M2 Technical Topics > Track / Autocross / Dragstrip > Schroth quickfit pro
      01-14-2020, 09:30 AM   #23
bentom2
Originally Posted by eeyang92 View Post
I just installed the quickfit pro, but I find that if I tighten the harness to a level that holds me in place, the center-lock rides way above the pelvis, directly over the belly-button And this is having the bottom two straps painfully tightened around the gut. With my HANS on, the issue is even worse since the device "raises" my shoulder height, bringing the center-lock even higher.
I'm considering purchasing the VAC anti-sub belt mount (https://store.vacmotorsports.com/vac...ket-p2106.aspx) along with the Schroth Profit anti-sub strap (https://www.schrothracing.com/products/anti-sub-straps) to help remedy this, but I'm sort of curious as to why, despite all of my research, I've never seen anyone complain about this? Hopefully I'm just doing something wrong
Are you cinching down the lap belt first, and then the shoulders? When I do the lap belt first, the belt stays on my hips. If I get lazy and try to skip loosening and tightening the shoulder belts, I end up in the same situation with the buckle up way too high.
eeyang92318.50
      01-14-2020, 12:16 PM   #24
eeyang92
Drives: LBB M2 LCI 6MT
Yes, although the shoulders weren't completely slack when I did that. I'll give it another try. Thanks for the tip
bentom2335.50
      01-17-2020, 01:18 PM   #25
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
Quick-Fit Pro
Went to HMS Motorsport today to check out this harness. They told me they are in the process of getting one tested and fitted for the M2. Should be out this year. Awesome selection of Racing seats and Track Equipment.
At a Point above 7,000 RPM.
      01-20-2020, 03:13 AM   #26
eeyang92
Good to hear - I can't imagine it is significantly different than the current one forum members have been using since it already fits without any modifications.
