M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Diverter Valve Upgrade Chuchuchu
      05-21-2020, 05:36 PM   #45
Spartan King
MOLON LABE
Spartan King's Avatar
80
Drives: BMW M2 LCI
Originally Posted by Endeav View Post
Great review. I'm going to be switching from the DV+ to the VR11 plumb back model in the next couple days here. Just trying to decide when I want to subject myself to the frustration of that install hahaha.
Yeah I have no idea how this could be done easily without a lift. I have a mechanic local to me that I only trust to work on my car. I watched him do most of the install, and realized I made the right choice letting him deal with it.
      06-09-2020, 05:32 PM   #46
3t3p
New Zealand
455
I like the look of the turbo smart, was going to go DV+ originally but this is the more complete solution it appears.
I'm going to get it installed for me though as can barely do half beer car jobs!
Wattens59.00
      06-09-2020, 07:53 PM   #47
ZM2
Drives: 2017 LBB M2
Got mine installed today, along with the Pure Turbo Inlet and Wagner Evo3 Comp.
Throttle response/lag is definitely better, but no idea which of those parts is helping the most.
Bee Pee1783.50
Wattens59.00
      06-11-2020, 01:33 PM   #48
Bee Pee
Bee Pee's Avatar
1784
Drives: AW M2 DCT
Evo3 will be making throttle response worse so it be DV and inlet upgrades combined 😉
Current '22 X3M LCI..
Wattens59.00
      06-11-2020, 01:44 PM   #49
ZM2
Drives: 2017 LBB M2
Originally Posted by Bee Pee View Post
Evo3 will be making throttle response worse so it be DV and inlet upgrades combined ��
IDK, Wagner shows the Evo3 has less pressure drop, and a Wagner rep confirmed it to me: https://www.wagner-tuning.com/produc...0001144-4.html
I think it's b/c they enlarge the IC inlet/outlets and provide their own larger pipes to go with it.
      06-11-2020, 01:48 PM   #50
Bee Pee
Bee Pee's Avatar
1784
Drives: AW M2 DCT
I think it's b/c they enlarge the IC openings and provide their own larger pipes to go with it.
Interesting.
Larger bore is for cold outlet only ?
Hot inlet side uses same sized coupler as stock ?
      06-11-2020, 01:59 PM   #51
ZM2
Drives: 2017 LBB M2
Interesting.
Honestly can’t tell you for sure, but if you want to reduce pressure drop increasing the outlet of anything always has more impact than increasing the inlet.
      06-11-2020, 02:13 PM   #52
Bee Pee
Bee Pee's Avatar
1784
Drives: AW M2 DCT
Interesting.
Honestly can't tell you for sure, but if you want to reduce pressure drop increasing the outlet of anything always has more impact than increasing the inlet.
Looking at the pictures on Wagner link you sent - silicone bottom half of CP has reduction in ID to suit what looks standard ID of top half of CP to TB connection....
      06-11-2020, 02:41 PM   #53
ZM2
Drives: 2017 LBB M2
Not sure I follow all that, but from the description:
“The stock click connections have been eleminated and increased to a connection diameter of Ø65mm/2,56Inch for inlet and Ø76mm/3Inch for outlet, so this kit comes with reinforced silicone hoses as well as 3 aluminum chargepipe.”
What do you think?
      06-11-2020, 02:45 PM   #54
Bee Pee
Bee Pee's Avatar
1784
Drives: AW M2 DCT
"The stock click connections have been eleminated and increased to a connection diameter of Ø65mm/2,56Inch for inlet and Ø76mm/3Inch for outlet, so this kit comes with reinforced silicone hoses as well as 3 aluminum chargepipe."
What do you think?
Throttle body end is 3" connection.
Looks like CP silicon and hard pipe sections are less than 3"dia
3" outlet from IC surely would only bring a benefit over competition if the evo 3 CP was constant 3" ID too ??
Does Evo 3 install involve mods oem bracing ala Dinan cooler ?
      06-11-2020, 02:53 PM   #55
ZM2
Drives: 2017 LBB M2
No idear. You guys know the details like this better than I do.
All I know so far is throttle response is better, but could be more from the TS BOV and Pure inlet pipe, and IATs are better than Evo2--more data coming on that.
What's the stock IC outlet size and diameters of the typical aftermarket charge pipes?
You do have to change to the M235i radiator v-brace, and we cut the ends off the bottom sides of my M2 brace to get additional bracing to the bottom two bolt locations on each side.
GerardzM and I have an Evo3 specific thread going here: https://f87.bimmerpost.com/forums/sh....php?t=1727351
Bee Pee1783.50
      07-01-2020, 06:02 AM   #56
widetyres
280
Drives: M3 E92 DCT, 2012
Originally Posted by tenkies View Post
I ordered mine through TougeFactory If you need a US shop.
Mine just shipped at a good price.
Originally Posted by Drop the hammer View Post
Will log it again after installation to see how it affects things.
Originally Posted by Wattens View Post
I've got some logs from BM3 but not sure which logs would be related to the BOV performance?
Originally Posted by Spartan King View Post
I just had my Turbosmart VR11 Plumb back installed today along with a Pure high flow inlet pipe.
Hi All,
If you can, please can you post a log with your VR11 installed? - it would be great to see what differences it is making to boost during gear shifts.
Ideally a log with shifts less than 5.5K RPM, as well as those higher in the rev range.
Thanks in advance,
WT
      07-01-2020, 08:08 AM   #57
ZM2
Drives: 2017 LBB M2
Originally Posted by widetyres View Post
Hi All,
Thanks in advance,
WT
I have some logs posted in the Evo3 and HPFP threads. Good luck figuring anything worthwhile out.
I finally heard the fluttering sounds some guys have mentioned. Very faint and only heard when going slow around town with the radio off. Not annoying at all, just a new, different sound.
widetyres280.00
      07-02-2020, 07:48 AM   #58
widetyres
280
Thanks for the info re the logs.
Although they didn't have the sub 5.5K gear shifts, they did provide what I was looking for to compare how the DV holds boost.
From my logs (stg 2, but with OEM DV), I see PSI drops as follows:
1 second after throttle let off: 5.9psi
2 seconds after throttle let off: 2.7psi
3 seconds after throttle let off: 2.5psi
after this, the PSI slowly drops to virtually nothing (0.2PSI)
From your logs with the TS DV:
1 second after throttle let off: 6psi
2 seconds after throttle let off: 3.5psi
3 seconds after throttle let off: 3.2psi
after this, the PSI goes down super slowly, levelling at ~2.2PSI
So for me, the benefit that the TS DV will give to responsiveness following gearshifts looks to be small. However, there is some benefit to responsiveness on-off the throttle.
Bee Pee I know that you are running the GFB DV+, please can you share a log of that for comparison? It'd be interesting to see what that large spring in the kit is doing in terms of holding PSI.
Cheers,
WT
      07-02-2020, 10:44 AM   #59
ZM2
Drives: 2017 LBB M2
Cheers,
WT
Keep in mind that I’m DCT.
      07-02-2020, 11:30 AM   #60
widetyres
280
Good shout - thanks for clarifying.
It would be good to see logs for a manual for sure, but the DV should be operating in the same way. The above is consistently seen across your logs where you let off the throttle, and is very similar to mine, except for the differences noted that must be due to the DV. Could be wrong, but I believe for that second or two after accelerator lift, the engines in both DCT and manuals should be working way in terms of boost management.
      07-25-2020, 09:59 PM   #61
AmuroRay
AmuroRay's Avatar
2335
Drives: M235i
Any logs?
Tags
diverter valve, dv+, n55, turbosmart, vr11
