03-09-2021, 04:21 AM | #177 |
Rep 69
DME
Wow, please update us on progress as to how you do this. My tuner was a bit loath to do this as he said a lot of other functions on the car rely on the original DME to function correctly. If this does work I'm in
03-09-2021, 02:56 PM | #179 | ||
Rep 1,262
Drives: BMW 1M
The moment you connect the old DME to the car which had the "locked" DME you will understand what I mean. |
03-09-2021, 03:18 PM | #180 | |
Rep 6,637
https://f87.bimmerpost.com/forums/sh...php?p=27024806 however you noted later that the poster here said he went and got a JB4 and you wanted to know what the story was with that. I don't know if he ever got back to you? |
03-10-2021, 05:43 AM | #181 | ||
Rep 1,262
Drives: BMW 1M
The DME and certain modules are unique to each other apparently. When a dealer orders a new DME from the factory it is assigned to that chassis number, not sure what/why/how?! I know of two tuners in the UK who have "virginised" DME's to try and retro fit them to M2C's with the new Bosch software DME's without success. On a good note, it seems a software tuner has had success regarding a "bench unlock". I'm waiting on more news |
GarageMadness665.50 |
03-10-2021, 05:37 PM | #182 |
MDM = Must Drive More
666
Rep 479
I'm a firm believer that no matter what the challenge, someone somewhere with radical knowledge and passion will come up with a solution. I've subscribed and keep tabs on this thread to read what comes out about. Patience is the key!
'21 M2 Comp
Sunset Orange | MT | Exec Pkg |
e92ben1053.00 |
03-10-2021, 05:47 PM | #183 | |
Rep 5,728
Drives: 2019 M2 Competition
M2C-Free M2C-Locked |
03-10-2021, 09:17 PM | #184 |
Remove Before Flight
6822
Rep 1,611
Three, I think?
2018-sometime in late 2019/early 2020 M2C: Flashable via OBD-II port Sometime in late 2019/early 2020 - mid 2020: Bench-flashable Mid 2020-present: Locked At least that's how I read things? My M2C (Feb 2020 build) was bench-flashed by Carbahn but I couldn't use their optional tablet to go to/from the original OEM flash that the earlier cars could use with their OBD ports. Could be wrong? |
infinitekidM2C4206.50 |
03-11-2021, 12:31 AM | #185 | |
Rep 1,262
Drives: BMW 1M
I should have never sold my 2018 M2Comp : |
03-18-2021, 04:47 PM | #187 |
Rep 775
03-18-2021, 05:23 PM | #188 | |
498
Rep 697
Drives: Alpine White 2020 BMW M2C
Garage List 2017 BMW X6 M [0.00]
2020 BMW M2 Competi ... [0.00] 1993 Mazda RX-7 [0.00] 2006 Mitsubishi Evo ... [0.00] 2005 BMW M3 ZCP [0.00] 2016 Ducati Panigal ... [0.00] |
so far the earliest I've seen confirm they have the new ECU is August 2020. |
03-18-2021, 06:45 PM | #189 | |
Rep 3,540
My DME's production date was July 5th 2020. I've heard if it was produced June 2020 or before it can be bench unlocked. Just missed the cutoff...
03-18-2021, 09:03 PM | #191 |
498
Rep 697
03-19-2021, 03:42 AM | #192 |
Rep 775
Different drivers though. The DME unlock is merely an inconvenience which can be 'cracked' with a bench unlock. The new Bosch DME stuff is an outright block to any ECU tuning. Considering this change will affect BMW, Mini, Toyotas and other brands that use the same Bosch DME it has a huge effect on the aftermarket industry. Also consider that the effect of such a block will increase exponentially as newer models are released. There is a big driver and a lot of money behind ensuring this gets broken. But, we'll see.
03-19-2021, 07:18 AM | #193 | |
Rep 9,709
With this in place I wouldn't bet on it being cracked any time soon. You'd be better off installing a second ECU piggyback like they used to do back in the day before OE ECU cracking. All the engine function is taken care of by the secondary ECU, but primary ECU still thinks it's in control. |
msdss497.50 |
03-19-2021, 07:57 AM | #194 | |
Rep 4,254
///M Power
msdss497.50 |
03-19-2021, 10:50 AM | #196 | |
Rep 775
03-19-2021, 11:57 AM | #197 |
Rep 3,540
Or just query the DME via ISTA like I said above. There's no need to remove the DME.
03-19-2021, 12:23 PM | #198 |
Rep 775
Sorry, I missed that. This is news to me. Downloading as I type. Will try it out later. Thanks
