05-14-2019, 01:06 PM | #1 |
Rep 923
M2 comp brakes (2NH) how do they preform on track?
I have OG M2 (MY17) and do +/- 8 track days a year (mostly Nurburgring). My current brake set-up is the OEM 'blue" M2 brakes with Pagid RSL29 / ATE racing brake oil / steel linings. The brakes perform rather well on Nurburgring (did not drive any other tracks the last two years). My front rotors needs replacing and I can get a rather ok deal on a brand new M2 comp 2NH "grey" M brake set (bigger rotors + 6/4 calipers + bigger shields). I'm talking about the bigger 6 piston / 4 piston set from the M2 competition; also known as the 2NH option (or standard in some country's on the M2 comp).
Yes; I know AP racing is lighter and even better for ultimate track performance. Yes; I know I can only fit 19" with 2NH brakes. Yes; I know the brake pads are replaced faster with AP racing calipers. I had AP racing BBK + Pagids pads on my Z4M, so I know AP racing brakes very well and how they perform on track and street But a full AP racing set is a bit more expensive then this 2NH set and in my country it is actually not legal to fit aftermarket brakes on your car. You have the chance to get red flagged at the annual car check (MOT) and then you need to remove them if they notice the aftermarket brake upgrade (sometimes they notice, sometimes they don't). So the M2 comp set is cheaper + rather safe and hassle free to fit on my OG M2. But...how good are the 2NH brakes on track with steel lines + different brake oil + track pads? Is the upgrade in bite (bigger contact patch) and less fade (bigger rotors) really noticeable and how are people experiencing these brake on track? Not talking about driving with standard brake pads on tracks of course...then every brake set-up is crap on track. That's normal
05-15-2019, 12:59 PM | #2 |
Rep 379
I would like to know as well. I am giving "M2C brakes upgrade" serious consideration as well. I feel we will all know a good bit more over the next few months. The reviews out now do rave about the M2Cs upgraded brakes. Don't feel there are many pad options around, yet.
05-15-2019, 03:37 PM | #3 | |
Rep 923
Wern3r26.50 |
05-15-2019, 04:10 PM | #4 |
Rep 923
Found some
05-15-2019, 11:06 PM | #5 |
Rep 111
I had a trackday in my M2c recently and upgraded stainless lines, dot 4 fluid, and race pads (Pagid RSL29). The brakes performed flawlessly with no fade.
My previous track car had Brembo GT brakes on all four corners and I’d say these performed at a similar level. |
05-16-2019, 12:55 AM | #6 |
Rep 4,515
M2c has better oem brake cooling built in than M2. Hence on m2c, I'd expect both blue std brakes and grey 2NH brakes to work better on track than if fitted to M2, unless of course additional cooling ducts have been retrofitted.
Current '22 X3M LCI.. |
05-16-2019, 05:54 AM | #7 | |
Rep 147
what brand is your recommendation for brakepads? trackday use.. thx |
05-16-2019, 07:03 AM | #8 | ||
Rep 4,515
Had similar set up on my m135i and it was superb.
05-17-2019, 08:27 AM | #9 | |
Rep 120
They work wonderfully, no fade. However the front OEM rotors have many fractures now so I'm having to replace. No after market options yet although Girodisc is working on changing that. Interestingly my rear caliper paint is changing from silver to a noticeably more golden color from heat : the heat is high at the rear because me being new to this cars rwd (coming from a GTR) I'm still running with DSC in MDM mode (even did the first few days with DSC fully on) im not ready to turn DSC fully off yet... soon. Rear pad wear is also significantly impacted by my DSC usage, they are wearing much faster than the front pads which is not something I'm used too seeing.
'19 BMW M2 Competition | BSM | DCT | Exec Pack | GC Camber Plates | Acexxon Reflectors | Pagid RS29 | Castrol SRF | 788m MP4S | 437m AD08R
05-17-2019, 10:37 AM | #10 | |
3841
Rep 54,352
Drives: F80 M3
Hawk DTC series doesn't seem to very popular anymore plus they wear way too quickly. PFC should have something soon. |
05-17-2019, 10:56 AM | #11 | ||
Rep 120
I just picked up a set of XP10's to try out mainly because I don't like the Pagid price point - I have no complaints with the Pagids, will probably return to them at some point just pretty damn expensive in the 2NH pad shape.
