02-29-2020, 04:51 PM | #1 |
Rep 95
Normal tire wear?
Just checking... is this cracking on the center of my tread in the front tires normal after 2000 miles of fun ?
02-29-2020, 06:13 PM | #3 | |
Rep 95
Is it cosmetic or is this damage? What pressure range is recommended for spirited driving to avoid this? |
02-29-2020, 06:43 PM | #4 |
Rep 6,937
Drives: 2018 M2 AW DCT
In the center I would treat it as cosmetic damage. Recommended pressure is 35 psi all around. You can see you tire pressure in the idrive menu under vehicle status.
SFM2C6MT175.00 |
03-04-2020, 02:46 AM | #6 |
Rep 95
Checked the tire pressure tonight while on a road trip at highway speeds. Found 37-39 psi pressures. Clearly this confirms the overpressure that was suspected?
I'll check it cool and take a few psi out. |
03-04-2020, 03:07 AM | #7 | |
Rep 1,899
But yea check cold tire pressure with an accurate handheld gauge |
03-04-2020, 03:08 AM | #8 | ||
Rep 95
03-04-2020, 03:42 AM | #9 | |||
Rep 1,899
03-04-2020, 09:14 PM | #10 | |
F80_Katz
764
Rep 440
Drives: 2020 M2 Competition
My Cup 2's looked similar after a track day. |
SFM2C6MT175.00 |
03-05-2020, 08:49 AM | #11 |
Rep 542
Over inflation would cause less tire roll? Looking at the OPs upper sidewalls and outer tread I would say they are under inflated? That is some pretty aggressive tire roll IMHO.
03-05-2020, 09:39 PM | #13 |
Rep 391
Couple of pics of mine. Pss after track day three 20 minutes sessions. And my brand new Re71r’s after autocross day of 6 runs at 55ish seconds each.
17 M2 AW, DCT, black grills, eventuri, bm3 Stg 2, csf intercooler, Fabspeed sportcat, AA charge pipe, 285r/265f pss, 285/30r18 re71r’s square apex 10x18, and smooth riding TC Kline coil overs with a very heavy throttle foot.
03-07-2020, 07:34 PM | #14 |
Rep 1,092
This is what I use and I'm very happy with it - https://www.amazon.com/Joes-Racing-3...dp/B00404WDUC/
Most gauges will be 0-100PSI so this 0-60 gives you more precision. |
