M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Supra Fuel Pump in OG m2..FINALLY!!!!
      11-01-2019, 08:12 AM   #23
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
Originally Posted by MiamiM235iEstorilBlue View Post
Any reason at all to upgrade the fuel pump on a totally stock n55 M2? Would it also provide more midrange torque, just less than the big turbo setup in the video? Or would it have no effect on a stock motor?
Yes, if you’re going FBO and have an aggressive tune, this could help. It’s definitely a benefit for people using E85.
      11-01-2019, 08:13 AM   #24
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
Originally Posted by F87source View Post
Zero benefits whatsoever if your actual HPFP pressure is not below the target HPFP pressure, i.e. if your HPFP is not having issues flowing enough fuel this upgrade will give you zero gains, which would be the case on a stock m2.
You're better off getting a tune, chargepipes, downpipe, and intercooler.
This is also true. I would assume if your normally maxing out your pump like I am, you have a weak pump.
      11-01-2019, 10:38 AM   #25
F87source
F87source's Avatar
Drives: Bmw M2
The F series n55 hpfp is notoriously weak from the factory when tuning especially with ethanol. However if you're maxing out your hpfp on a stock car something is definitely wrong.
      11-01-2019, 11:09 AM   #26
Daleb
Definitely possible to reach the limits of the oem hpfp before turbo on the M2. Not by a great deal but certainly possible. The BM3 OTS maps tend to be on the hpfp limit especially around the 5-6krpm area. There’s performance to be had over these maps.
Over in the U.K. and parts of Europe guys have installed the XDI-35 pump while on oem turbo and made gains even on 99 ron fuel.
We have also seen a m2 use the b58 hpfp which was sufficient enough to run e40 fuel and max out the oem turbo.
Bee Pee1779.00
      11-01-2019, 11:21 AM   #27
MPBK
Everyday I'm shuffling
Drives: '12 SG 135i DCT; '18 MG M2 DCT
How do you know you're "maxing out" your pump?
Do you drive WOT all the time?
Nezil1404.00
      11-01-2019, 01:17 PM   #28
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
I have logs.
https://f30.bimmerpost.com/forums/sh....php?t=1661914
      11-01-2019, 03:21 PM   #29
cecaa850
Is there a good way to tell if low rail pressure is caused by a bad high pressure pump or a low pressure pump that can't supply enough volume?
      11-01-2019, 04:08 PM   #30
F87source
F87source's Avatar
Drives: Bmw M2
If you're stock and the hpfp isn't supply enough pressure likey it is bad, or you have some underlying issues like a fuel leak or the lpfp is not supplying the hpfp with enough fuel.
If it's tuned then it'll be harder to tell.
Otherwise codes will be another key indicator.
      11-01-2019, 04:54 PM   #31
cecaa850
Yep, that was pretty much my question. Fuel leak should be easy to spot.
I would think that low pressure from either cause would trigger the same code.
      11-01-2019, 05:56 PM   #32
eeyang92
Drives: LBB M2 LCI 6MT
Was it determined the b58 pump actually flows better than the one with n55? I seem to remember reading that linked thread that some people did not find any improvement at all.
      11-02-2019, 07:34 AM   #33
Andi-M2
Andi-M2's Avatar
Germany
193
Drives: M2 F87
Just a short question:
I've got a B58 HPFP (BMW part.no. 13517642466) here in my garage.
Does it work any better than the standard N55 pump based on producing more fuel volume? Is that the Evo5 or Evo6 pump?
Or do I need the 13518631642 pump necessarily for running Stg 2 turbo?
Thx in advance for your help.
      11-02-2019, 08:21 AM   #34
Rondavouz
Drives: Bmw M2
13517642466 is Evo5. Better than original but not that much.
On stage 2 turbo and no ethanol (or just the 5% that is in some regular gas) you are fine with the orignal one. With E30 and my TTE 550 turbo my orginal HPFP crashes.
13517642466 might solve it for E30, I dont know for sure, have one laying around but didnt think it was worth installing in the end.
Have a 13518631642 that will arrive on monday that I will install.
Running
      11-03-2019, 07:49 AM   #35
Andi-M2
Andi-M2's Avatar
Germany
193
Drives: M2 F87
Running
Ok, thx for your explanation!
