01-14-2021, 04:35 PM | #23 | |
Rep 201
Great info. Thanks! |
GasBurnlife(landapanda)576.00 |
01-15-2021, 09:39 AM | #25 | |
Rep 181
It’s not plug and play right? The weight saved by switching to a lighter battery should be added to the list too. |
01-15-2021, 10:23 AM | #26 |
Rep 1,263
Its PNP...I had a tech try to register it with the car but he wasn't able to. I've had the battery in for about 1.5 years now. No problems to date
01-16-2021, 01:28 PM | #27 |
Rep 81
If my wife is displeased... I know I'm doing something right. Thanks for posting progress!
chief1richard382.00 |
03-05-2021, 02:59 AM | #29 |
M///modifyer
2494
Rep 1,295
Couple of new weights of items I have fitted for the list (wasn't able to edit as it was in 'read only' format)...
Aluminium GTS hood : 9.9 kg Cobra Nogaro seats: 10.2 kg each (Carbon version are 5.3 kg each). Lithiumax battery: 3.3 kg.
www.tarmacperformance.com
Best Modified BMW - BMW Nationals 2022 |
04-24-2021, 04:02 PM | #31 |
Rep 579
Adding:
Headliner and related pieces - 10 pounds Side curtain airbags and a-pillar trim - 6.7 pounds Subwoofers - 7.3 pounds Kicking myself for not weighing my half-cage/rollbar before I reinstalled it after painting it. Guessing it was 50-60 lbs. |
Hawkdriver68.50 |
06-15-2021, 10:28 AM | #32 |
Yoda of mods
1676
Rep 3,006
Drives: X5 RWD
M2guru The speadsheet link didn't work for me.
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
06-19-2021, 06:30 AM | #33 |
Rep 579
06-20-2021, 09:36 AM | #34 |
Yoda of mods
1676
Rep 3,006
Drives: X5 RWD
06-20-2021, 04:02 PM | #35 |
Rep 527
Drives: 2020 F87 - M2 Competition
Any pics of the gutted interior? Crazy amount of work you've put in!
06-20-2021, 06:24 PM | #36 |
Rep 658
The problem of weight saving measures in the rear side of the car (antigravity battery, rear seat delete, etc) is that the rear end is struggling to find proper grip even being stock. And when you take off the weight from the rear the car will become even more unbalanced.
06-20-2021, 07:44 PM | #37 | |
Rep 427
06-21-2021, 10:20 AM | #38 | |
Rep 342
I tend to agree with Kart Driver here, not necessarily because of traction (managing weight shift and tuning suspension/tire can often resolve that) as in overall static balance—switching to a lightweight battery or a titanium exhaust back-box are pulling weight from where it has the most leverage and may not be as easy to compensate for with corner balancing. Unfortunately, it appears easier to remove weight from the rear of the car vs. the front where it may be more beneficial. |
06-21-2021, 12:41 PM | #39 | |
Rep 427
Agree an equivalent change in fuel weight probably has a different impact than the battery, exhaust, or a carbon trunk lid. Also agree there are a few more options to remove weight in the vicinity of the rear axle than the front, chasing the lightest weight possible is certainly shifting weight balance forward, but my point with fuel is that perhaps you gain more benefit toward lap time reduction with the lower weight than you lose by shifting weight balance forward. If balance were more beneficial than total weight, I’d expect nose heavy race cars would get ballast added (beyond what’s necessary to meet the class rules for minimum vehicle weight), but I do not believe that is the case. If anyone is aware of some exceptions, they would be interesting to hear about. |
06-25-2021, 09:28 AM | #41 |
Rep 753
Here's my thread around weight reduction and corner weights.
https://f87.bimmerpost.com/forums/sh....php?t=1819724 I don't plan to go as extreme as M2guru here, and am focusing on the "bolt on/bolt off" large weight reduction rocks with the M2. I am at 3370lbs with a full tank of gas and an empty car. Below is my list of mods so far and weight change estimates. The only other thing I'd like to do is an M Performance hood that I am hoping will be good for somewhere between 30 and 35 lbs reduction. And, at some point I'll get a carpet made for the rear seat base and remove that for a net decrease of around 10 more. And on track days, I usually run 513Ms which are around 12lbs lighter than the 437Ms. Akrapovic exhaust -10 Rear seat back delete -35 Recaro Sportster CS front seats -24 - VAC floor mounts for the seats - Recaro sliders Remove engine bay foam piece -4 - Replace engine cover with Turner carbon AntiGravity 60Ah battery -40 ER intercooler & charge pipes +14 KW Clubsport coilovers +4 Bigger PSS tires on 437M +6 |
inTgr8r2431.50 |
06-25-2021, 10:31 AM | #42 | |
Yoda of mods
1676
Rep 3,006
Drives: X5 RWD
