10-19-2022, 03:36 PM | #1 |
The Seeker
13945
Rep 3,349
More turbo lag after Stage 2?
Just a quick question for those that might know.
Last year when I went to the Dragon (re: 318 curves in 11 miles, mostly 20-60 mph) I found that I could pretty much keep the car in 3rd gear most of the time with the odd downshift here and there for the really hard corners. I also don't remember feeling much lag. This year I'm now BM3 Stage 2 91 octane with an OTS map (CSF intercooler/charge pipe/Fabspeed downpipe). I use the 91 map but run 93 exclusively. Anyway, I found that I was actually in 4th gear most of the time on the same road, and at lower rpm's, which seemed to cause a lot more feeling of turbo lag. I imagine it's because the car has more power/is faster and therefore I'm needing to be in a higher gear sooner, but because of that I'm at a lower rpm, which is making the car feel more laggy. Has anyone else experienced what they would consider more lag on Stage 2 compared to stock? |
10-19-2022, 03:37 PM | #2 |
Rep 4,171
Post a log - could be a boost leak from when you installed the Charge Pipe/intercooler, or it could be what you say. Does the car feel responsive from a stop? Were you in Sport mode?
Mods: Yes.
///MPhatic13945.00 Mr_M//123.50 |
10-19-2022, 06:36 PM | #3 | |
The Seeker
13945
Rep 3,349
It feels responsive, and faster for sure. Sport mode, yes. It was a situation where I wanted to leave the car in gear, so I was off-throttle and then back on at 2,000, 2,500, etc, over and over. Same as last year, I just didn't notice the laggy feeling as much. |
10-19-2022, 07:47 PM | #5 |
Rep 3,701
I had something similar back in the day. Went away when I installed the MST V2 turbo inlet, Turbosmart BOV and Evo 3 IC (all at the same time).
IDK which of those items contributed the most, but guessing it was the turbo inlet. |
///MPhatic13945.00 F87Tomei268.50 |
10-19-2022, 07:51 PM | #6 |
Rep 4,171
10-19-2022, 08:41 PM | #7 |
Rep 647
This is just called being in 4th gear at 2000rpm.
The engine feels more responsive in that type of driving higher in the power band. Downshift. 4th gear 2000-2500 is not where I’d be running the snake. It’s called spirited driving for a reason. Car revs to 7. Let it eat. |
10-19-2022, 10:10 PM | #8 | |
The Seeker
13945
Rep 3,349
Next year I'll have the MST inlet and TS valve. I'll do some testing before that as well. |
10-20-2022, 07:21 AM | #9 |
Rep 643
in bm3 app, "learned adaptations reset", "reset all". i've realized that the car gets lazy when it adapts to daily driving.
you can try this at home. do the adaptation reset, then go for a drive.
M235i rwd 6mt
AmuroRay2308.50 ///MPhatic13945.00 |
10-20-2022, 08:02 AM | #10 |
Rep 583
I'm no tuner but I assume it's entirely possible that because the stage 2 map makes more power up top, that it decreases the amount of boost/power lower in the rev range.
But otherwise yes like the poster above, what do you really expect at 2000rpm? |
10-20-2022, 08:34 AM | #11 | |||
The Seeker
13945
Rep 3,349
I guess I could be misremembering how much time I spent in 4th gear last year, but that'd even be worse considering I don't remember any lag issues then. |
10-22-2022, 05:14 PM | #12 |
Rep 140
I noticed a significant amount of lag introduced once I installed the CSF intercooler. Pretty sure it's cause it's just so massive.
10-22-2022, 08:33 PM | #13 | |
The Seeker
13945
Rep 3,349
I don't know how many people I've told (a lot), but my car is no more fun with more power. I'm considering returning it stock. |
10-23-2022, 01:11 AM | #14 | |
Rep 554
I have a Wagner Evo2 Comp and couldn't detect any increased lag compared with the stock intercooler even initially on stock tune. I believe IAT's run slightly higher compared to the CSF but are not an issue even with the hardest of street driving. I'm very happy with my custom stage 2 tune (incl custom throttle mapping & the 6MT load drop fix). |
10-23-2022, 09:00 AM | #15 | |
The Seeker
13945
Rep 3,349
At some point I'd like to have a custom tune, once I get my inlet and BOV, but it's the same can of worms. I think there are 11ty billion threads fighting about those as well. |
10-23-2022, 09:31 AM | #16 |
Rep 647
Monitor IATs and you may change your tune. That massive, heavy CSF intercooler produces consistently low IATs and these cars need all the help they can get.
Out of boost without the help of the CSF intercooler IATs get insanely high, and quick. |
10-23-2022, 10:13 AM | #17 | |
The Seeker
13945
Rep 3,349
My motivation in going Stage 2 was to pick up anything BMW may have left on the table for free without sacrificing drivability and reliability. To that end I've certainly made the car faster, and probably not sacrificed any reliability, but I've also made it a bit less enjoyable to drive. I'm hoping the MST inlet and Turbosmart BOV will help. |
10-23-2022, 10:14 AM | #18 | |
Rep 4,171
10-23-2022, 10:16 AM | #19 |
The Seeker
13945
Rep 3,349
10-23-2022, 10:55 AM | #20 | |
Rep 4,171
Trust me, I live in Florida with 90 ambients, and you MIGHT get a pull with full power before it cuts off. |
10-23-2022, 05:58 PM | #21 | |
The Seeker
13945
Rep 3,349
I don't think I have any leaks, car runs great, it's just not as responsive as it was when it was stock. |
10-23-2022, 06:09 PM | #22 |
Rep 554
Any factual data to support this? Goes against the general & accepted principle that 1 compromise of a bigger IC is increased throttle lag (though the Wagner Evo3 seems to go against that, maybe better engineered).
