M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > help, bm3 log attached, losing boost
      08-18-2019, 06:41 PM   #23
JKen_0115
JKen_0115's Avatar
Drives: 2017_M2
Originally Posted by Drop the hammer View Post
I might try to install the gfb dv+. To eliminate that possibility (a leak there at higher boost levels that may not show up at lower stock boost levels). Although if it was leaking past it, I would think it would show up at the stock 12psi as well. Cheap enough to change as I’d do it myself.
I highly suggest DV+ because it holds the boost well. The part is cheap but the labor is high since it's not easy to install. Remember to find the good shop to install that part I had a installation issue before and caused some issue. I have similar setup like you do but CTS open Intake, FTP charge/boost/inlet pipes upgrade....
Wish we can figure out the root cause. BTW, my buddy from BMW tech mentioned they have changed couple OEM wastegate under warranty...
      08-18-2019, 07:02 PM   #24
Drop the hammer
Drives: '17 F87 M2 AW, Dct
I was thinking of taking into dealer, however, the problem doesn’t exist at stock tune boost levels, if it did exist at that level then it would for sure go to the dealer. But this seems to only occur at the higher boost levels.
      08-28-2019, 05:24 PM   #25
Pray for Mojo
430
Drives: 2014 M235i & 2018 X3 M40i
You're at 3,200ft of altitude, you aren't going to hit the boost target with 15-20% less air density. You should fill with Husky 94 vs Petro 94, it seems to be more knock resistant. I'm down to 1/3 can of boostane professional with Husky 94 on 91 OTS. Stopped using Ultra 94 last summer when it was clear it just doesn't cut it.
      08-30-2019, 02:38 PM   #26
Drop the hammer
Ok, so the answer to this is a bigger more capable turbo for my altitude. I can work with that I assumed at 3200 feet that the stock turbo can make 17 psi, if techinically it cannot, then that explains it.
17 M2 AW, DCT, black grills, eventuri, bm3 Stg 2, csf intercooler, Fabspeed sportcat, AA charge pipe, 285r/265f pss, 285/30r18 re71r’s square apex 10x18, and smooth riding TC Kline coil overs with a very heavy throttle foot.
      08-30-2019, 03:28 PM   #27
Pray for Mojo
430
The stock turbo is good for 18ish psi at sea level, which nets 14-16psi for us highlanders depending on air density that day. Some people will make claims about higher than 18, but it's pushed beyond its efficiency range and makes heat and no more power.
      08-30-2019, 08:19 PM   #28
Drop the hammer
Thanks for the info!
      05-12-2020, 10:21 PM   #29
Drop the hammer
Adding a Turbosmart bov to see if this will help. It just arrived and will install it this weekend.
      05-17-2020, 08:04 PM   #30
Wattens
Drives: OG M2, 4C, Bentley GT
Curious to know if this helps, I didn't have logs ability when I was running the stock DV, but immediately after changing it to the Turbosmart VR11, I gained a bit of power and the stock boost was a little higher so I made the assumption my OEM DV had a little leak (probably not as large as yours though).
      05-17-2020, 08:07 PM   #31
Wattens
Originally Posted by JKen_0115 View Post
Op, I have been running into the same situation as you're on BM3 STG2 and my WDGDC is running 100% on the higher RPM. I did add the racing fuel and timing went well but the higher RPM issue is still there. I don't have this issue at all on stock map. According to Halim from PTF, he said i'm maxing up my turbo. I tried all boost leaking testing, also I have installed DV+ but the result is the same. I'm working on custom tune and looking for the better solution now.
I'm very interested this thread, looking for some feedback from other forum people as well.
OTS Log: http://www.bootmod3.net/log?id=5d5802edc090c644084cb552
Stock log: http://www.bootmod3.net/log?id=5d58012cc090c644084cb54e
How were you getting a target boost pressure of 17.8psi on BM3 Stage 2? Or has the map been changed by PTF as mine is only ever max 16.5psi (stage 2 OTS 93)
      05-17-2020, 09:27 PM   #32
JKen_0115
JKen_0115's Avatar
Drives: 2017_M2
I'm running the custom tune.
      07-13-2020, 07:24 PM   #33
gphung
194
Drives: 2018 M2 LBB - 6MT
2018 BMW M2  [0.00]
Any updates?
      07-31-2020, 03:29 PM   #34
widetyres
279
Drives: M3 E92 DCT, 2012
Hi,
I have the same issue - running BM3 stage 2 (tried both 91 and 93), the boost holds target in the lower/mid revs (~16.5 PSI , sometimes peaking just over 17), but then drops below target from 4.9K onwards (always ~1PSI below target). The wastegate is not @ 100% - more like 80%.
I had the car dyno'd today, and this is costing me 60-70bhp!!!!!!!!
Drop the hammer / JKen_0115 - please can you let us know if you managed to solve your issue with an aftermarket DV, or something else?
Cheers.
      02-03-2021, 01:07 PM   #35
akkando
akkando's Avatar
5863
i have some strange boost loss at higher rpms. I'm currently trouble shooting and took a log. I have just ordered another set of plugs since i have around 25,000 km's on this set.
Running bm3 stage 2 on 91 tune, with 93 fuel, csf intercooler, eventuri old style, fabspeed sport cat, aa boost pipe, bm3's recommended ngk plugs with 20 thou gap. This log taken with traction full off.
Maybe boost leak??
thought i'd start with changing plugs and maybe trying some octane booster and re-logging.
what do you think?
http://www.bootmod3.net/log?id=5d3c86eeae729b431954128a
MAF values seem low?
      11-06-2022, 11:02 PM   #36
Mtregre
Drives: '18 M2
Bringing this dead horse back.
I'm having the same issue. Haven't been able to pull any logs yet,
But I'm clearly loosing boost above 5500rpms.
Curious to know if the DV could be cause and what yall ended up doing to fix the issue if not
      11-07-2022, 03:40 PM   #37
Drop the hammer
I did add the turbo smart bov. I also upgraded to eventuri version 2. But same thing would happen at high rpm’s.
So I traded the car. When pulling off the csf intercooler, it did look like the motor side fitting may have been leaking at the intercooler where the AA pipe inserted into the intercooler. Had 80,000kms on it anyways, so was time to go regardless of this.
Got another n55 M2. In the process of putting the same mods on (but the modding is postponed for winter). I have transferred my BM3 (stage 1 for now) and my Fabspeed sport cat. The coil overs and intercooler can wait until summer as I don’t drive it much in winter. So I guess I solved the problem by moving the car along.
