M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > BMW M2 in BSM receives a New Car Prep/ Xpel Paint Protection Film / Nanolex SI3D
      04-24-2016, 12:28 AM   #1
Detailers Domain
Detailers Domain's Avatar
Drives: 20 M2C / 22 X3MC
BMW M2 Black Sapphire Metallic receives a New Car Prep/ Xpel Paint Protection Film / Nanolex SI3D
Detailer's Domain documents the first BMW M2 to receive New Car Prep/Xpel/Nanolex SI3D
We were very excited to get our first BMW M2 in BSM in for an extended amount of work.
The scope of the work included - new car prep, Xpel Ultimate Paint Protection Film, and Nanolex SI3D Ceramic Glass Coating.
The services above would provide protection from rock chips and road debris, as well as a durable long lasting shine.
Most will ask why would we need a "new car prep" when my car is new....hopefully the below will answer some of your questions.
What is new?
We consider a new car is new up from 50-100 miles or 1 month after purchase.
What is done?
  • Remove any plastics or wrappings from the factory
  • Remove any existing transportation/storage dirt without marring or scratching the paint
  • Remove surface contaminants ie:leftover adhesive, tree sap, traffic film, rail dust, overspray, etc.
  • Bring out the full potential of the paint by increasing gloss and smooth paint surface
  • Provide a durable protection of the exterior surfaces using high quality sealants or coatings
  • Provide a professional inspection of your vehicle's paintwork
What to look out from the dealership.....
  • The products used are not necessarily the best available for your car
  • The work is likely to be done by "detailers" who don't have the training or equipment
  • Lack of training can lead to subpar results or even worse swirls/burnt paint/holograms
  • Shortcuts due to time constraints will cause dealerships to rush a job and steps maybe skipped to complete the car
Paint protection films are clear or colored polyurethane films that are applied to vehicles to protect them from scratches, dents, or swirls caused by road debris, rocks, bug droppings, and other environmental elements.
Conventional paint protection films can show scars and yellowing after a single year of use—especially in the real world, where most of us drive every day.
Constructed from a combination of advanced elastomeric polymers, XPEL ULTIMATE’s special clear coat not only prevents the film from discoloring due to contamination and ultra-violet radiation, but also heals itself from swirl marks and light scratches that can occur through ordinary washing and drying or daily driving.
Contaminants like bug splatter, bird droppings, sap and road tar wipe off XPEL ULTIMATE’s super-slick surface with a cloth, while scuffs and light scratches in the surface of the film disappear within minutes in the heat of the sun or the warmth of your garage—leaving your car pristine and the protective film like new.
And this level of protection comes without compromise. The mirror smooth finish of XPEL ULTIMATE ensures that no unwanted texture, commonly referred to as “orange-peel,” is added to the appearance of your car, leaving the protected surface indistinguishable from the factory paint. Professional installation by one of our network of factory
trained installers ensures exact alignment around surface features such as air inlets, parking sensors, headlamp washers and other design elements, while the film along the perimeter of each panel is wrapped around the edges for a truly invisible barrier against the hazards awaiting you on the road.
Even the film’s adhesive is superior. The enhanced workability of XPEL’s adhesive allows the film to be contoured around the most complex surfaces without distortion—which means you show off a perfect finish, not seams, wrinkles, and ripples. XPEL ULTIMATE also comes with a full 10-year warranty against yellowing, discoloration, peeling, cracking and hazing. If it fails, we’ll replace it—labor included
Coverage on the BMW M2 (we custom called out edges and removed items for our personal touch to provide less seams)
Nanolex SI3D - Glass Coating/Ceramic Coating/Nano Coating
Based on its unique Si3D technology, Nanolex Car Care offers a range of products specifically developed and designed to fulfill the highest demands and needs of our professional customers.
The Si3D molecules - precursors of ceramic and hybrid materials - consist of silica, nitrogen, hydrogen and organic compounds such as carbon. These high-performance polymers are all solvent and fluorine free.
The additionally-implemented thermoplastic component forms an incredibly hydrophobic, flexible, cross-linked matrix to give an outstanding hardness and durability.
Nanolex Si3D is extremely weather and chemical resistant, which in turn provides excellent corrosion protection with easy-to-clean-properties.
Si3D can also increase the total hardness of the paint to up to 9H+, adding a clear coat with a color-darkening effect to the treated surface.
Depending on the number of applied layers of Si3D, the thickness of the coating can vary. The coating thickness, combined with the sophisticated structural nature of the Si3D matrix, make the coatings resistant to abrasion caused by frequent washing and also unaffected by most chemical substances.
