11-07-2017, 10:22 PM | #1321 |
Rep 259
Does making the angel eyes 100% brightness really accelerate headlight cover yellowing? Heard this from another m2 owner
2013 MW E92 M3
2018 MG F87 M2 (Sold) 2016 YMB F80 M3 (Sold) Follow me on Instagram- @dtmpower98 |
11-08-2017, 01:34 AM | #1322 |
Rep 87
I just did it today including removing legal disclaimer and video in motion. I didn't run into any issue. I suggest putting your phone into airplane mode to reduce interruption while coding. Also, do the coding while your engine is running so that iDrive won't shut off in the middle of the process.
AndrewC198910931.00 |
11-08-2017, 07:43 AM | #1323 | |
Rep 2,948
The angel eyes are LEDs, they'll have little to no impact on the headlight covers. I have had mine cranked on my MY16 for well over a year now and there is zero evidence of any change. |
11-08-2017, 12:34 PM | #1324 |
Rep 5
I bought bimmercode software on iTunes and while I successfully coded some options I'm experiencing some problems with enabling wifi hotspot. I've searched the forums for a solution but can't find the answers. I have a 2017 F33 with id5 idrive and factory enabled Carplay. The wifi hotspot option was not on idrive menu nor was wifi on / off checkbox. I coded in expert mode wifi direct and Miracast then coded in expert mode all the WLAN parameters as active which allowed me to see the wifi check box but no wifi hotspot. I have now 2 wifi signals one is the BMW my7vin# Carplay and the other is Direct-3-BMW-my7vin#. I can now check and uncheck wifi using idrive but I can't get to the options menu on my idrive to show / change the wifi name or password. Whenever I click the options button on the center console I only get "split screen / turn screen off". No other options are available no matter which menu I'm in.
Is there a way to code it in bimmercode or am I missing something like software / hardware? I reached out to Stephan but he emailed back saying that he doesn't know why and I should ask forums. Anyone with the same problem? Anyone knows how to solve it? BTW I did some programming a while back and know how hard it can be to program without knowing the API or for that matter all of the parameters and their dependencies. Kudos to Stephan for getting us this far. |
11-08-2017, 03:16 PM | #1325 | |
Rep 4,551
Drives: 2015 328d xDrive
Either way, these failures are not common, and it could have been your fault so don't be so quick to point the finger at the developers. You should be coding with the car running and with airplane mode on, like the person above me stated. That being said, if you're uncomfortable using bimmercode because of the possibility of another failure like you experienced, you can always pay someone to code your car for you, or you can learn how to use E-SYS and do it yourself from a laptop. It's much safter since the connection physically exists through a wire instead of doing it over bluetooth or wifi where an interruption is more likely to occur. |
Volki_M216.50 NYC Bimmer259.50 |
11-09-2017, 04:09 PM | #1326 | |
Rep 251
BMW M2 2018 LBB
BMW X1 2016 PSM Audi S4 2014 SMG |
NO_USER_537.50 |
11-09-2017, 04:48 PM | #1328 |
Rep 251
My 2018 LCI has adaptive LED headlights but no cornering lights which I find helpful. Does anybody know if Bimmercode allow coding cornering lights?
BMW M2 2018 LBB
11-09-2017, 04:52 PM | #1329 |
Rep 1,608
Isnt the adpative feature of the LEDs the feature responsible for the lights cornering?
Boostm3
11-09-2017, 04:55 PM | #1330 | |
Rep 251
BMW M2 2018 LBB
11-09-2017, 08:06 PM | #1331 | |
Rep 1,608
"Adaptive headlights are an active safety feature designed to make driving at night or in low-light conditions safer by increasing visibility around curves and over hills."
Boostm3
11-09-2017, 08:12 PM | #1332 | ||
Rep 251
BMW M2 2018 LBB
11-10-2017, 06:22 AM | #1334 |
Rep 4
hey guys, just started using the bimmercode app.
Does anyone know if there's an option to permanently activate adaptive lights? Also is it possible to make the drivers side wing mirror tilt downwards upon reverse? |
11-10-2017, 06:22 AM | #1335 |
Rep 2,948
11-10-2017, 06:26 AM | #1336 | |
Rep 2,948
And yes, you can make the mirror tilt down and adjust the angle. Your car should already come like this from the factory - make sure your mirror select switch is set to the left (or maybe right...can't remember) so that it triggers it. |
11-10-2017, 09:36 AM | #1337 |
Rep 110
Apologize in advance if this was covered, Is coding possible to change the instrument cluster lighting?
More specifically, I'd want to do away with the orange and stick with the colors on the bottom, the (white/blue/red) colors look nice. |
11-10-2017, 09:56 AM | #1338 | |
Rep 4
Only the passenger mirror tilts on reverse which is what is normal, I'm trying to work out if the driver side mirror can tilt too. |
11-10-2017, 09:58 AM | #1339 | ||
Rep 2,948
I misread your mirror question - you cannot get drivers to tilt automatically, only passenger. |
11-10-2017, 11:12 AM | #1340 | |
Rep 630
Drives: 2021 G80 M3
11-11-2017, 12:31 AM | #1342 | |
Rep 5
Anyway why would you want to do this? You can easily change to any mode with the rocker switch. |
