01-26-2020, 10:24 PM | #155 | |
Rep 267
01-27-2020, 09:26 AM | #156 |
Rep 775
Just to add that to this list, about 6 months ago my right rear turn signal failed and I got it replaced under warranty. Recently, my left rear turn signal failed as well. Booked in next Friday to get that replaced too.
Seems to be a very common fault. What frustrates me is that, in warranty, this wastes my time. Out of warranty, this will cost a lot of money (replacing the entire light unit). I just hope BMW honour replacements outside of warranty because it's a clear design fault. On top of that, I hope they are being sustainable with regards to the units and refurbishing/repairing them. If they are chucking all these units on the dumps simply because of a grounding wire issue, that's just wrong. I'm not even a "greeny" but the thought bugs me. |
01-27-2020, 10:52 AM | #157 | |
Rep 643
Good to know if out of warranty.... |
04-19-2020, 01:50 PM | #159 |
Rep 278
Last time I've been to the service, they have replaced one of the lights (I think front one) but not because of that. Because water were entering and the vents didn't work.
Anyhow, as for the turn signal issue, I have to say that I can reproduce it a lot more during this Corona crisis as I'm driving the car once every few day and the first time that I start the turn indicator, it gets this warning and blinks fast. After the first it usually do not reproduce. Hopefully after the crisis I'll visit the service again |
05-12-2020, 05:50 PM | #160 |
Car Guy
38
Rep 115
You can add me to the list of having the right rear tail light failure. It’s happened 3times in two days.
2018 BMW M2 Long Beach Blue
2022 Lexus IS 350 F Sport |
05-12-2020, 08:49 PM | #161 |
Rep 386
Well crap, I just ordered Euro Spec LCI taillights for my Pre-LCI M. Has anyone done the PreLCI to LCI Tail light swap then experience this issue afterwards?
Hopefully just a wiring issue vs. faulty Taillight :/ |
05-12-2020, 08:51 PM | #162 |
Rep 6,937
Drives: 2018 M2 AW DCT
Mine was a wiring harness problem. Nothing to do with the tail light assembly itself.
05-12-2020, 09:07 PM | #164 |
Rep 6,937
05-12-2020, 09:28 PM | #165 |
Car Guy
38
Rep 115
I hope that all it is. I tap the tail light and then it works properly afterwards.
05-13-2020, 01:59 AM | #166 | |
Rep 8,970
It's an odd design, usually tail lights fit over an opening in the bodywork with a seal, and the electrical connector is INSIDE the vehicle - i.e dry. On the 2 series, the entire light assembly sits outside the vehicle body incuding the eletrical connector and is open to the elements. To make matters worse, the drain gulley for the trunk lid and rear window means that water and muck runs behind the light fitting and all over the connector. Every time it rains or you wash the car then water is pouring directly over the connector. The narrow space behind the light gets full of dead leaves, pine needles, muck etc or whatever else gets caught in there and stuck around the connector plug. |
CSBM52721.00 |
05-13-2020, 04:55 AM | #167 | |
Car Guy
38
Rep 115
Thanks doughboy. I pray that this is the fix. Not a smart design from the Germans.
05-16-2020, 02:24 PM | #168 | ||
Rep 2,067
Hopefully they don't see this thread and I can Lemon it🙂 2021 m2c here I come lol |
06-07-2020, 02:32 AM | #169 |
Rep 278
Yesterday I went for a very short drive and the right rear turn signal message hadn't stopped from showing and the internal turn signal indicator ticked fast which indicates that there's a problem.
On the one hand this is a good thing because issues that aren't easily reproducible will usually get regected by the service. On the other hand it means that I have to go to the service today because it is illegal to drive without a rear turn signal indicator. I'll try to see today if it is still constantly reproducible and if it is, I'll go to the service and report back with what have they done |
06-09-2020, 12:53 PM | #170 |
Rep 278
Drove to the service today. After a few hours of inspection they called me and said that they want to replace both rear lights as part of manufacturer warranty. Tomorrow I'll get back the car but I assume that it'll take a while for me to understand if the issue has been solved permanently.
Cross fingers |
06-16-2020, 11:24 AM | #171 |
will pay to drift
22
Rep 24
So...
has anyone who got their taillights replaced under warranty, run into the problem again with their new and replaced lights?
I had this issue pop up like 3-4x in the first year, and now in the second year it pops up all the time. I live in Oregon where it rains a lot, and it sounds like there's poor protection to the elements and car washes... which seems like an idiotic design to me. 2020 M2C here. |
06-16-2020, 12:49 PM | #172 |
Rep 278
Oops.. for some reason I thought I replied with what they did.
They have replaced both rear tail lights under warranty. So far so good but I assume it is too early to judge. I'm thinking of replacing the car so I'm not sure how long will I have it but I promise to report back after I'll replace it. |
06-16-2020, 02:39 PM | #173 | |
Rep 8,970
But no issues since I cleaned and dried them and squeezed clear silicone grease into the connectors body and sockets 12 months ago after the fault first appeared. Sorted... BMW will replace the whole light because that is what their computer tells them to do. Thinking doesn't really come into it. Also they'll update the car as part of the warranty process, so I'd lose my OBD tuning access as mine's not been updated since new in 2018. |
06-16-2020, 03:11 PM | #174 | |
Rep 6,937
06-16-2020, 04:35 PM | #175 | ||
Rep 492
06-16-2020, 05:10 PM | #176 |
Rep 6,937
I used Nathan Morrisette at BMW Seattle. Alex was on vacation. But I was extremely impress with Nathan and will use him for my next service. He really cared about solving the problem.