An important part of automotive coatings are solvents. The liquid consistency, viscosity and volatility of the product is highly dependent on the used solvents. Nanolex Car Care do not incorporate any aromatic solvents in their product formulations, due to the high potential of ‘hazardous-to-health’ character, thus making them safe use in an enclosed environment.
The Si3D coatings have very good ‘solvent release’ properties - about 90% of the solvents will evaporate during the first 24 hours, with the remaining 10% evaporating within one week. Please take note that solvent evaporation is also greatly dependant on temperature and weather conditions.
Unlike traditional protective coatings such as car wax and conventional polymer coatings, where the protective efficiency decreases with time, and from using degreasing or alkaline detergents, or because of mechanical removal, Nanolex Si3D coating exhibits outstanding durability and a tough insensitivity to abrasion from frequent washing and the use of strong alkaline or acidic detergents.
With proper maintenance Nanolex Si3D will have a durability of approximately 30000 km on the surfaces it was applied to.
Nanolex Si3D was developed, tested and manufactured in Germany.
Full list of products used during the new car process
Exterior
Nanolex Prewash Concentrate
Nanolex Wheel Cleaner and Iron Remover
Stoner's Tarminator
Nanoskin Autoscrub Sponge
Uber Clay Bar
Nanolex Ultra Glass Sealant
Nanolex Glass Cleaner
Meguiar's M101
Meguiar's M205
Nanolex Tire and Trim Restorer
Nanolex SI3D Pro Installed Product
Interior
Nanolex Interior Cleaner
Nanolex Textile and Leather Sealant
Tools used:
Metro Vac N Blo Car Vac Pro Series PRO-83BA CS
Metro Air Force Blaster 8 hp
Rupes LHR15 MKII
Rupes LHR75E
Meguiar's Microfiber Cutting Disc
Meguiar's Microfiber Finishing Disc
Uber Green Foam Pad
Uber All Purpose MF Towels
Uber Classic MF Towels
Uber High Tech Glass Microfiber Towels
Scangrip Multimatch Light
Brand new BMW M2 received in
Prep - Wash/Decon/Clay/Wheels
Loving our new favorite wheel cleaner and iron remover - works faster, better coverage, works on paint as well as wheels.Nanolex Wheel Cleaner and Iron Remover
Nanoskin Autoscrub Pad used on the paint as well as glass - clay not shown but used to hit some of the tighter areas.
Drying
Full house at shop - lots of M cars here
Factory grills, Roundel, and Side gills removed
Clear Film actions shots
We called out as many edges out as we could wrap for a close to seamless install
The shot that was discussed about, removal of the side gills for that clean install.
Film installed
Putting it all back together
Installing the black side gills
Installing the black kidney grills
The BMW Roundel goes back into place
Polishing out the paint to bring out the gloss and shine
When inspecting the paint we found a lot of isolated scratches, marring etc.
After compound and polishing
Some great results!
After Polishing we prepped the paint for Nanolex SI3D
Final touches
Tires were cleaned and dressed
Stoner's Tarminator to remove the dealership installed tire dressing.
Nanolex Tire and Rubber Restorer
50/50 shot
Nanolex Tire and Rubber Restorer leaves such a great finish.
Engine Bay
Afters
Interior
Exterior
Hope you enjoyed this article as much as we enjoyed working on this new BMW M2!
Email us if you have any questions or comments.
Phil@DetailersDomain.com
Appreciate 16
      04-24-2016, 05:09 AM   #2
Bmwhocr
Bmwhocr's Avatar
92
Drives: F80 AW M3 | NB Miata
Wow, looks amazing. Good job!
How long does xpel last and how much is it to install?
      04-24-2016, 05:32 AM   #3
Pol
Pol's Avatar
Belgium
1117
Drives: M2 CS BMS DCT August 2020
Fantastic job and ditto sport!
      04-24-2016, 06:15 AM   #4
///M2-PILOT
M2 PILOT
///M2-PILOT's Avatar
Drives: 2016 ///M2 HEA LBB M-DCT
Beautiful!!!!
///M2 - LBB - EXEC - M-DCT
Appreciate 5
M2Cnme33.00
      04-24-2016, 07:43 AM   #5
Detailers Domain
we had the car for 4 days. we love the car so much we wanted to ensure perfection.
pricing will vary depending on where you are located in the country. pm me for the exact price.
      04-24-2016, 07:44 AM   #6
Detailers Domain
thank you.
Originally Posted by M2PILOT View Post
Beautiful!!!!
I would agree.
      04-24-2016, 09:58 AM   #7
F87LUV
F87LUV's Avatar
Drives: '16 M2, '23 GT4
2023 Porsche GT4  [5.00]
2016 BMW M2  [8.66]
Thank you DetailersDomain ! Car looks awesome.
