09-14-2021, 06:46 AM | #23 | |
Rep 76
Tbh the Ohlins weren’t as much as you’d think, not sure what the retail will be as mine were the development set. |
09-14-2021, 06:49 AM | #24 | |
844
Rep 1,962
https://f87.bimmerpost.com/forums/sh....php?t=1775848 |
09-14-2021, 03:03 PM | #25 | |
Rep 76
Yes there is some data on spring rates in this this thread…However as rightly mentioned spring rates in itself is subjective as it’s all dependent on the application and user as to what spring rate is “best”. The ethos behind the kit that Omnium Racing have developed is exactly as per the above…develop the Coilover dependent on the application the customer requires (in my case mostly track) and not only spring rates but pair with the appropriate valving based on the spring rate, desired ride height etc. I’m still struggling to grasp your overall point tbh, would you be happy if you had the spring rates I’m using? How would that help you given spring rates is only very a small part of the overall package and is customisable depending on objective. Again it’s ironic given you’ve bought some coilovers where the manufacturer wont directly tell you the spring rate you have, yet you bought them anyway… |
09-14-2021, 04:49 PM | #26 |
844
Rep 1,962
Good Spiel Love the bad-mouthing.
My point was to understand in what way the MPS didn't meet your requirements based on the settings you used vs those recommended. As I mentioned earlier, I find the MPS are better than stock, but not perfect. Hence, in what way is your new set up better, in terms of quantitive improvement and/or subjective feel? Yes, they look fab, but that's not what I asked. Please go back and try to read my original post as something other than a personal attack. Or don't - if the intent was purely to promote product. HTH |
09-15-2021, 01:25 AM | #27 | |
Rep 76
If you read my original post I thought I’d been pretty clear in explaining both subjectively ( improved feedback/feel, body control, damping across bumpy surfaces, compliance over harsh bumps) and objectively (lap times). Am happy to elaborate further? They say a picture says a thousand words so here are a few thousand words about what I thought could be improved when pushing on track with MPS Last edited by Juliana19; 09-15-2021 at 01:35 AM.. |
09-15-2021, 03:06 PM | #28 |
844
Rep 1,962
Okay, so: for your use case, the front springs are too soft, and upping the compression to try and support the front of the car under braking and on turn in resulted in it bouncing on the tires (I'm guessing - based on your earlier description) over bumps/rumble strips. The rear is also looking comically underdamped on rebound.
Noting that my original question was what settings did you use compared to the recommended track settings, it appears that stiffer front springs would have been the first thing to try (along with less compression damping, and more rear rebound). So, in the pictures, what settings were you using? That's my "point" as you put it. Glad the Ohlins and springs have sorted the shortcomings though. For reference, I bought MPS as it allowed me to retain the BMW Warranty, and I made the assumption that they would at least be on a par with KW V3 (for which data on spring rates and damping performance exists). For the type of road driving I do they are better than stock. The bit about the personal attack was that you appeared to think what I asked was just that. HTH. Last edited by M Fifty; 09-15-2021 at 03:16 PM.. Reason: Repetition |
09-15-2021, 05:06 PM | #29 |
Rep 658
What is the difference between these 3 options?
1) Ohlins R&T 2) KW V3 or M Perfomance 3) KW Clubsport Do I understand it correctly, that KW Clubsport are better than Ohlins R&T for track use? Is KW Clubsport good for road use? Or are they significantly less comfortable in comparison to KW V3 / MPerfomance? Or it is not the case? I am pretty happy with my MPerf on my M2C, but I am considering to buy coilovers as well for my M2CS and just hesitating which way to go. |
09-15-2021, 05:22 PM | #30 |
Rep 658
It is interesting that the KW V3 is the most expensive option among Billstein, Nitron and Ohlins.
https://www.litchfieldmotors.com/bmw...ling-upgrades/ I presume more expensive means better? |
09-15-2021, 06:50 PM | #31 | |
844
Rep 1,962
09-16-2021, 02:11 AM | #32 | |
Rep 76
Having done quite a bit of research into spring rates and alternative set ups before settling on custom Ohlins one of my takeaways was not too focus just on spring rates as it’s the combination with damping that really makes the difference especially on bumpy/undulating tracks (Oulton is my local), hence why I was nervous to start swapping springs on the MPS dampers for far stiffer springs (which was my original plan). Either way happy with what I’ve ended up with and they didn’t break the bank… They are not KW Clubsport, Ohlins TTX or Nitron R3 money put it that way… |
09-16-2021, 04:30 AM | #34 | |
Rep 76
Have some experience with KW Clubsports on an e92 and they are a good set up but primarily aimed at track use. Depending on budget Be worth looking at Nitron R1s and also recommend speaking to Omnium about retail prices for a custom Ohlins set up as in my experience it’s a good compromise between R&T which is largely focussed on mostly road use and track. Plenty of options out there. |
09-17-2021, 07:19 PM | #35 | |
Rep 658
Just an update. Spoke to the guy, who has a shop for servicing road legal and racing cars at Nurburgring. His answer is as follows: - KW is rubbish given that they do for the past several years - Nitron is better but far from being great - Ohlins is the best choice. Best perfomance, top quality. Ohlins R&T: way way superior to KW V3. Price: around 4000 euro Ohlins TTX: the best option money can buy. Price: around 8000 euro. |
09-19-2021, 06:32 AM | #36 | |
Rep 566
On a more serious note, some of the hardcore Porsches and BMWs came fitted with KW Clubsport and/or Ohlins TTX. Not sure if anyone called them crap. There are options out there. Quite a few variables when leaning toward a certain option. |
goforwand68.00 |
10-10-2021, 04:47 PM | #38 |
Rep 139
OP, I’m glad you found a suitable coil over for your needs.
I think some people have been a little harsh in their comments about the benefits of a custom Ohlins strut being better than the MPS suspension; the latter while being good for some circumstances, doesn’t excel in daily road manners, or give ultimate control at the track as the springs are too soft. I’m not familiar with Omnium Racing, but I did see someone wearing one of their fleeces in one of the recent videos for Gordon Murray’s new supercar. If you’re a consultant to an OEM manufacturer, that carries significant weight in my book. |
10-12-2021, 03:48 AM | #39 | |
Rep 76
Good spot! The chap who runs Omnium Racing is a senior engineer on the Gordon Murray T50 Project so safe to say he knows a thing or two! |
11-16-2021, 12:42 PM | #41 | |
Rep 80
It's much more than turning knobs and spewing our arbitrary spring rates. People would much rather be sold a lie, under the illusion of choice, than to be shown a solution with objective proof behind it. Damper dynos will only shed light on a portion of the whole story.. Just know there's a real method to his madness, and I hope to learn more from Farkle in the future |
12-02-2021, 10:04 AM | #42 | |
Rep 76
12-02-2021, 10:49 AM | #43 |
Rep 3,535
Actually it says please don't "PM" me because otherwise I'm inundated with requests for free private consultations. You should really see all the technical info I've posted in the open for the F-chassis that gives looks into things that nobody else will give you for free...
12-03-2021, 02:33 AM | #44 | |
Rep 76
It's great having lots of technical data but in reality we drive cars on the track not a spreadsheet and the car is objectively quicker (measured via laptimes from different drivers), having done 18 trackdays this year (so far) I'd say I am suitably qualified to have an opinion without having access or understanding to low level detail of damper dynos etc. If you give Omnium Racing a follow on insta he has done some videos on the philosophy and technical details of building custom Ohlins kits which may help. |
Bee Pee1772.50 |
