M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Odd conditions after rear tire replacement
      05-20-2020, 09:56 AM   #1
MtlM2
MtlM2's Avatar
Just installed 275/35 19 rear tires and still have the stock 245/35 19 fronts.
Driving on rutted highways is now an absolute nightmare. Car pulls in all directions. On smooth roads no issues.
Anyone experienced something similar ? Hard to believe 10mm extra at the back makes such a difference.
Considering trying the 255/35 19 fronts and seeing what happens.
Thanks
      05-20-2020, 10:28 AM   #2
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Since you didn't specify:
what tire?
Dry and warm ideal road conditions as well? (i.e. no rain and roads not wet/oily)
      05-20-2020, 11:20 AM   #3
MtlM2
MtlM2's Avatar
what tire?
Firestone Indy 500 and dry conditions above 10 degrees Celsius
      05-20-2020, 11:29 AM   #4
Conissah
Conissah's Avatar
1576
Drives: 2018 M3
What are the tires on the front?
I believe what you are talking about is "tramlining" correct? The tendency for a car to follow grooves / ruts on road surfaces.
nioh_lbbm21716.50
MtlM21.50
      05-20-2020, 11:30 AM   #5
nioh_lbbm2
nioh_lbbm2's Avatar
1717
And you're getting the squirrelly feeling just cruising on the highway? Or are doing WOT pulls and get the side to side
      05-20-2020, 12:30 PM   #6
robertm
Drives: 2020 M2 Comp
Not sure this helps you but for what it's worth, I've got the Indy 500s front and back on my car w/o issue. I believe I went to 255 front and 275 back (was one size up from stock).
      05-20-2020, 07:51 PM   #7
MtlM2
MtlM2's Avatar
Yup exactly correct. Same tire up front. And just cruising.
      05-20-2020, 08:22 PM   #8
Drop the hammer
Drives: '17 F87 M2 AW, Dct
Check pressures and maybe up the pressure a bit. Should be already close to what’s on your door tag for pressure. Maybe they didn’t check properly after the mounting and one tire could be off.
Whenever going over size tires you will increase the tramlining effects. It’s why I’m going back down to 255/275 next time. But since you aren’t hugely oversized I wouldn’t think that would be much different one size up from stock.
      05-21-2020, 06:01 AM   #9
MtlM2
MtlM2's Avatar
Checked and double checked the pressures. Will be digging into it tonight some more and maybe play with the pressures a bit. Thanks
      06-01-2020, 10:11 AM   #10
M2Cmtl
Drives: 21 Q7 & 22 4XE
I hated the indy 500s I had on my F31 (in 19" 225/255) I can't imagine having them on my M2C. The Michelin tires are so amazing...
If the tires are new, maybe it's just that they are not broken in.
2020 M2C 24.04.2020 delivery - Sold 24.08.22
      06-01-2020, 03:15 PM   #11
MtlM2
MtlM2's Avatar
All checked out ok. Nothing to report. Guess I will just have to get used to it.
Thanks for the input