IG: Trackinheels
      04-24-2016, 12:56 PM   #8
Detailers Domain
thanks for trusting us with your baby!
      04-24-2016, 01:18 PM   #9
pruettfan
I wish you guys were in AZ or one of the western states. If I end up getting a car on the East Coast I think I will have it taken by your place on the way home. I love attention to the details. My installer is great at installation of Xpel and tint but they don't do the level of paint prep and detail your shop does. Keep up the great work and thanks for posting the details here. I am a hobby level detailer so I learn a lot from posts like this and information you put on your website.
      04-24-2016, 04:05 PM   #10
BurpZilla
Avid Car Enthusiast
BurpZilla's Avatar
Drives: 2017 Alpine White M2 6spd
SOLD. Looks beautiful. I was on the edge of doing this to my car but after this great review I am looking for places in Northern/Central FL. If anyone recommends anyone near gainesville, jacksonville, or orlando let me know!
History will never be forgotten
1992 Red Acura Legend 4dr, 2003 Daytona Blue Nissan, 350z 6spd, 2007 Black Audi B7 RS4 6spd
Current Girlfriends
Alpine White BMW M2 6spd; 2015 Arctic White Yukon XL Denali
      04-25-2016, 07:33 AM   #11
Detailers Domain
thank you for the kind words. if there is no one around that you trust why not do it yourself.
      04-25-2016, 07:34 AM   #12
Detailers Domain
you may want to to contact Brian Guy of http://www.aowheels.com/
if he can't do it he may have the right people for you.
I know he's an authorized Nanolex installer.
      04-25-2016, 08:22 AM   #13
MR.
MR.'s Avatar
Looks great! Excellent work.
I want the same only across the complete car + carbon roof wrapped + tinted rear lights and rear reflectors. In my case the car does not only need protection against stone chips but also vandalism and keying of the car.
Other than that the same principle as you did here
MR
      04-28-2016, 09:42 PM   #14
Detailers Domain
MR
MR,
Where are you located?
      04-28-2016, 10:28 PM   #15
MTHRAR
Drives: LBB M2
DetailersDomain How do you go about protecting the PPF? This is my first new car and first car with Xpel Ultimate, so I'm wondering what are the best ways to take care of it? Since I have a full front clip with many other areas covered (partial roof, rear fenders, luggage strip, etc etc), will I have to have a hybrid approach to maintaining my car...One procedure for PPF and one for areas that PPF doesn't cover?
I've basically only 2 bucket washed, clay bar'd, and waxed on all my used cars in the past (I now know that I was doing it wrong - lol), so I'm delving into new territory. I'm learning a ton, but feel so freakin overwhelmed by all the products, procedures, polishes, waxes, sealants, microfiber towels, foam cannons, foam guns, decontaminants, etc etc...
      05-01-2016, 06:46 PM   #16
supersam
Da Baus
supersam's Avatar
Drives: F87 6MT, RA, E46
Seconded,
Phil, whats your take on post-ppf and post-coating aftercare?
Fabspeed/Wagner/ER/Eibach/UCP/RTD
RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID
E46 330ci --> S54 M3 xplant vzv 3bananas (retired)
      05-03-2016, 07:29 AM   #17
Detailers Domain
sure thing as you can see on this M2 we installed the coating over the clear film, that will definitely help with the maintenance. as far as routine up keep, I would just wash normally and use a quick detailer, you can also protect as often as you like with a sealant or wax.
depending on the film you no longer have to polish it out.
You can still wash the film, 2 bucket method, quick detail spray, no rinse, wax, seal, we have use iron removers with great results.
I would stay away from solvent based products
      05-03-2016, 08:53 AM   #18
MTHRAR
Drives: LBB M2
Great! I actually just purchased a pressure washer and foam canon and made a large Adam's order (2 Buckets with Grit Guard). I am getting H20 Guard and Gloss with my Adam's order, would that ok to use on the Xpel or would you suggest going with something like a CQuartz UK or like a Menzerna Powerlock sealant with Collinite 845 wax on top. So many suggestions, I just want to make sure I'm protecting my car and not harming my PPF. I'd like to protect the PPF with the same stuff as the rest of the car with bare paint as well...
      05-03-2016, 01:29 PM   #19
Detailers Domain
yes the H20 guard and gloss will work well with the film as well as the paint.
      05-03-2016, 03:31 PM   #20
Elsharkyyturbo2
Drives: Long Beach Blue M2
Wow! This looks amazing.
      05-03-2016, 10:06 PM   #21
MTHRAR
Drives: LBB M2
Thank you for the response. I appreciate it!
      05-13-2016, 08:21 AM   #22
Detailers Domain
no problem at all.
Tags
bmw m2, nano coating, nanolex, paint protection film, xpel
