10-05-2018, 09:14 AM | #1 |
Rep 148
Drives: M3 G80
M2C - Wireless Charger - iPhone gets HOT
My phone gets pretty hot when charging in the car.
Even short durations. Went for a 20min ride yesterday and it was burning up and charged the phone like 5% maybe. iPhone 8. I use a wireless charger on my desk and its totally fine. Anyone else experienced this? |
10-05-2018, 09:48 AM | #2 | |
Rep 825
+1 A number of folks have mentioned this, and I've read that it's probably due to the fact that the wireless charging in the M2 is less than perfectly efficient - lots of waste heat. Here's what I've found: 1. If you use maps on your phone for any extended period of time, then the phone will heat up like crazy - found this to be the case whether I was plugged in via USB or using wireless charging. Maps simply use a ton of processing power with resulting heat. One time, when I was using maps and wirelessly charging at the same time, the phone got so hot it shut itself down 2. If I charge the phone wirelessly without using maps (use phone for music, phone calls, etc.) then it doesn't heat up excessively My experience, thus far. |
10-05-2018, 10:17 AM | #3 |
Rep 50
Same issue at home on Anker wireless charger ... slow charging and iPhone 8 gets hot (but not always)
10-05-2018, 01:09 PM | #4 |
Rep 5,728
Drives: 2019 M2 Competition
It's just the built in phone warmer.
10-05-2018, 01:31 PM | #5 |
Rep 289
Inductive charging is about getting the charging coil exactly positioned over the receptor inside the device. Failure to get these aligned perfectly produces wasted energy during the transmission - and this energy becomes heat.
///M2 - 2018 LBB DCT
10-05-2018, 02:42 PM | #6 | |
Rep 148
Drives: M3 G80
I have no cover also. Good phone warmer. |
10-05-2018, 02:47 PM | #7 | |
Rep 289
Drives: '18 M2 MG 6MT, '03 E39
You can also qualify for the DINAN iPhone charm but only if you also get the DINAN iPhone cable, sold separately...
Current Car | 2018 ///M2 MG 6MT
Previous Car | 2003 E39 530i Sport Last edited by arquitecto; 10-05-2018 at 02:55 PM.. |
10-05-2018, 03:02 PM | #8 |
Rep 5,728
^lol
10-05-2018, 07:42 PM | #10 |
Rep 289
My iPhone X gets hot but not scalding nowhere near shutting down.
10-05-2018, 07:43 PM | #11 |
Rep 466
Are you using a case by chance? I'm using a leather case but if it get hot I might take the case off.
10-05-2018, 08:54 PM | #12 | |
Rep 289
10-06-2018, 09:45 AM | #14 |
Rep 466
10-07-2018, 03:28 AM | #15 |
Rep 113
cptobvious2531.50 |
10-07-2018, 04:59 AM | #16 |
meow
118
Rep 156
If you are using a wallet case, be warned that charging with cards that have a contactless payment chip, or a metal card (amex) will also cause this heating effect and can also damage the cards.
10-07-2018, 05:55 AM | #17 |
Rep 3,062
There is. But better thinking is probably just to use a USB to lightning cable. It will charge the phone much faster, plus, in my non wireless charging car the space in there easily accommodates the Xs Max very securely. Just make sure the power button faces the back seat. Otherwise you will accidentally call emergency services every time you put the phone in there.
10-07-2018, 09:33 AM | #18 | |
4972
Rep 10,200
Davil6484.00 |
10-07-2018, 11:17 AM | #19 |
Rep 2,268
Wireless charging has been shown to lead to increased phone battery deterioration. I'd definitely avoid it if possible.
don't read this. too late...
10-07-2018, 11:25 AM | #20 |
Rep 825
Yeah, the heat causes significant battery deterioration. I totally wouldn't do it on a regular basis, except I signed up for the Apple iPhone program, so effectively I'm just leasing my phone on a yearly basis. So, I just need the battery to last 12 months! Ha!
10"4967.50 |
10-07-2018, 12:15 PM | #21 |
Rep 148
Drives: M3 G80
10-13-2018, 04:08 PM | #22 |
Rep 1,237
Drives: M2 Competition
iPhone X - gets hot af...
I only charge it wirelessly, but the phone does not get hot at all with all the other wireless chargers i have.
