M2 Technical Topics > Suspension | Brakes | Chassis > Clicking sound turning wheel
      10-14-2021, 12:56 PM   #45
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Originally Posted by HunterHofman View Post
Interesting stuff, I have found the same in the meantime. I wonder if anti-seize would be the best way to lube up these pinchbolts, would silicon grease or ceramic grease work too, you think?
I did a bit of searching on it, by I'm by no means an expert. The copper grease seems to be the most popular option.
      10-14-2021, 03:09 PM   #46
M Fifty
844
Drives: M2 & 330CI
My knees make similar noises every time I do Squats. Where do I apply this anti-seize compound, and how far should I move my kneecap to minimise the noise?
SebsM2652.00
jdubm2c169.00
VisualEcho6636.50
      10-24-2021, 12:49 PM   #47
TheHunterHofman
TheHunterHofman's Avatar
Netherlands
237
Drives: 2017 BMW M3 Competition (LCII)
Hm, tried a couple of things in the meantime: first I replaced the pinch bolts and fasteners with new ones, lubricated the construction of the front strut with anti-seize, torqued it down to 45 nm (~20% of the original 56 nm torque value, because of the anti-seize) and buttoned it all up. Still clicks.
I then tried again, this time also thoroughly cleaning the hubs of the car and the contact area of the wheels and torquing it down to 60 nm, while also jacking up the suspension (so that the suspensions is under load). Interestingly enough, the sound on the right hand side is gone, while on the left hand side it's still there. Driving me nuts.
Any further suggestions anyone?
      10-24-2021, 02:03 PM   #48
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
I recently read this, and hadn't read it before.
      10-25-2021, 03:25 AM   #49
TheHunterHofman
Netherlands
237
Thank you man, could you possibly send me the link to that thread? Will be trying this soon.
      10-25-2021, 08:30 PM   #50
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
It's on Facebook in the M2 & Comp board.
https://www.facebook.com/groups/1268987769782211
      10-27-2021, 09:49 AM   #51
TheHunterHofman
Netherlands
237
Thanks, I entered the group and sent out a message there. Would you think it's a good idea to remove the strut from the knuckle, just enough to thoroughly clean the inside of the knuckle, and the bottom of the strut, before tightening it back down again with new pinch bolts and fasteners, at a slightly higher torque spec (without anti-seize, as I'm not sure what the anti-seize actually does)?
      10-27-2021, 12:24 PM   #52
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
I can't imagine it's dirty enough to need to clean that thoroughly.
I'd contact your local BMW dealer and just ask them what they have done when guys come in with this clicking. It's obviously nothing the owners are doing, having happened to many stock cars.
Anti-seize simply keeps the 2 different metals from bonding. But it must be used with caution, as there are many bolts you don't want to put it on.
      09-26-2022, 01:52 PM   #53
gphung
194
Drives: 2018 M2 LBB - 6MT
2018 BMW M2  [0.00]
Have you managed to solve the noise on your car? Curious if you have an update.
      09-27-2022, 03:19 AM   #54
TheHunterHofman
Netherlands
237
Smile
Hi man, yeah check this out:
Hope that helps (and perhaps consider subscribing)
gphung193.50
Kattanah137.50
      03-03-2024, 12:34 AM   #55
BMW63
Drives: Bmw N55
behind the disc is a aluminum plate which mounts with 3 bolts to the wheel hub, The clicking sound comes from these plates, don't try any of these other fixes I did them all with the same issue, just install 3 X ceramic or soft copper washers between the plate and the hub, this solved my issue immediately and only required taking the wheel and disc off, replacing the hub bolts and installing shims was a waste of time.
Rub1con76202.50
