11-23-2019, 05:35 PM | #1 |
Rep 330
Custom Drive Mode | Set Options Individually
Is there any way to set custom drive modes on the M2C?
I know you can set the M buttons, but I would like to be able to set the exhaust separately from the throttle response, separately from the auto rev matching . Example: Sport + exhaust Sport throttle No rev matching in MDM or full DSC On I guess I could get this done through custom programming, but I'm surprised there aren't options like this in iDrive. Other cars I've driven have these options built in. |
11-23-2019, 07:45 PM | #3 |
Rep 330
Thanks. That's what I thought.
On Audi/VW they have the presets similar to BMW, Normal, Eco, Race, etc...and then Custom. You can set: Steering Throttle Chassis (dampening) Exhaust sound DSC mode Pretty simple really. |
11-24-2019, 04:35 AM | #4 |
Rep 744
You can set the above to the M buttons
Only the M2CS has adaptive or variable damping For whatever reason BMW wont let you adjust the exhaust or auto rev mathc separably. I think the exhaust is a bit more complex than people think, my friend forces the valve closed using an app but it still opens the valves under full throttle.
smknjoe234.00 |
11-24-2019, 03:45 PM | #5 |
Rep 330
Yep. I'm aware of the static suspension. That was just an example.
I think you are correct about it being more complicated. At least with what's going on with the drive modes. For example, I notice the car runs warmer in Efficiency and Sport modes vs Sport +. I guess holding the DSC button down is "technically" an auto rev match off button. I'll just have make sure I'm not driving like a moron when I do that. Easier said than done sometimes. |
11-24-2019, 04:54 PM | #6 |
Rep 33
Drives: 20 M2C, 12 X5d
Garage List 2020 BMW M2 Competi ... [0.00]
2000 BMW M Roadster [0.00] 2015 Porsche 911 Ca ... [0.00] 2005 Porsche Cayenne [0.00] 2012 BMW X5d [0.00] 1987 Porsche 911 [0.00] |
If you adjust your timing, you can rev match no problem without any software override. It just requires that your rev match occur before you begin to enter the gate of the next gear. The nice part is if you under rev, the rev match will close the gap for you. Kind of like having a tutor. If you over rev, well, no help from rev match and you still have some technique to work on. In the old days of double declutch, you would perform the revmatch in the neutral gate. That is what i am currently doing. I may try adjusting my timing a bit to start the rev match as I begin to move out of the high gear. Not sure I love pausing in the neutral gate.
Moflow2484.50 |
11-24-2019, 05:10 PM | #7 | |
Rep 330
11-25-2019, 02:28 AM | #8 | |
Rep 744
You are correct on the cooling. Sport + hold oil at 105C and the other modes at 115C. This is done for efficiency vs. max cooling
11-25-2019, 03:31 PM | #9 | |
Rep 1,602
Usually i'm not giving it enough of a blip in neutral. I feel like NA cars always require smaller throttle blips for rev matching and after driving a 350Z for 13 years, my brain is always telling me to just barely tap the gas. My first car was a Celica All-trac from 1988, which was very old school in its turbocharging. I remember making 4-3 downshifts on that thing and actually briefly flooring the gas to blip the throttle properly. The M2 will just take some getting used to, but I do find the feature kind of obnoxious in the mean time. |
Thescout134947.00 |
11-25-2019, 07:46 PM | #10 |
Rep 330
It definitely requires an adjustment period.
There are different ways of doing it for sure. Blipping at the "top" of 4th (before moving into neutral) seemed most natural to me for a long time but it also seemed slower or required more throttle to keep the revs up before I got into 3rd completely. In my previous "fun car" I'd become quite adept at rev matching by blipping at the point just before letting up on the clutch and when I was already hitting/sliding into the 3rd gear. It felt more accurate, precise, and faster. Turning DSC off completely is fine for now when I'm just putting around practicing. Not sure I'll do it while on a "spirited" drive. |
Moflow2484.50 |
