05-29-2018, 11:04 AM | #155 |
Luxury at the redline :)
9105
Rep 7,563
They gave us bigger brakes to match a more potent motor at no added cost; I don't get what all the fuss is about.. I don't care if is needed or not - it's "free" #NoBrainer
05-29-2018, 11:21 AM | #156 | |
Rep 2,787
Repeated hard stops require both effective heat transfer and adequate thermal storage capacity within the disc. The more disc surface area per unit mass and the greater and more efficient the mass flow of air over and through the disc, the faster the heat will be dissipated and the more efficient the entire system will be. |
BAN_M2C4180.00 M3 Adjuster7905.50 |
05-29-2018, 12:20 PM | #157 |
Rep 3,842
If you don't like the brakes on the M2C because of caliper color or weight, trade them to an M2 owner. While you're at it, update the pads and change the hydraulic fluid. There will be a line of people waiting for that offer You might even make some money on the deal.
05-29-2018, 12:50 PM | #159 |
Rep 2,787
05-29-2018, 12:54 PM | #160 |
Rep 2,817
05-29-2018, 03:50 PM | #161 |
Rep 923
Any guesses how much the M Performance "BMW M Compound Brake Discs of the BMW M Sports Brake System Red" would be for a full front and rear kit?
05-29-2018, 04:33 PM | #162 | |
General
17488
Rep 25,114
My car made front page of Bimmerpost
05-29-2018, 05:15 PM | #163 |
Rep 2,787
05-29-2018, 05:32 PM | #164 | |
Rep 660
So this is more of a "side-grade", rather than a straight upgrade. If you find yourself in situations where you need the extra thermal capacity (and are willing to trade a bunch of unsprung weight and rotational mass for it) vs. cooling from ziptie-ing on brake ducts, then it may be worth the tradeoffs. Although I am a numbers guys... Would be nice to know how much more thermal capacity and cooling we're talking about! |
05-29-2018, 05:32 PM | #165 |
9105
Rep 7,563
JustChris17487.50 |
05-29-2018, 05:58 PM | #166 | |
7906
Rep 11,785
05-29-2018, 11:41 PM | #168 | |
Rep 650
eeyang92318.50 |
05-30-2018, 12:27 AM | #169 |
Rep 2,787
You improved air flow with your aero stoptech rotors. But your setup is still inferior to what you call "fat brake parts bin". First off the CCB calipers are some of the best calipers BMW puts on their cars. The 2NH rotors are one-off, as lemetier pointed out having different offsets. The standard brakes with no matter what rotor upgrade, is lacking friction surface area of the 2NH that incorporates larger rotors, larger pads and larger calipers. The increased surface area lends to greater heat capacity and an increased friction surface. Also increasing the diameter of the rotor increases the torque arm and increases the moment of torque for braking. It is like using a breaker bar for more leverage. 2NH owners will also have the opportunity to get lighter aftermarket rotors whether they be iron or carbon ceramic. The new brake kit will work well and I am sure M engineers that tested the car for over a year with the 2NH package will vouch for it.
05-30-2018, 01:43 AM | #170 | |
Rep 1,759
The only way I can get a multiplier of 2 or above is when the diameter of the rotor is 890mm (35 inches) or above. http://hpwizard.com/rotational-inertia.html (scroll down to the brake disc section and key in the numbers) The extra 2Kg in weight on each rotor doesn't amount to much overall weight even when rotational inertia is taken into account. Last edited by Karmic Man; 05-30-2018 at 02:02 AM.. |
CSBM52722.50 |
05-30-2018, 04:21 AM | #171 | |
Rep 245
Drives: M2 DCT MPerformance coilovers
https://www.essexparts.com/essex-des...87M2f80M3f82M4 I am running these calipers on my tarmac rally car and they have proven massively better than stock brembos (with race pads) and lighter too even though they are a larger caliper. |
05-30-2018, 07:55 AM | #172 | |
Rep 650
M3 Adjuster7905.50 OG///M1003.50 |
05-30-2018, 11:37 AM | #173 | ||
Rep 207
The general rule of thumb is fixed unsprung weight (e.g. caliper) has a 4:1 multiplier; while rotational unsprung weight has a 7-10:1 multiplier (many variables at play) in translation to sprung weight. Why else would you think some people shell out BIG bucks on CCB and CF wheels...
Gone but not forgotten:
'14 Corvette Stingray (2014-2017) '05 Boxster S (2005 - 2014) '00 S2000 (2000-2005) |
05-30-2018, 12:03 PM | #174 |
Rep 3,337
Those "rules of thumb" shouldn't even be called that as it does a disservice to the term.
Rotational inertia is easily evaluated and can easily be calculated in basic physics models like Cartest2000. I can quickly find out how much impact a change in wheel weight will have on an acceleration segment time for example. The actual changes are almost always far, far smaller than one would be led to believe by stuff you see posted online. If you want to compare what an added rotor weight will *actually* do on the car, it's a simple process to accurately estimate it. I was referring to people who are making wild claims about static weight comparisons to rotational inertia. Realize that inertial effects are 100% related to acceleration of the rotating mass. For acceleration, they are highest at the slowest speed, and something like accelerating from say 100mph to 120mph the difference in 15% lighter wheels might not even show up on the time segment. Acceleration is highest in 1st gear of course and falls dramatically as speed increases since the power to overcome air drag varies with the cube of velocity. In any event, the emotions and claims about relatively minor changes are off the charts in some posts compared to the physical reality. However, very few people are interested in the actual physics and actual unbiased data.
Current Stable:
bunnyhive55.50 |
05-30-2018, 06:42 PM | #175 | |
7906
Rep 11,785
I drove my car to a track event this past weekend.. .... drove my car hard Saturday am in two sessions with DSC off.. and very little squeal.. My GF drove the car two sessions that afternoon with DSC on and they began squealing like a stuck pig (on track even!) and when I drove back to the hotel even the lightest touch of the brakes made a loud squawl. The next day I drove on track with DSC off on Sunday and cleaned them up again and the squeal went away mostly... just in time for the trek home thankfully. I agree with your comments. With regards to HAWK vs PF-C brake pads.. Hawk is the KING of initial bite. If you want LOTS of braking force at the moment you hit the pedal.. then Hawk Pads are for you. Many people get addicted to this initial bite.. Once you go Hawk.. you probably won't go away from them. However... I personally prefer a pad with torque characteristics that give MORE torque the harder you push the pedal.... not just a bunch of torque on the initial press.. For me... when I am braking on track...I want the pads to have good initial torque... and *more* torque when I need more braking force. In other words... if I have made my initial braking effort.. and realize.. OH CRAP.. I need to brake even harder.. I want my brakes to work even harder too. So.. while some prefer more initial torque.. .. no way man.. I want brake torque equal through the travel.. or.. more brake torque the harder that I push the pedal...... I am an Performance Friction fan all the way and have been for two decades or more. Another good pad with torque characteristics that are steady through the pedal travel is Ferodo. Last edited by M3 Adjuster; 05-30-2018 at 06:49 PM.. |
05-30-2018, 09:28 PM | #176 | |
Rep 1,759
A increase of 2kg on the rotor does not equate to a increase of 2x9 = 19Kg on the weight of the car as you claimed from a multiplier of 9. Using their calculator it is an increase of less than 4kg (per rotor) on the overall weight of the car. A multiplier of less than 2! |
