06-03-2021, 10:32 AM | #24 | |
Rep 342
243Racing1447.50 |
06-03-2021, 10:56 AM | #25 |
1448
Rep 1,414
Great! That's a pretty strong confirmation that +20 is the preferred offset for an 18x10; making the 18x10+25 with a 5mm spacer fitment the most preferable.
I had 15mm spacers on the front and it completely ruined the steering. I don't know if being able to rotate is a big enough benefit, especially when we burn through really sticky tires in 3-4 weekends... |
06-07-2021, 10:52 PM | #27 |
Rep 753
Supercar 3R Short Review
I ran the 3R this weekend at Thunderhill Raceway. It was 90-100°F ambient all weekend. This was my first time ever with r-comp tires and it was the first time at Thunderhill with the M2. My car has -1.9° front camber with zero toe, stock rear alignment specs, Pagid RS29 pads, Castrol SRF fluid. TireRack heat cycled these before shipping them to me. Tires were 245/40/18 front abs 265/40/18 rear on 513M rims.
I found the 3Rs to be a bit "greasy" throughout the pressure range and they felt like a less precise RE71R. That being said, they are very progressive at losing grip and intuitive when they start allowing for time to correct as long as you're not overboard. I did 4 sessions each of the 2 days with total mileage around 190 over the 2 days. I think I have another day, maybe 2 at most on these. Looking at the wear pattern, I believe more camber would help these tires as you can see the outer edge wearing faster than the main tread face. Overall, I am not so sure I would get these again. Will likely go back to SC3s once these are done, unless they turn out to be substantially quicker on my local track compared to the 3s. [IMG]https://media.fotki.com/2v2aect3Lxu6LVA.jpg[/IMG] [IMG]https://media.fotki.com/2v2aectvgxu6LVA.jpg[/IMG] |
06-08-2021, 06:38 PM | #28 | |
Rep 555
IG: M2C_SO |
06-09-2021, 08:34 AM | #29 | |
Rep 753
06-09-2021, 05:38 PM | #30 |
Rep 342
I am very interested to read your findings as you increase camber (especially if you keep everything else consistent). I do wonder if that alignment is keeping you from fully experiencing the tire though. Everything I've read says that it is an extremely capable tire and should be quite a bit quicker than a non-R SC3.
That aside, I have only run my car at -3.2° front with the 245/265 SC3 and found the car quite manageable and safe (i.e. understeer biased). |
06-10-2021, 08:29 AM | #31 | |
1448
Rep 1,414
09-02-2021, 02:27 PM | #32 |
Rep 95
For anyone that has ran the Supercar 3, what is your target track pressure?
Heading to my first track day on Monday with a new set. I have a lot to figure out with a new car, new track, new suspension. Lots to dial in. Just looking for a ballpark pressure. I'll obviously will fine tune to what I need but any prior experience is appreciated. Thanks, JJ
Current: 2020 X3M, 2022 911 GT3
Past: 2020 M2 Competition,2018 X3 M40i,2017 X3,2016 VW ,Golf R,2015 BMW M3,2010 VW GTI,2008 911 GT3,2005 VW GTI,2002 VW GTI 337 |
10-17-2021, 11:42 AM | #33 | |
Rep 127
1997 Dakar M3
1999 Cosmos M3 2004 Imola M3 CSL clone 2017 Alpine White M2 Performance Edition |
10-20-2021, 08:14 AM | #34 |
Rep 753
I am on my second set of SC3s (255/40, 275/40) on 513Ms. This time I have KW Clubsports on the car and -2.8° front camber (zero toe). After 4 days on them, I still like the feel and feedback. However, I am sensing a slight drop in max grip - almost as if they are starting to heat cycle out. They still allow for a good pace and fun, but not sure if I'll be setting a PB on these. I'd still recommend these tires for anyone looking for a 200tw track day and streetable tire though.
12-28-2021, 04:52 PM | #35 |
Rep 1,730
Adding my own experience to the hive. I'm just about done with my first set of sc3r's and they're an amazing tire. I run them on my e46 m3 race car, at about 2900 lbs with me inside.
They have very impressive and predictable grip. Each day I go out, I make new PB's. They do not have a long life, as I'm 12 sessions in with street driving to/from the track and the tires are nearly bald. It probably has a day or two left in them. I really hope GY comes back with more supply. I was really hoping to run these tires in TT, so I can get some points back to run more power. If not, I may have to revert back to the a052's.
2018 Grigio Telesto F80 M3 DCT | :: Bone Stock :: 2004 Titanium Silver E46 M3 6 Speed | :: Track Car :: |
01-12-2022, 04:05 PM | #36 | |
@333m2c
229
Rep 177
Drives: 2020 M2c f87 S55
I switched to Nankang cr-1 and havnt looked back i run a staggered set up though 10 / 11 (265/35/18 and 285/35/18) since the nankang run wide. You can easily do a 10 et 33 stagger around the car with nankang 265/35/18 all the way around
@333m2c / Willing to sell my soul for parts..
Build thread: "Going for Broke - a Saga" https://f87.bimmerpost.com/forums/sh....php?t=1805010 |
nando_51465.50 |
01-12-2022, 08:27 PM | #37 | |
Rep 80
01-12-2022, 10:35 PM | #38 | ||
@333m2c
229
Rep 177
Granted on button Willow and big willow which are both really hard on tires
01-17-2022, 05:12 PM | #39 | ||
Rep 485
01-17-2022, 05:13 PM | #40 | |||
@333m2c
229
Rep 177
01-17-2022, 07:47 PM | #41 | ||||
Rep 485
01-18-2022, 02:59 PM | #42 |
Rep 302
SC3R's are amazing tires if the proper air pressure is used and there is no comparison between them and the NT01. NT01 are not as consistent at all. Great tire but older technology. Also, the SC3R's can be run inside out for additional track days etc and are just as fast in the dry.
On my ZL1 1LE I would get over 3 full weekends of running SC3R's by flipping them around due to not running square setup |
01-27-2022, 11:10 AM | #43 |
Rep 684
I run the Bimmerworld forged wheels 18"x10" ET33 with 12 mm spacers upfront. Front wheels rub without spacers, but I could probably run with smaller spacers around 7-8mm. But since BW recommended 12mm spacers, that's what I ended up running.
I also run Michelin takeoffs, since they are by far the best bang for the buck. I get great performance out of them the first 2-3 heat cycles, after which they drop off. But since keeping cost down is important and I still get good performance out of them even after 12-15 heat cycles, I'll end up running them for at least two weekends. Here are a few pics and a video from Summit Point from this fall. |
