03-04-2021, 11:03 PM | #67 | |
Rep 3,696
03-05-2021, 12:46 PM | #68 |
Rep 4,146
The more I read, the more I'm convinced that the Wagner Evo 3 might be one of the best IC's on this platform. It's not just the good keeping the IATs in check, it's that it provides (from all the reviews) lighter weight and great driveability.
I'll wait for more review to trickle out, but I really like what Wagner did - MASSIVE surface area to make up for the lack of fin density (which can limit response) lighter weight (I believe it was quoted at 27lbs?) but still heavy enough to provide good thermal capacity. I really want to see some track reviews on it, and how the taller height effects the coolant temperatures.
Mods: Yes.
03-05-2021, 12:56 PM | #69 | |
Rep 3,696
It’s pricey and a bit of a pain to install, but it comes with its own pipes with larger inlet/outlet diameters, so that saves some cash. And it bolts to the crash bumper, so it’s super solid. It’ll take 5-6mo for me to get some hot weather track day logs, but the 95F ambient back to back pull logs I did last summer look pretty good! |
03-05-2021, 01:21 PM | #70 | |
Rep 4,146
Mods: Yes.
03-05-2021, 03:08 PM | #71 | |
Rep 3,696
Also remember I'm pushing 442whp@5500rpm & 507wft-lbs@2600rpm (~520/600 engine hp/ft-lbs) with 20.5-20.9psi target and this is real world data, not a "best case scenario" starting off with a cooled off IC, doing single pull data using lower powered cars than this, like the IC manufacturers do. In addition, IAT temp rise (or fall) and the temp delta to ambient are two different measures that may not be clear to some folks. The values below are absolute values above ambient in different scenarios, not the IAT rise/fall trend under load. The general IAT trend for the Evo3 when you're applying throttle is temps drop in gears 1-2-3, stay flat in 4, and begin to creep up in 5, which is pretty darn impressive. I get the feeling that the ambient delta for other IC's may be better when cruising around town or at part load, but this thing performs when you're WOT and really pushing it. But, I haven't seen anyone else with as much data pushing one of the big IC's as hard as I have with the Evo3, just some single pull VRSF & ER data from the manufacturers--so, IDK their real world performance. Everyday driving (95F ambient): Very slow stop-and-go/bumper-to-bumper traffic: +30-35F 25mph cruising around town: +20-25F 75mph cruising highway: +15F Logging (95F ambient): End of first pull: +12F End of 3rd & 4th combo pull: +15F End of 3rd/4th/5th combo pull: +19F End of 10+ back-to-back 3-4/3-4-5 pulls with hard braking in between: +28F Cooler weather example (34F ambient): 75mph cruising highway: +6F End of first pull: +6F End of 3rd & 4th combo pull: +8F End of 3rd/4th/5th combo pull: +13F Last edited by ZM2; 03-05-2021 at 04:53 PM.. |
03-05-2021, 09:42 PM | #72 |
Rep 6,637
So I attempted to take some logs today but couldn't stay in Mexico long. Wagner Comp Evo 2 intercooler and BM3 stage 1 ACN tune. Ambient temp unfortunately was only 55-60 degrees F.
This log is just cruising the highway. As you can see IAT was like 11-12 degrees above ambient. https://www.bootmod3.net/log?id=6042...729b5994d9ea9e Some pulls with the highest IATs. Ambient was 57. Highest IAT was 84 after two pulls and then coasting for a while. The IAT went down as soon as I was on throttle again. https://www.bootmod3.net/log?id=6042...729b5a22cd1188 Here I am just fooling around on the highway with little pulls here and there. Ambient is 56 degrees F and IAT start at 79 but get lower and hover low 70s. https://www.bootmod3.net/log?id=6042...729b5a22cd11aa My conclusion is that for the STREET for my state of tune I don't think I will have IAT problems at any ambient less than 80 degrees. I just generally can't be pushing the motor more than this because I can't get to the top of fourth on these roads and I can't find roads where I can do back to back to back pulls often enough that the intercooler heatsoaks and doesn't cool down. Also on back roads with curves I can't be flat out long enough to heat soak the intercooler. Is there a better intercooler that's cheaper? I am sure of it. Does this intercooler do the job for my use case? It does. Would this work for someone who is in 95 degree weather most of the year or on the track? I doubt it. |
AmuroRay2282.50 |
03-08-2021, 08:44 PM | #73 | |
Rep 6,637
Wagner Evo 2 Comp https://f87.bimmerpost.com/forums/sh....php?t=1788934 |
AmuroRay2282.50 |
03-08-2021, 09:09 PM | #74 | |
Rep 4,146
I thank you for doing the legwork for this, and the logs. The Evo2 is a good street cooler, but even without all the data I’ve seen, I could assume it’s not ready for stage 2 or track use. Last edited by AmuroRay; 03-10-2021 at 08:59 AM.. |
03-22-2021, 10:45 PM | #76 | |
Rep 753
