10-26-2020, 06:55 AM | #1 |
Rep 235
Building the M2 CS (and others!) a home..
I have been working on this garage since the same day allocations went out (total coincidence). It's almost complete and it's totally weather tight now. Figured for entertainment while we wait why not share what's been keeping me busy the past couple months.
https://www.dropbox.com/sh/z81xyvg1p...7DJfRsDqa?dl=0 I'm not sure if this link will work here if it doesn't I uploaded pictures to my album.. Feel free to share your spaces (for inspiration and ideas!)
///M2 CS - No longer just a dream.
10-26-2020, 07:07 AM | #2 |
Mmmm... Bavarian
2129
Rep 1,690
Here's mine! Just finished it last year. Love it and lots of little things that make it a great working garage.
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S Last edited by sdhotwn; 10-26-2020 at 07:46 AM.. |
10
TCBavarian674.00 Bimmed Out1908.50 Hedoniste3834.00 Poochie9104.50 gmhl10384.50 Davil6524.50 W///7489.50 CSBM52721.00 BMrDrmr314.50 1bmwaddict787.00 |
10-26-2020, 07:39 AM | #3 |
Rep 235
love the lift! I may have to add one of those eventually, though I've got enough room for 4-6 cars in the garage itself.
10-26-2020, 07:49 AM | #4 |
Mmmm... Bavarian
2129
Rep 1,690
Mine will solidly hold 4 without the lift if we wanted. The CS will be the 4th car, and keeping the space clear for the kids and yard stuff etc on the right side is easiest by stacking two cars with the lift. It was also because I do 98% of all the work on my cars myself. So having a lift is a huge thing for me finally for doing track day prep and service etc. I have the F30 up on it right now partially apart because of the oil filter housing gasket leaking.
The epoxy flooring, drain, and the tons of LED lighting on the ceiling have been more than worth it. I also put in an air conditioner when it was build (as well as a heater of course). That A/C unit is amazing in the summer for pulling out humidity etc. Can't recommend that enough!
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S |
10-26-2020, 09:17 AM | #5 |
Rep 1,552
very cool!
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
10-26-2020, 06:25 PM | #6 |
Rep 2,819
Drives: e82 1M, f87 M2cs
Can I play too?
Epoxy floor coating. I have a split garage with 4 bays at a 90 degree angle. One is the daily driver section, and the other is the shop. I have a two post service lift, but it does a nice job of increasing winter storage.
10-26-2020, 10:51 PM | #8 |
756
Rep 2,149
Wow, nice. If you don't mind me asking, how much does it cost to build a garage like that? I've been looking at buying a house and it increases my options if I look for one without a garage and build my own.
10-27-2020, 06:01 AM | #9 |
Rep 235
Can't wait to see!! Good tips so far and a few great ideas!
10-27-2020, 06:07 AM | #10 | |
Rep 235
edit: Prices of materials went up 30-40% over the past 6 months so it is a bit more pricey currently to build. Which was another reason the cost was higher compared to the estimate, I'd guess the estimate would have went up a good bit (100k+)had I used a contractor to build it when I was able in September.
10-27-2020, 06:15 AM | #11 |
Rep 235
This was why I built mine, houses with garages were just too much last year. I'm single and a business owner so it was a bit tougher getting a mortgage also needed more down because it wasn't a conventional loan.
10-27-2020, 06:44 AM | #13 | |
Mmmm... Bavarian
2129
Rep 1,690
M2 CS
10-27-2020, 06:46 AM | #14 |
Mmmm... Bavarian
2129
Rep 1,690
My wife dreams of this setup! She wants the shop totally separate from the daily drive section she wants a perfectly empty pristine bay to drive into each day with no kids toys, lawn stuff, or car projects.
M2 CS
10-27-2020, 06:48 AM | #15 | ||
Mmmm... Bavarian
2129
Rep 1,690
M2 CS
10-27-2020, 06:55 AM | #16 | |
Rep 235
I got a lumber list in March it was about 14k in September it was at 19k for the same materials.
10-27-2020, 06:57 AM | #17 |
Rep 235
On a side note my project came to a grinding halt this morning as my electrician notified me he is waiting for his Covid test and can't do my garage until things are cleared.
10-27-2020, 07:58 AM | #18 | |
Mmmm... Bavarian
2129
Rep 1,690
I put in two electric car charging drops for the future, and separated the ceiling lights to 3 circuits so I didn't have to run the full 120,000 lumens all the time. Also put in 240V for the compressor, welder, and lift. It's a 100 amp sub panel with some run off the main house panel, so you can't run everything simultaneously, but it covers things well enough.
M2 CS
BMrDrmr314.50 |
10-27-2020, 08:33 AM | #19 | ||
Rep 266
Drives: '89 Land Cruiser, '18 M2
E92M3LMB23.00 |
10-28-2020, 05:37 AM | #20 |
Rep 235
Where are you in the process? I started in February getting drawings and plot plans done.. Then covid. My garage required a special permit which added about 60 days onto the process(not to mention at least 5k in additional costs).
10-28-2020, 07:04 AM | #21 | |
7490
Rep 12,310
So you mentioned you stack the cars so you can have space for the other stuff, but did you at all consider a 2 post? My ceiling is only 9 ft tall, so unfortunately I might just have to settle for a quick jack. Keep the pics coming guys, these are easily my favorite type of threads!
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
BMrDrmr314.50 |
10-28-2020, 07:28 AM | #22 | ||
Mmmm... Bavarian
2129
Rep 1,690
- I can move the lift around if needed and it's not attached to the floor. I did pour the floor thick so I can do two post later though if I want to. - storing the car for really extended periods with the suspension extended isn't great, so this resolves that. - you can't see it in the photos but the lift is equipped with sliding jacks so I can lift the car off the deck to do suspension work while it is up on the lift. So far I haven't found any drawback to this arrangement given the space I have and the work I do.
M2 CS
