06-08-2020, 11:47 AM | #111 |
Rep 42
You can go to aircraftspruce and get the 2.5" flange, use a holesaw to cut a hole in stock backing plate and then rivet the flange in. Then in winter just remove the ducts and hoses if you want.
I like this solution a lot. Looks like it may be more effective than the Porsche ducts to me. Great job Magnus. |
06-09-2020, 01:29 AM | #112 | |
Rep 744
I remixed your scoop to go directly to 76mm. My printer is being an A hole though and having trouble with such a long print.
06-09-2020, 05:05 AM | #113 |
Rep 624
That is odd, my Lightweight backing plates came with 60mm hoses!
07-29-2020, 09:34 AM | #114 | |
Rep 744
https://55parts.de/collections/m-mod...bremsbeluftung and started printing in ABS which made all the difference! Pics are thanks to Kankles who is running the 1st protos. These work with 18" wheels
07-29-2020, 02:09 PM | #117 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
These carbon shields are smaller than stock and have the hose port. Not sure which would keep brakes cooler, this set up or just running no shield.
07-30-2020, 01:31 AM | #118 | |
Rep 744
I also plan to make some air deflectors for the rear brakes. Like the GT3 scoops used in DE.
Kankles1484.50 |
07-30-2020, 05:40 AM | #119 | |
Rep 624
Nice :-) The Lightweight shields are quite different in design on some details, so these you got are from some other manufacturer, but yours look very very well done :-) |
07-30-2020, 01:41 PM | #120 | |
Rep 744
08-20-2020, 10:44 PM | #121 | |
Rep 468
08-28-2020, 02:36 AM | #123 |
Rep 744
Here is a write up of my results with my scoops
https://f87.bimmerpost.com/forums/sh...&postcount=159
08-28-2020, 06:38 PM | #124 |
Rep 660
08-29-2020, 03:13 AM | #125 |
Rep 624
The heat is no problem. But I agree 100% that aluminium shields are absolutely as good and much cheaper. I doubt there is any weight saving whatsoever compared to a very thin aluminium shield. But I got these for a very very very good deal.
08-29-2020, 05:31 AM | #126 |
Rep 744
Same for me, the CF ones ended up being cheaper than any metal ones on offer.
They also blew air into the hat more than any of the other designs and retained most of the backing to protect the susp. Bushings. Not worried about the CF catching fire. If that happens you probably had way worse problems going on. CF also does not ignite that readily from my quick search. |
08-29-2020, 03:12 PM | #127 | ||
Rep 660
09-03-2020, 07:32 AM | #128 | |
Rep 670
There is a very similar part for a Camaro for the same function. A bit cheaper at $18 for a pair. https://www.gmpartsgiant.com/parts/g...-84145204.html
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
03-30-2021, 03:29 PM | #129 | |
Rep 126
Never had issues on or off the track with any negative effects. Easy mod that takes no time and cost zero. There was a Company in Europe that measured Caliper temps after track sessions before and after removing shields from an M2 and the difference was in the 60C range (If memory serves). Unsure how scientific that test was but at least a data point to consider.
---2017 White M2 - Zero Option- 6-Speed Manual---
H20neun114.00 |
04-01-2021, 01:39 AM | #130 | |
Rep 744
And holy crap ppl are making fake endless brake pads now ?!?!?! https://trackparts.ch/Endless-Bremse...ngen-im-Umlauf EDIT: I always heard the dust shields also work as heat shields to protect suspension components. Did you ever notice any accelerated wear?
04-05-2021, 04:40 AM | #131 | |
Rep 89
what is that part initially good for and did anyone remove this as well? |
04-05-2021, 06:28 AM | #132 | |
Rep 744
I did not remove it as my brake scoops are lower and this does not impact the flow to them. I did remove the 2nd further forward lip (M2C has this not sure on OG) as I needed to for my chin spoiler. I think most lip spoilers are deeper and block these guys anyways.
H20neun114.00 |
