03-19-2022, 06:13 PM | #1 |
Rep 23
DONT wash driver side engine compartment on S55!!
Hello I recently installed the VTT crank hub on my M2 Competition and when filling the engine coolant it spilled and I figured meh not a big deal I'll wash it off. Unfortunately after starting car I had 5 codes all related to terminal 15 short to ground and O2 sensor heating short to ground or low voltage.
Turns out the ISM which is a junction box that houses terminal 15 which is located right by the coolant revisor is not water proof!! So it got fried. If you spilled water or coolant in this area and now you have these codes odds are the ISM is fried just like mine. It's super simple to install a new one and after doing so no more codes! Hope this helps anyone I'll attach a picture of the ISM |
13
chris7197378.50 MarlboroM2C238.50 bkishore771.50 jason.seki55.50 CSBM52756.00 RocketBoots1860.00 HazChem262.00 Moflow2484.50 m0g2446.00 Zuzu2826.50 Killed by Death12999.00 MooMooM21843.50 BMW DIY Guy3103.50 |
03-19-2022, 09:21 PM | #2 |
Rep 1,555
Good to know. Sorry you had to learn that the hard way.
Will Delarosa50.50 Moflow2484.50 |
03-20-2022, 10:34 AM | #3 |
Rep 2,104
Thanks for the tip!! I'll have to keep this in mind when I detail my engine bay.
03-21-2022, 06:08 AM | #4 |
7525
Rep 12,316
Did you spray directly into the engine bay, or were you misting it? I normally put plastic bags over items like alternators but most of the other cars have more room in the engine bay. This is good to know for sure though!
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
Will Delarosa50.50 |
03-21-2022, 01:02 PM | #5 |
Rep 23
Just did a quick engine bay spray down nothing high pressure and I never focused water on the electronic components especially in this section of the engine bay. Literally something I do all the time to other cars with zero problems definitely taking extra care in this section of the engine bay of this car moving forward
W///7525.00 |
03-21-2022, 01:42 PM | #6 |
Rep 170
Same thing happened to me while my mechanic did the VTT V2 crank hub, but I got different codes , disregard the fuel mixture codes as I'm in the process of tuning for e85 😂
03-21-2022, 03:09 PM | #7 |
Rep 23
Power management code tells me it definitely could be the same thing although you'd have to run further checks to see. I've hear of guys also getting a code that says battery discharging too quickly or something that was the same thing. As for the valve tronic codes I'm not sure if they are related. Did you replace ISM?
03-21-2022, 03:13 PM | #8 |
Rep 23
03-21-2022, 03:16 PM | #9 | |
Rep 170
03-21-2022, 03:18 PM | #10 | ||
Rep 170
03-21-2022, 03:19 PM | #11 | ||
Rep 23
03-21-2022, 03:21 PM | #12 | |||
Rep 170
03-21-2022, 03:31 PM | #13 | ||||
Rep 23
03-21-2022, 03:32 PM | #14 | |||||
Rep 170
03-22-2022, 07:24 AM | #15 | |
Rep 170
03-22-2022, 04:46 PM | #17 |
Rep 170
03-22-2022, 05:03 PM | #19 |
Rep 23
03-22-2022, 05:04 PM | #20 | ||
Rep 23
03-22-2022, 06:14 PM | #21 |
Rep 170
03-22-2022, 06:16 PM | #22 | |||
Rep 170