I'm planning on running 500-520hp (engine output, not whp) with a TTE550 and the B58 hpfp, so with regard to your thougts I won't get into trouble with fuel supply!?
I already installed a Walbro 450 lpfp..
Do I need anything else? Tmap sensor? DV+?
      11-03-2019, 10:14 AM   #36
Rafal84
Drives: various
at my place:
1. TTE550
2. HPFP: xdi https://www.rosssport.com/Brands/TUN...5-TTFSN55-HPFP
3. IC wagner
4th exhaust: Milltek
5. intake: ARMA
6. lpfp: serial original
7. inlet pipe: Evolution Raceworks
8. NGK Lazer Iridium Spark Plug - BMW N55 / S55 (Single Plug) https://www.rosssport.com/Brands/NGK...-NGKSILZKBR8DS
9. DV: https://www.rosssport.com/Brands/GFB...2-N55-GFBT9357
10. map sensors: original
11. DP: wagner, no cat
fuel: Shell 100 octane
without methanol
520 hp
      11-03-2019, 10:38 AM   #37
Andi-M2
Andi-M2's Avatar
Germany
193
Drives: M2 F87
Originally Posted by Rafal84 View Post
at my place:
1. TTE550
3. IC wagner
5. intake: ARMA
without methanol
520 hp
Not too bad, as well!
My current mods on engine-wise are:
- Wagner Evo 2 Competition IC
- Eventuri Intake
- HJS 300cpi
- Akra Evo Exhaust
- Walbro 450 lpfp
- TurboPerformance Charge- & Boostpipe
- PureTurbos Inlet pipe
- Ecu custom tune (435hp/640nm) with Shell 100 octane
During winter months I'll install the TTE550 with the B58 pump and see what happens. Otherwise I'll upgrade to XDI or the Supra pump.
      11-03-2019, 07:10 PM   #38
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
- Eventuri Intake
- HJS 300cpi
- Akra Evo Exhaust
- Walbro 450 lpfp
Europe has the best octane, but 500 crank hp, or 450whp (Dynojet) requires 19~20psi (uncapped), which is more than RON100 can handle, unless it’s freezing cold all the time.
Not many tuners want (or have the skill) to work around octane. Race gas, WMI or ethanol would make things a little easier.
Lemania 2320
      11-04-2019, 07:06 AM   #39
Rondavouz
Drives: Bmw M2
B58 Hpfp Vs B58 Supra
Below are some pictures to show the difference between the B58 and B58 “Supra” pumps
Differences are heavier, a little bigger, connector orientation, Thicker and different flange round top with no dent and some more.
Now to install...
TemjinX2520.50
Poochie9104.50
ried791.50
      11-04-2019, 09:35 AM   #40
F87source
F87source's Avatar
Drives: Bmw M2
Now to install...
Nice!
Keep us posted!
      11-04-2019, 10:22 AM   #41
Pray for Mojo
430
Drives: 2014 M235i & 2018 X3 M40i
Rondavouz can you template the flange modification on a sheet of letter paper and scan it for us? Everyone seems to do it themselves but it would be nice to be able to do the modification prior to taking the intake and old pump off.
      11-04-2019, 02:19 PM   #42
F87source
F87source's Avatar
Drives: Bmw M2
That could be a recipe for disaster. You should really mark it while it is in position because if the template js even a bit off you risk absolutely messing up the flange, which already has barely enough space for the modifications if you have to redrill due to a mess up you risk the bolts being too loose or having holes too wide to properly secure the hpfp.
      11-04-2019, 03:57 PM   #43
Rondavouz
Drives: Bmw M2
I totally agree with f87source. It’s not just a cutting operation
Here is a quick outline sketch just showing the difference in size and location of things. And then there are physical lines in the way too.
So below is just for fun and nothing else.
Inner line is original M2 hpfp
Outerline is b58 Supra hpfp.
Lines on the outline is connector orientation. Big box is electrical connector.
      11-04-2019, 04:39 PM   #44
Pray for Mojo
430
You guys are right, just looking at other pics the flange/pump clock position of the HDP6 relative to the OE pump makes it impossible. You really have to template the existing with a piece of cardboard then overlay the new pump to get the right angle prior to cutting and drilling.
