11-21-2020, 06:46 PM | #6799 |
Rep 602
Had a good laugh at this new mechanic I went to. He said my air filter was filthy. Out of curiosity, I asked how much it would cost. He said $175
I also installed some led turn signals
Drifter2090909.50 |
11-21-2020, 07:59 PM | #6800 |
Recovering RS4 owner
297
Rep 266
finally got around to installing the F22 sound deadening under the hood, in the trunk/rear wheel wheels, etc. made a huge difference in cabin noise when on the highway at 70mph or so
dtmurf480.00 Drifter2090909.50 |
11-21-2020, 08:34 PM | #6801 | |
Rep 38
11-21-2020, 08:47 PM | #6802 |
Rep 38
CF Braces
The Turner CF braces look so much better than the metal after thoughts BMW used.
11-21-2020, 10:26 PM | #6803 |
Rep 800
11-22-2020, 09:13 AM | #6804 |
Rep 602
Oh man that's a big project. Going to add this to my list... how long did this take you? Did you use a post to guide you on where you should place the material?
11-22-2020, 10:21 AM | #6805 | ||
Rep 6,635
He told me the app makes a back up so if I ever want to undo the change you can. I'm not sure that works because I have not tried reversing it but it gives me some piece of mind. CarPlay with fullscreen is so much better, especially when you consider being able to use Waze fullscreen. It also just looks nice. |
11-22-2020, 11:14 AM | #6807 | |
Rep 602
Here is the part number from advanced auto parts:
11-22-2020, 11:38 AM | #6808 | ||
Rep 6,635
11-22-2020, 12:37 PM | #6809 | |
297
Rep 266
removing all panels etc took a half hour. Installing everything took an hour, mainly just due to carefully unclipping all the wiring to slide the padding under, getting it all positioned properly, trying not to break clips etc. Then gave the interior a good detailing as everything got reinstalled. so maybe 2.5hrs total? |
11-22-2020, 01:48 PM | #6810 |
Rep 38
Sebs, your private messages are full and won't accept more until you delete fyi. If your gonna powder coat the rims that's $500- use gloss black. You can DM for an offer on the OEM corner braces. THanks.
11-22-2020, 06:04 PM | #6811 |
Rep 757
Not a fun job but totally worth doing. I put a little extra sound deadening on the floor, not sure if it helped but it can't hurt! Did you do the filler pieces in the front fenders just in front of the doors? I think they make a difference too as the block engine sounds coming into the cabin.
'17 M2 DCT Long Beach Blue
11-22-2020, 09:38 PM | #6813 |
Rep 6,926
Drives: 2018 M2 AW DCT
11-22-2020, 09:48 PM | #6814 |
Rep 425
good job! I'm looking to install the side plates (as taped to the body of the car) as per your first picture - would i just have to remove the side panels next to the back seat? Would i be required to take out the actual seats as well? were there any specific instructions to follow to remove those side panels?
11-22-2020, 10:37 PM | #6815 |
Rep 86
Created a thread to keep track of what gets done to the car. Probably should've started in June '19 but I had no idea things would change this much in 18 months. Check it out.
https://f87.bimmerpost.com/forums/sh....php?t=1777324 |
11-22-2020, 10:38 PM | #6816 | ||
297
Rep 266
* remove rear seat bench (pull up at front edge, then out/away) * remove side panels (5x plastic clips per panel, 3F 2R) there was some info in the f22 thread I linked above, and I looked at a couple of youtube videos, but it was pretty straightforward. I didn't break any clips removing, but did on reinstall when I didn't have it lined up properly and went to pop it in. $3 and a trip to Autozone fixed that though. |
M2Power6.00 |
11-22-2020, 10:44 PM | #6817 |
Rep 436
Tracking or Parking? I'd cry like a baby parking. I'd feel like it was a battle wound driving. It would hurt and my pride too but I'd feel a little better haha. 😜
11-23-2020, 06:30 PM | #6818 |
Rep 564
Do you know if those clear the Dinan Airbox? I am doing the M3/4 CF strut retrofit but I absolutely love how those turner pieces look and would like to add them on if they would fit.
11-25-2020, 10:14 PM | #6819 |
Rep 406
Drives: BMW 328xi BMW X5 F15 BMW M2
Replaced headlight bulbs to the OSRAM XENARC 66140 COOL BLUE BOOST (7000k).
I believe they are the brightest HID's in the market. Although they are 7k they look pure white like leds. https://www.theretrofitsource.com/d1...CBB?quantity=1 Left is the osram, the one on the right is the OEM bulb.
11-26-2020, 02:33 AM | #6820 | |
297
Rep 266
eldogo274.00 |
