M2 Technical Topics > Suspension | Brakes | Chassis > M performance coilovers kit
      10-10-2021, 09:49 AM   #1
oranzada_m2c
Czech_Republic
17
Drives: M2C 2019
hi i have problem on front right wheel, piston from damper is moving
front right bad
https://streamable.com/00sy3l
https://streamable.com/twmhkh
front left good
https://streamable.com/1eejhe
      10-10-2021, 03:25 PM   #2
M Fifty
844
Drives: M2 & 330CI
Doesn't look like the bolt holding the strut to the front upright is tight? Maybe take the wheel off and post some pics of the area while giving it a shake.
      10-10-2021, 04:30 PM   #3
oranzada_m2c
Czech_Republic
17
Drives: M2C 2019
he is tight... probably bad damper... piston is moving, is common problem on KW V3....
      10-10-2021, 04:35 PM   #4
M Fifty
844
Drives: M2 & 330CI
If you know the answer, why ask?
chris7197324.00
      10-11-2021, 03:25 PM   #5
x233
Ukraine
284
Drives: M2C, M235xi
It's not really apparent that the piston/damper is the problem. The whole assembly is moving when you shake that wheel. Can see the wobble in the top mount (don't know how it looks on the other side) but can't really see any wobble of the piston vs the shock body when you do that.
Everything OK at the bottom?
Also, where does that clunk come from?
      10-12-2021, 02:39 AM   #6
oranzada_m2c
Czech_Republic
17
Drives: M2C 2019
front right damper - if i change rebound or bump, nothing happen.... damper dont spring...
front left damper is OK with changing rebound and bump....
top mount camber plate looks good and is tight to spec.... just piston in damper is moving....
      10-12-2021, 04:31 AM   #7
Caduceus
342
Drives: 2008 135 (sold), 2017 M2
If I had to guess, top nut has been done up via impact driver and the piston has been allowed to rotate excessively within the shock body and it’s come apart inside.
      10-12-2021, 09:30 AM   #8
oranzada_m2c
Czech_Republic
17
Drives: M2C 2019
it wasOK 9 month and 9000km... its bad right damper.... damper is not moving... left is quite OK, but not much better...
top camber plate is 100% OK
      10-15-2021, 03:35 PM   #9
oranzada_m2c
Czech_Republic
17
Drives: M2C 2019
BMW MPS, KW V3 and clubsport is shit, dont buy if you are pushing car....
https://streamable.com/uxtty8
toned44.00
blitzyo53.00
      10-16-2021, 01:02 PM   #10
M Fifty
844
Drives: M2 & 330CI
Nice bridge you have there...
      10-16-2021, 07:57 PM   #11
x233
Ukraine
284
Drives: M2C, M235xi
I understand the frustration. But it's not surprising IF a) there was an installation error or b) the car gets abused (or both). I could post a dozen of similar videos/pictures of other coilover kits and shocks (KW, H&R, Koni, Bilstein, AST) that I had on my previous cars and which failed in 5000 km or less (mostly as a result of abuse). If it's any consolation.
      10-17-2021, 01:32 AM   #12
oranzada_m2c
Czech_Republic
17
Drives: M2C 2019
no installation mistake... omg..... all bolts were correct torque moment...
kw v3 and clubsport is just bad product, if somebody is pushing car sometimes on track.... its suspension for probably car meeting.....
but bmw is writing, "suspension is tested on tracks"....
      10-19-2021, 12:10 AM   #13
Robbyjai
Drives: BMW M2C
lols i track the hell out of my car.. and no problems with my BMW MPS coils ...nothing wrong with the product i know heaps of guys here who have it and dont have issue and have had it on longer than i have... and track the car as much as me
      10-19-2021, 01:51 PM   #14
blitzyo
Drives: 19' M2C
Mine did the same thing in 5 track days (5000km total). What a waste of money.
      10-22-2021, 03:29 PM   #15
oranzada_m2c
Czech_Republic
17
Drives: M2C 2019
yeah.. they are shits....
      10-23-2021, 03:43 AM   #16
M Fifty
844
Drives: M2 & 330CI
Good job you both had the BMW warranty then - yes?
