07-06-2017, 12:03 PM | #793 |
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
I've set my car to ID6 lite, but unless I'm not seeing it, all my car GFX are still the 2 Series. Which screens are you seeing the 5 in?
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
07-06-2017, 02:55 PM | #794 | |
Rep 105
07-06-2017, 04:00 PM | #795 |
484
Rep 821
Hmm, I'll check next time i get in and let you know.
07-06-2017, 06:15 PM | #796 |
Rep 7
I'm having the same issue. I sent logs and email to support on the 28th and the developer replied back saying it was a bug and he would send out an update the following day. I haven't seen an update yet, but maybe it's still tied up in apple approval process.
07-07-2017, 10:47 AM | #797 |
Rep 7,594
Drives: '19 M2C
Did you find/get this to work?
www.ReTuneTheDeTune.com
07-07-2017, 11:26 AM | #799 |
Rep 7,594
Drives: '19 M2C
monkiboy534.50 |
07-08-2017, 03:04 PM | #802 |
Rep 59
I don't believe there is a current gear coding option for the 6MT at least. There is only the gear indicator that suggests what gear you should in if you want to save gas....which is next to impossible with this car. : I'm almost always a gear or two lower than what it suggests.
LA_M217.50 |
07-10-2017, 05:17 PM | #803 | |
Rep 52
dj202093.50 |
07-10-2017, 07:10 PM | #804 | ||
Rep 29
ASD
Thanks, Gary LBB M2 |
07-10-2017, 08:38 PM | #805 | |||
Rep 7,594
Drives: '19 M2C
07-10-2017, 10:23 PM | #806 | |
Rep 278
According to this post: http://f80.bimmerpost.com/forums/sho....php?t=1122306 All you have to do to get it back on via the app is to change the value for model range from F20/F21 (ASD off) to F87 (value for an M2). |
07-11-2017, 04:59 AM | #807 | ||
Rep 29
07-12-2017, 08:02 AM | #808 |
Rep 9
Came across this here:
Its an coupon code how to ( posted by an forum member ) that shaves off 5$ on every carly adapter order placed over amazon. I tried it and it worked perfect ( basically just an copy and paste) Heres an coupon code for the carly obd adapter wich shaves immidiately 5€ off from your amazon order, if you do it as following: 👇 BEFORE you place your amazon order , send this 5 € coupon code 4ZECQD to trainer@mycarly.com Explain in your email from wich amazon you'd prefer to order (US/UK/Canada/UAE) Then wait for Carlys reply containing your "special" 5€ coupon code. |
07-12-2017, 09:54 AM | #809 | |
Rep 2,148
Drives: F87 M2 BSM MT
The recommended adapter for BimmerCode is so much cheaper and works perfectly fine
07-12-2017, 11:10 AM | #811 | |
Rep 2,948
Bimmercode specifically states you should get the vGate. There's a reason for that (compatibility and drop-out during coding) and also it's cheaper than whatever spamming code you're trying to get us to use. |
07-12-2017, 11:51 AM | #812 |
Rep 943
Drives: 2012 328i Modern Line
I just bought the vGate icar2 adapter...need to try it out. Is there a preferred iOS app for monitoring car info like Torque on Android?
:wave:
