avatar
121
Drives: old: E90 335i E46 M3 new: M2C
fleetfoot - our cars eats up the outer shoulder, especially in the front. My PSSs are looking like yours and I think they should be good for one more hard, dry track day. If you add more camber in the front, something like 3.5 you may be able to stretch them out to 2 days.
fleetfoot120.00
      08-06-2023, 12:18 PM   #24
fleetfoot
fleetfoot's Avatar
Drives: 2017 M2, 2013 E92 328i
Thanks! I was hoping to get one more weekend out of these PS4Ss. Is there anything in particular you look for on the shoulder to know they’re done?
I’m planning to add a little more camber next time I get the car aligned. I’ve also got a set of RS4s waiting in the garage. It sounds like those shoulders might hold up a little better?
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9"
      08-06-2023, 08:36 PM   #25
E90convert
Drives: F87 M2 DCT, F15 X5
This is what one of my PS4S fronts looked like after 3 days on stock camber. I added Vorslag camber plates and -3.0 degrees camber in the front (-2.0 in the rear). Did 3 days last weekend with my passenger tire looking like that on a clockwise track, running 40 psi hot and had no problems. There was no additional wear on the shoulders for either tire. I'd say if you can get some camber plates, the tires can be saved.
fleetfoot I'd run those many more events. They look great.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport
Sold in 2023 '12 F30 335i 8AT Sport Line
Sold in 2020 '08 E92 335xi 6MT
Sold in 2016 '08 E90 335i 6MT - FBO
fleetfoot120.00
      08-06-2023, 09:12 PM   #26
fleetfoot
fleetfoot's Avatar
I just thought of a better question so I know what to watch for: does anyone have a picture of PS4Ss with completely worn out shoulders? (and not due to chunking like the OP)
      08-09-2023, 07:34 AM   #27
Gotfuel
Gotfuel's Avatar
17
Drives: Trek Madone
[QUOTE=MooMooM2;30363781]What size are you running on the Falkens? What I am seeing *and have heard over and over* is that 19s just don't have a ton of tire size choices. I have also read that about the bridgestones but people swear by them.
Sorry for the late reply, I’m running 245/265. It really was a stop gap for this year. I just bought the car and didn’t have the funds to get a second set of 18s, plus tires. I’ll drop to 18s, and get a similar configuration that gives me a nice sidewall similar to the gt3 as mentioned above. BTW, any one gonna be at Mid O 9/15-17 with ARPCA?
Current:
16 M2, LBB DCT. 14 335 Sport Superman Spec, 06 Avant 6sp Many Things, 06 Range Rover Sport Supercharged
Past: 13 RS5 Coupe, 04 M3 Vert, 95 URS6, MK6 GTI, 69 Chevelle Copo 427 clone, many Fox Mustangs
      08-09-2023, 07:36 AM   #28
E90convert
I’ll be instructing and driving at Mid O on 9/23-24 with NORPCA
      08-09-2023, 08:51 AM   #29
Gotfuel
Gotfuel's Avatar
17
Drives: Trek Madone
Bummer, would be good to meet up. I’m technically assigned to NORPCA (I live East of CLE), but started doing ARPCA HPDEs last year, and the Sept 9/23-24 is my anniversary, and if I’d like to have any more anniversaries, I’ll never be able to attend that weekend.
Current:
      08-09-2023, 09:02 AM   #30
E90convert
Yeah I understand that. Maybe I’ll see you at the spring event.
      08-09-2023, 10:02 AM   #31
AlpinewhiteM2C
121
I don't have a picture of actual tires myself but found this: https://www.reddit.com/r/CarTrackDay...side_shoulder/
I personally would avoid using a tire w/ no more thread on the shoulder as 1) I don't want to potentially miss out on track day sessions because my tire isn't up to par and 2) I'd rather not risk chunking and a potential blow out from a chorded outer edge.
However if you add more negative camber the tires you have may last longer as it will not be destroying the outer shoulder at the same rate as being on stock camber settings. Not an M2C but when I added coilovers and 3.5 degrees of camber on my GR86 I was able to salvage a set of tires that had heavy shoulder wear from being run at autocrosses at stock camber settings.
