05-27-2020, 11:22 AM | #1 |
Rep 1,092
Brake temperatures
I'm new to tracking my car but I can already tell it's gonna be my new hobby
My first day was on a small track that's very hard on brakes. I noticed some fade once we started picking up speed (200kmh down to 60kmh hairpin). I was on stock brakes with fresh OEM DOT4 fluid. I checked rotor temps and I was up to 300C (572F). Here are my questions - 1. Where should I measure temperature? On the rotor? Caliper? Where on the caliper? 2. How hot is too hot (for stock brakes)? At what temp will the calipers turn green? 3. In which order would you upgrade: pads, fluid, ducts |
05-27-2020, 01:44 PM | #2 |
Rep 1,823
Yes sir, you know once you're hooked!
As for your questions: 1) Measure both at the rotor, and at the center of the caliper (Or hottest point of caliper you can find). The rotor temp is good to know so you can choose the right pad, the caliper temperature in turn tells you what temps the brake fluid is exposed to. 2) Stock fluid is not made to take much over 300F, stock pads will fade at ~800F Castrol SRF, Motul 600 or similar take your fade resistance when dry (no moisture from environment absorbed into the fluid) to about 600F Proper track pad will take 1300-2000F before fading. 3) Pads and fluids at the same time, ducts after. You'll be good for a while with high temp pads and fluid. Ducts come later once you're rally pushing into the brake zones, and on throttle enough to minimize cooling off time between brake applies. BIG HINT: It's also important to maintain the right braking technique ONCE you have the high temp pads AND fluid. Brake LATE AND HARD! Don't ride the brakes till the apex when you already slowed down. This is the fastest way to overheat your brakes.
2017 BMW M2 German Spec
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" Last edited by 5.M0NSTER; 05-27-2020 at 01:49 PM.. |
ZM22810.50 |
05-27-2020, 01:54 PM | #3 | |
Rep 1,092
I will upgrade the pads and fluid before the next session. Interesting on the technique, exactly opposite of what the instructors told us. But I understand the difference between dealing with street and race pads. |
05-27-2020, 03:15 PM | #4 | |
756
Rep 2,149
05-27-2020, 03:44 PM | #5 |
Rep 1,823
Makes sense though. Instructors job is to make sure you survive your outing. The race driving techniques come later. It's everyone's instinct to hi the brakes at the 5 marker. But with proper equipment you aren't supposed to brake until you see God. Or the 2 marker as I like to call it
PLF693766.00 |
05-27-2020, 11:00 PM | #6 | |
Rep 2,926
Drives: Cayman GT4, 135i
A good instructor will help you figure out how to brake in a safe manner while leaving margin for error (I.e., they may ask you to brake at the 400 marker when you could brake at the 200 or 300). But their job isn't to get you the fastest LapTime - it's for you to learn, have fun, and be safe. When you're solo and experienced you can experiment even more!
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
05-27-2020, 11:31 PM | #7 | |
Rep 650
05-28-2020, 08:26 AM | #8 |
Rep 42
Do pads and fluids together in my opinion. If that is not feasible then fluids at a minimum. Just understand that track pads can behave differently than street pads.
You brake late and hard with race/track pads because they have a torque rise (i.e. they don't grab as hard the first few moments of brake application and then they kick in progressively). You want to get the heat in them and keep it up while not overdoing it. This happens very fast but it is noticeable if you've been on a long straight and haven't touched the brakes for a bit. If you're in a series of turns you likely won't experience the delay. Generally track pads like to be hot to work well. This is why driving them on the street is not ideal. Of course not all pads are the same. Some pads will have much better "cold" bite (the brakes will still be hot of course but not like when you are under hard braking). So full braking is available more quickly. My preferred pads in the past sometimes needed a little heat before they really grabbed. To that end if I was on a long straightaway I would often just touch the brake with my left foot to both set the pads and get a little heat in them. Also a good check to make sure you still have brakes. The car barely slowed. I liked those pads though because their torque rise was minimal (i.e. very consistent brake force throughout their working temperature) and I was never able to overheat them. I do agree with both braking hard and braking early to start. That is how you will learn the behavior of the brakes but still be safe in case you are over the limit. Just take little steps to go deeper. Top priority is to make sure you are on your line though. This illustrates my point about different pads having different torque rise rates, starting/stopping to work at different temperatures (the delay I mentioned is evident in the pads that work at higher temperatures) Last edited by JoeP; 05-28-2020 at 08:41 AM.. |
05-29-2020, 03:06 PM | #9 | |
Rep 660
05-29-2020, 03:45 PM | #10 | |
Rep 1,823
It takes me a good few laps before I start braking at the 3 or 2 marker and stay on throttle past the 5 and 4 markers. Self preservation instinct is still too strong early in the day. Also if you're braking late chances are you need to brake past the turn in anyway, like you said. I aim to be just releasing the brakes past turn in, and be on throttle a little before the apex, then balance the oversteer with throttle.
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" Last edited by 5.M0NSTER; 05-29-2020 at 04:07 PM.. |
05-29-2020, 04:35 PM | #11 |
M2 Pilot
138
Rep 165
The OEM brake pads tend to leave deposits on the rotors. I use Pagid RSL29 on track, and they work well. I'd recommend learning to swap the pads yourself-- it's pretty easy and there are plenty of videos to teach you how. Track pads squeal like a school bus on the street, so you're going to want to change them out for each event, if you drive often in between.
Welcome to the addiction.
America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt
'17 BMW M2 |
05-29-2020, 04:55 PM | #12 | |
Rep 1,092
I'm very comfortable with working on the car so I would have no problem swapping them. |
05-29-2020, 07:43 PM | #13 |
Rep 427
Pagid RSL 29 has played nicely with OEM pads for me personally, and I chose them because that seemed to be the consensus among others here.
05-29-2020, 11:21 PM | #14 | |
Rep 650
05-30-2020, 03:33 AM | #15 | |
Rep 1,823
I'm a big fan of the PFC08 as well, and I swap it before my events, then return to OEM pad. No deposits at all, and no issues swapping back and forth. I love that the PFCs last forever, and offer high fade resistance. Also they have a good linear torque with only slight increase over temperature, making them easy to modulate. But FML, the noise!
05-30-2020, 03:55 PM | #16 | |
Rep 660
Haha, the self-preservation thing is real. I've given rides to friends who just started going to HDPEs and slamming the brakes really late after a long straight is an eye-opening experience for them |
5.M0NSTER3353.50 |
05-30-2020, 04:02 PM | #17 | |
Rep 660
Honestly, I think it's more important to keep the same pads on the same rotors (and on the same side) and do proper bedding in procedures. The former is to ensure the wear patterns are similar for each pad and the latter will pretty much remove any traces of the previous pad. Realistically, track pads (when cold) will scrub off the stock pad transfer layer, so when you get to the track, you take it easy the first session and bed in brakes there. When driving home, the track pads will be cold again and remove the transfer layer, then swap back to stock pads. Street pads bed in over time just by street driving so the whole procedure is actually pretty easy. |
