12-23-2019, 12:12 PM | #1 |
Everyday I'm shuffling
449
Rep 1,098
Seat bolster protectors
It seems most people with sport seats will, sooner or later, run into the bolsters wearing out.
For me, the M2 side bolsters, with less than 10K miles, are already showing signs of wear. On the 135i, the left leg bolsters literally ripped. I had to put duct tape there (temporarily). I found this company, which sells a neat solution. http://www.wattsmotoringaccessories.com/chaps.html Unfortunately, it seems they have not up updated their products for a long while, which seems to indicate that they're out of business (?) I can't believe there aren't more companies offering similar products. Does anyone know of a good solution for this problem? |
12-23-2019, 12:15 PM | #2 |
Rep 1,049
This is something I am worried about with the new seats in the Comp. I plan on trying to code an "easy-out" function to prevent this. When the car is started, move the seat up, and when it's off, move it back. My Jeep GC had it and I loved it.
12-23-2019, 04:43 PM | #3 |
449
Rep 1,098
I don't think BMW has such feature.
Let us know if you find it. I did not see anything like that in Bimmercode. But seriously, this is not something that an app can fix. You can slide the seats all the way back, but you will go along with the seats. You'll still brush against the bolsters when you get out, and while driving, your legs will still brush against the side bolsters. |
12-23-2019, 04:56 PM | #4 |
Luxury at the redline :)
9103
Rep 7,563
You can code Easy Entry/Exit, I did it in a 2019 model, so I don't see why it work on a new M2C.
https://www.bimmerpost.com/forums/sh...php?p=23264183 |
12-24-2019, 08:54 AM | #6 |
Rep 1,657
Drives: 2022 WRX World Rally Blue
I did it in my 2017 using E-Sys.
I think the value for all the way back is 64. I adjusted mine because I'm not tall. Just enough to get in comfortably and press the clutch. In E-Sys it can be found under the SM2 module. Can't help you with Bimmercode though. Look at Poochie's link. That's what I followed.
Rick
12-24-2019, 10:33 AM | #7 |
Rep 47
I had my 135 for almost 12 years and never had any issues with the leather seats. I cleaned and put leather conditioner every couple months. The seats in the M2C seem to be even easier to get in and out of so not to cause excessive wear.
12-24-2019, 11:53 AM | #8 | ||
449
Rep 1,098
In your linked post you said: Quote:
12-24-2019, 12:00 PM | #9 | |||
9103
Rep 7,563
Sorry about the confusion, that post was from last year before I had an opportunity to test the coding on a 2019 230i loaner car. To confirm, yes, those same parameters does work on all F-Series vehicles with model years 2018 and above, including vehicles with the latest software revision. |
12-24-2019, 12:06 PM | #10 | |
449
Rep 1,098
12-26-2019, 09:22 PM | #11 | |
449
Rep 1,098
On a 2018 LCI M2, I see the 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE but the 3012 EAH looks very different. There is no EAH_VERFAHRWEG_SLV_PHYS nor EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS parameters. Instead, there is only a EAH_0_42_255 parameter. (see picture : https://www.dropbox.com/s/bbli43segu...44.33.png?dl=0 ) If I go inside that parameter, I see 5 other values (including a custom value). (see picture https://www.dropbox.com/s/tu15w333yk...44.37.png?dl=0 ) What am I missing? Do I need to ask my dealer to update the software? |
12-26-2019, 11:32 PM | #12 | ||
9103
Rep 7,563
I linked the thread below of someone who had a similar issue. Good luck and keep us updated. https://f80.bimmerpost.com/forums/sh...php?p=20937103 |
12-27-2019, 12:10 AM | #13 |
Rep 1,602
I do two hands on the wheel to hold myself from touching the side bolsters when getting in and out. I did not do this in my 350z and the cloth seats did eventually tear a bit. Probably regularly cleaning the leather there is a good idea too.
It makes me feel kinda bad putting a bunch of weight/pulling force on my steering wheel, but I figure it's built to take a fair amount of abuse. Maybe I'll try to figure out using my left hand on the roof instead or something since I don't wear rings. |
12-27-2019, 12:54 AM | #14 |
Rep 1,092
To be honest I think those covers look worse than worn bolsters. I'm keeping my car forever and accept the fact that I will probably reupholster the seats at last once.
12-27-2019, 12:59 AM | #15 | |
9103
Rep 7,563
Best you can do is replace it when it becomes worn and just move on. |
12-27-2019, 02:22 PM | #16 |
Rep 6,634
12-27-2019, 10:36 PM | #17 | ||
Rep 13,089
///M is art ↔ Artemis
12-28-2019, 11:31 AM | #19 | ||
449
Rep 1,098
Many folks like to drive with their arms fully extended (for comfort, I guess). But that limits your motion, in case of an emergency maneuver. For maximum range of motion, you want your arms bent almost 90 degrees when holding the steering wheel. That was also what they taught us when I did a BMW driving class (factory delivery in Spartanburg, SC). Notice how close the professional drivers have their steering wheel. The first thing I do with any car (usually rental, not friend's cars), I pull the steering wheel to the maximum it will go towards my chest. Then I adjust the seats to fit my legs. That leaves not much room for entry/exit and inevitably I rub on the bolsters. |
12-28-2019, 03:45 PM | #20 |
Rep 1,602
Appreciate the tips! I don’t sit too far from the wheel, so I should be close enough to try out a few different ways of using it as leverage. I like the idea of using the steering lock as I know that’s a mechanical component that’s pretty robust.
12-29-2019, 03:41 AM | #21 | |
Rep 13,089
Furthermore, you definitely don't want a steering wheel with airbag way too close to your upper body. A steering wheel can kill you. See for example also here from 01:33 onwards:
12-30-2019, 11:28 AM | #22 | |
449
Rep 1,098
It's the same philosophy : get the wheel close to you for better range of motion. Folks here drive with their arms fully extended, gangster style. I pull the wheel as close to me as possible and if I put my wrist on top of the wheel, my shoulder blades come off the seat. Maybe I have short arms relative to my long legs... |