On Sat, I was at The Ridge Motorsports park (my home track). This has a long front straight where you enter at around 50'ish mph in 3rd gear and get to around 132-135mph in 5th before braking for T1 that is around a 90mph turn. On Sat, the ambient temp was around 50°F. For 3 20 minute sessions, I would enter the straight at around 100°F for IAT and end at 120-124°F; every shift would drop the temp by a few degrees only to climb back up. The rest of the track has enough in terms of pace and slowdowns that IAT stayed below 90°F - average I'd say was 75-82°F. I was using an Ultraguage connected to OBD II and data was visual reference. I did not experience any timing pull or loss of power. Top speed at the end of the straight was consistent lap after lap. Oh, another thing is how quickly the stock Intercooler sheds IAT as soon as you're off boost. |
03-22-2021, 11:06 PM | #78 | |
Rep 3,696
I got the autox fastest time of the week a few years ago at M Track Days, but I wasn’t actually registered bc a cpl of the instructors (that I raced with) invited us out to Seattle. No free trip to Thermal, damnit! Anywho, 75F IAT above ambient is pretty nuts. The car def makes less power as IATs go up unless you’ve got high ethanol or octane in your fuel, and timing is def pulled with IAT >110F—you just may not have noticed it for the last bit of the front straight. It’ll be interesting to see the IAT impact of the ER IC, and daily driving impressions. Thanks for posting up some info! Last edited by ZM2; 03-22-2021 at 11:12 PM.. |
03-23-2021, 09:36 AM | #79 |
Rep 753
105mph through T1 takes a special set of "skills" to even attempt. And I am not surprised he did not stick it - should have kept it straight and stayed on the brakes and the car would have slowed down before the track ends or just past. I'm usually in the 88-92 range at T1 apex - there are a few more mph to be had, but it makes the next complex (T2/T3/T4) more difficult to get right and carry momentum. It's a fun track and has a nice mix of elevation, speed and technical bits.
I was kinda surprised at the peak IATs on the front straight as well, given ambient was 50°F. What does a timing pull even feel like, if at all? If it's happening, I certainly don't notice it. I only had WA 92 octane in the tank. No octane booster or anything else. What's the word on Boostane or Race Gas octane boosters on a car with stock cats (or just with cats in general)? |
03-23-2021, 09:55 AM | #80 | |
Rep 3,696
It sounds like you're not getting above 110F IAT until the end of the straight, so you're probably focused on braking and turning for T1 and may not notice the timing pull. It just feels like the car has slightly less power, and it's hard to pick up on unless it's summer and happening all the time. It could also be that you're not actually hitting >110F IAT while under power and it spikes up once you start braking for T1 with reduced airflow over the IC. In that case you wouldn't feel power pulled, but it will reduce available power getting back on the gas coming out of the corner. Again, more noticeable in summer, but it is happening. I'd say all it's going to take is a 70F ambient day for you to start to notice these things bc your IATs will start going 130F+. Last edited by ZM2; 03-23-2021 at 10:45 AM.. |
03-23-2021, 10:52 AM | #81 |
Rep 4,146
I have an IC on my car now (unkown brand) and it does NOT hold up. LOL, I looked back at my logs and it's hitting 130F iats during some of my pulls. Can't wait to change this garbage out.
Mods: Yes.
03-23-2021, 01:53 PM | #82 |
Rep 753
It's definitely over 115°F for the second half of the straight, close to 120 at the top of 4th gear, drops a couple of degrees during the shift and climbs back up to 122-124° before I brake for T1. The car is over 110 for most of the straight ...
AmuroRay, I am surprised you're running some random brand Intercooler |
03-23-2021, 02:04 PM | #83 | |
Rep 3,696
IMO, you have enough data to support putting the ER on before your next track visit. |
bentom2335.50 |
03-23-2021, 02:25 PM | #84 | |
Rep 4,146
https://f30.bimmerpost.com/forums/sh....php?t=1661914 Check the wonderful IATs on that. When I bought the car, it already had a MPE, DP, IC and JB4. I sold the JB4, moved to MHD but otherwise I haven't done anything else. When I asked inquired about an intercooler, no one could give me a satisfactory answer. I've been wishywashy about if I wanted to continue to mod the car or go back to stock, so I really haven't done anything since.
Mods: Yes.
03-23-2021, 07:55 PM | #85 | |
Rep 427
For the record, I agree with your assessment that Pal has all the data he should need to go ahead and install the intercooler. |
ZM22813.50 |
03-24-2021, 06:49 AM | #86 |
Rep 4,146
I’m going to run a log this morning if I can. I want to give a good before/after comparison.
This morning - stock tune, 58F-62F - IAT as low as 10F over and as high as 20F. Stock tune, no full WOT. I'm going to continue compiling a few logs tonight, hopefully stock tune vs custom 2-3-4 runs. Last edited by AmuroRay; 03-24-2021 at 08:08 AM.. |
