BMW M2 Forum > BMW M2 CS Model > Missed my M2 CSR had a M2 CS. Why not make a Hybrid?
      10-24-2022, 08:38 PM   #89
aroundelway
Drives: M2 CS
Apparently the change is drastic. Car is expected to be stable and planted
Be careful here about what you expect. I have modified many cars for track use including being about 20k into suspension mods for my CS and the difference is not night and day, especially with cars that are as well setup from the factory.
My modifications mean the car is better on the track and the setup will likely stay closer to the desired settings under track use with sticky compounds.
However if you want bang for buck? Swap the brakes out for smaller non comp calipers, slap 18 inch 305s on square and have at it.
      10-24-2022, 11:38 PM   #90
aparedes
aparedes's Avatar
302
Drives: M2CS
I am not expecting more than what a sport sedan will be capable of. We will see, parts will arrive soon - however they seem to be making very fast BMWs at the Nurburgring, can't wait to try it either way.
If I need a more precise track machine ...thankfully I have that cover too
      10-25-2022, 07:56 AM   #91
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
Originally Posted by driver91 View Post
Are you running square set up on the 18s what size ? I'm thinking of trying to sqweeze 285s under it after we do the front brakes
Yes square setup. I think 275 Toyo RR's. Need to check.
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy)
      10-25-2022, 05:12 PM   #92
driver91
Drives:
I have to say the stock dampers have been incredible car planted and predicable
ptgltw3777.50
JoeMatt160.00
      10-26-2022, 11:36 AM   #93
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
I run square yes. I believe 275 all around. I do have camber plates on front. -2.5 and -1.5 works well for me
The CSR is square setup as well. We could have fit larger rubber under that one but chose not to for DE
The limited factor for me with my setup isn’t from a lack of grip. Tons of grip for me. Drivers skill I could always use some work
      10-27-2022, 07:15 AM   #94
sdhotwn
Mmmm... Bavarian
sdhotwn's Avatar
2129
Drives: M2 CS, X5 45e, i3, Cayman S
Odd that the more you do it the more this is the realization, versus early in the journey when we all originally believed "just need that mod to be faster!"
M2 CS
2023 CB X5 45e
2018 i3 94
2014 Cayman S
ptgltw3777.50
      10-27-2022, 10:38 AM   #95
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
So true. It's a complete mindset. I found this to be true as a former professional golfer also. Growing up without any money, learning to work with your mis matched set of clubs. Learn to use what you got first.
Back to cars, I cut my teeth on E30 M3. Try being fast in those lol.
The pros with the race cars are 2 flat at VIR. If I get there with the street car setup as is, then maybe I can look into more mods. At moment I'm at 2:06.25 after essentially one day of tracking.
Loads of potential left but A LONG way from 2 flat.
A basically stock M4 GTS with a good alighment and Randy Pobst behind the wheel did 2:03 ish. My fastest time in the CSR was 2:04.xx. Got this after about 8 days at VIR. That's my first goal.
aparedes302.00
Jimjamz4581.50
      10-29-2022, 09:43 AM   #96
driver91
Drives:
How did you fit 305s up front ?
      10-29-2022, 08:37 PM   #97
aroundelway
Drives: M2 CS
18’s and camber. It’s a known setup by now.
      11-14-2022, 07:10 AM   #98
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
The camber plates are making so much noise either something is wrong or it's just the way they are. Going into shop today for diagnosis.
Could also be a strut failure. I'll find out soon, just dropped her off.
I'll likely go back to factory shock plate setup and get the camber from the bottom via SPL control arms.
Headed to Daytona early December !!
      11-14-2022, 04:33 PM   #99
FaRKle!
Let me guess, Ground Control?
One thing about using the SPL lower arms for camber is that they reduce the clearance from the tire to the upper fender. I was getting rub on heavier compression there with 265 tires on 9.5" ET22 wide wheels.
chris7197334.00
      11-15-2022, 07:37 AM   #100
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
LOL so yeah. Ground Control. What a mistake. No way they can handle the rigors of the track forces the M2 CS sees.
With the car on the lift you could take the entire shock assembly back and forth on the drivers side. Like 2" play lol. The passenger side had about 1/4" wiggle. Refund coming.
So we decided to forgo SPL parts all together and ordered Vorshlag plates which at the time of our build was backordered.
This should solve things quit nicely.
      11-15-2022, 10:54 AM   #101
FaRKle!
Wow, that's a lot of play! Where's it coming from on the GC plates?
When you install the Vorshlag plates make sure the bolts holding the plate to the shock tower aren't "too long" on the engine side of the plate or they'll limit the travel. Also, if you're going to really high camber, you'll need to check the same for the engine-side bolt that connects the alu brace to the top of the camber plate (I replaced my stock bolts there with M8x1.25 x 20mm long and a washer).
      11-15-2022, 09:00 PM   #102
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
Thanks. Don't you use the factory strut tower bolts for the Vlag plates?
      11-15-2022, 09:18 PM   #103
FaRKle!
You can use the factory strut tower bolts, but they also provide their own. The factory bolts are longer than needed, and protrude down through the plate. This can cause the spring perch flange underneath to contact them if the camber is adjusted to a high position (see @ 10:49 in my video below).
      11-21-2022, 02:16 PM   #104
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
GC Camber plates after 1 weekend. Installed by a professional shop.
Vorshags in now. Quite for the time being. Daytona coming up. Will report back.
      11-21-2022, 03:31 PM   #105
FaRKle!
Wow, how does that wear even happens in those locations? The rubber isolation boot and bump stop should be preventing that wear. Did your shop not put the bump stops in and the top of the damper is hitting the camber plate? As much as I'm not a fan of GC, I'm not sure this one is due to their design.
If you look at my video below at 15:57 I show where the GC bump stop is supposed to go, which should be preventing the wear seen on your plates.
      11-21-2022, 05:59 PM   #106
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
No idea. The crux of my issue was...
The strut nut came loose and the strut bolt came below the camber plate monoball. I was running around VIR at 150 mph like that.
I'm told by my BMW factory mechanic the new plates are snug as a bug with zero noise. Let's see if I can change that with a few laps around Daytona, lol.
He also said these have lock nuts so it won't come loose. What a S*&T design GC is.
      11-21-2022, 07:16 PM   #107
FaRKle!
I'd still encourage you to double check you have bump stops installed (can be done just jacking up each of the front corners and trying to feel it within the rubber boot. Don't even need to take the wheel off). Even a good design like Vorshlag will suffer if they're missing. If you didn't give the OE front bump stops to your shop to swap in when they took the GC out, you might not have them...
      11-22-2022, 01:21 PM   #108
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
Mechanic said factory bump stops are in (and were in) and are in perfect condition.
      11-22-2022, 03:51 PM   #109
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Damn, that is scary. I have used Vorschlag on my 1M for 5 years, approx 30k miles and probably 30+ lapping days. Still tight.
ptgltw3777.50
      11-22-2022, 05:17 PM   #110
ptgltw
ptgltw's Avatar
3778
Drives: BMW M's
BMW Factory mechanic said the side that was making the most noise wasn't even the side that had the loose strut nut issue lol. All I can think of is:
Glad I'm safe.
GC will be on nothing even remotely getting close to the track again.
Fine for the street for a 190 hp E30 M3 lol.