05-17-2019, 11:38 AM | #12 | |
Rep 3,714
05-17-2019, 11:39 AM | #13 |
Rep 3,714
Non sense, my DTC 60/70's on my 17 M2 lasted at least 8-10 track days on R compounds at instructor run group speeds and still had about 3-4 mm left.
05-17-2019, 12:44 PM | #14 |
Rep 379
Very good to know, there are certainly more around than I am aware of.
05-17-2019, 01:24 PM | #15 |
3841
Rep 54,352
Drives: F80 M3
Not particularly on the F87, but on the E9x platform that was the major complaint. Also in our own experience in Time Attack.
05-17-2019, 01:57 PM | #16 | |
Rep 923
05-17-2019, 01:59 PM | #17 | |
Rep 923
05-17-2019, 02:00 PM | #18 |
Rep 923
The front calipers are the same pad size as the F10 M5 (+ M6)...so everything that fits this will also fit the M2 comp BBK...the rear caliper is specific for the M2 comp BBK.
05-18-2019, 11:24 AM | #20 |
Rep 4,154
Drives: 1/18 Monte Carlo Blue E92 M3
Just ran my M2C at my first track day, everyone including another M2 owner buddy that attended with me said I need pads/fluids at least before going to the track. My stock M2C brakes compared to his M2 with pads + fluids out braked him during the track day and I felt more confident than he did. He even mentioned it being a passenger in my car.
Commanderwiggin2050.00 |
05-18-2019, 03:47 PM | #21 | |
844
Rep 1,962
https://www.realoem.com/bmw/enUS/sho...diagId=03_5003 |
05-18-2019, 04:15 PM | #22 | |
Rep 1,200
Edit: Looking up some of the brake features employed by BMW : Dynamic Brake Control (DBC). When, in an emergency, you apply the brake pedal quickly and with force but without really further increasing brake pressure, Dynamic Brake Control (DBC) instantly builds up maximum brake pressure, bringing your BMW more quickly to a halt. Even when the driver fails to press on the brake pedal with adequate force, DBC ensures the braking distance will be a short as possible. The DBC control unit adjusts braking pressure to suit the current speed of the vehicle and the brake's level of wear. Furthermore, the DBC computer is networked with the vehicle's other chassis control systems, such as Dynamic Stability Control (DSC) and the anti-lock brake system (ABS), which work together to ensure the highest levels of driving safety. Dynamic Brake Control (DBC) supports the driver actively and reliably when braking in an emergency. By electronically monitoring the speed and pressure with which the driver applies the brake pedal, it is able to recognise an emergency braking situation - and instantly ensures that full braking power is applied to the wheels. This automatically puts the brake force into the ABS range of control. This process ensures that the stopping distance is not lengthened unnecessarily by abrupt braking. Whether the driver applies the brakes quickly or slowly, the system responds to the driver’s actions automatically and ends brake pressure buildup via DBC. Adaptive Brake Assistant Not too heavy, not too light: the Adaptive Brake Assistant adjusts the amount of brake power applied to the wheels during emergency braking so that your BMW comes safely to a standstill. The Adaptive Brake Assistant is a practical adjunct to the Active Cruise Control (ACC) system. The radar sensors at the front of your BMW measure both the distance to the vehicle ahead and its current speed. If the vehicle ahead stops suddenly, or if an obstacle appears in the lane ahead, the Adaptive Brake Assistant calculates whether emergency braking must be applied, and the necessary amount of brake pressure. Having calculated the optimum braking power, the system activates the brakes only after the driver has applied the brake pedal. It also gives the driver warning signals either using sounds or visual warnings on the dashboard or the Head-Up Display depending on the model. The type of warning differentiates between a cautionary signal (e.g. if the vehicle ahead is too close) or an acute alert to a critical situation (e.g. the vehicle ahead brakes suddenly). In order to minimise brake reaction times, the brake pressure is permanently maintained high enough to hold the brake pads on the discs without actually impeded wheel movement. The system can also momentarily delay brake application and apply engine braking to make braking distance as short as possible relative to the situation.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder Last edited by Commanderwiggin; 05-18-2019 at 04:25 PM.. |
