07-31-2023, 03:15 PM | #23 | |
Rep 2,873
I do not believe this is correct; without a cage, a full harness is not safest/best. When you have a fixed seat and harness, a roll cage is also required or at least advisable (rollover protection hoop, not neccessarily a full cage). Otherwise, the belts/seat will hold the driver fully erect in the seat, incurring risk from roof collapse. Street cars are tough, but they assume that in a crash you are curled over into the airbag (or could be) so you are not held in place; this is also the case for the Quickfit setup with "ASM". I believe that this is part of the BMW CCA regs for HPDE. Since HPDE is so loosely regulated, I assume there are other sanctioning bodies that could not care less and would let you run sitting on a milk crate. And related to other posts: I don't think they just 'make up their standards' - they are getting DOT approval which implies that they are meeting a DOT specification/standard. And it would be incorrect to assume that every aspect of an F87 seat is superior to E92; they are testing for downforce on the back, probably not something the OEM's look at specifically. This said, I think it is a safe application, I just think it needs to be a personal decision - I used QF's in my F22 and am eager fo find a way to put them into the F87 (either get custom holes put into my M2C seatbacks, or retrofit a set of OG M2 seats). |
fleetfoot120.00 |
08-03-2023, 06:46 AM | #24 | |
Rep 1,644
I just don’tike to make life safety decisions with words like “assume” and “imagine”. I’ll take the oem 3 pt system with airbags and keep my top speed reasonable. |
08-04-2023, 08:06 AM | #25 | |
Rep 553
No one is making 'life safety decisions' based on assumptions or the like. I simply trust (reasonably I'd argue) that BMW carried over the seat integrity standards from the e82/90 to the F22/87. Now if we were talking about Ford/GM I might not be so confident, Great Wall Motor I'd say no chance. |
08-08-2023, 06:53 AM | #26 |
Rep 1,610
are the reason these belts not "approved" just because of the seat? So say you have a cobra or a recaro would then the e9x setup be "ok" for the m2 (from scrhotch or their distributer perspective)?
08-08-2023, 10:27 AM | #27 | |
Rep 557
There is definitely some legal cya going on but given all the knowns I personally feel comfortable fitting a Pole Position ABE and quick-fit pros with the optional sub belt as my solution for a dual-use vehicle that retains the 3-point. Safety is personal, and what various organizations will and will not allow vary. |
