01-25-2021, 06:47 PM | #45 |
Rep 2,819
Drives: e82 1M, f87 M2cs
LOL . . .Oops again
01-25-2021, 07:53 PM | #47 | ||
Rep 3,102
Drives: 21 Vantage, 18 Vantage, 00 WRX
I mentioned coilovers as these have matched shocks and springs and allow you to adjust ride height via a perch, which will retain good suspension travel. There are many different types and all have compromises. If you go for the fastest lap setup your car will be a pig on the road. The CS is a lovely compromise out of the box. You can set the car up for better track times with coilovers and a corner weighted track alignment but then your car won't be the great all rounder that it is. Finally. It's personal preference but I really like the standard ride height. |
01-25-2021, 08:35 PM | #48 | |
Rep 2,211
Drives: G81 M3 Touring (Frozen Black)
01-25-2021, 09:15 PM | #49 |
Rep 248
I've built 6 BMW race cars in my time, and while I'm certainly not a suspension engineer, I'll throw in my two cents.
Lowering a car past a certain point is absolutely detrimental to handling. A car's control arms and suspension geometry are designed to work at certain angles. When you lower (or raise like on a Safari car) the suspension, you are altering that geometry. I've been racing a Spec E46 for 4 years (have built two of them), and as in all spec classes, we have to use specific parts. So all 100+ cars in the class have identical suspensions. The few things we can adjust are alignment, shock clicks (only single adjustable), and ride height. And as a group, we have tested, and too low of a ride height absolutely has negative effects on handling. Also, if you're lowering your car more than an inch, you need to think about your swaybar end links. If you don't replace them with the adjustable type, and dial out all of the bind, then you're screwing up the suspension even more. Suspension is a system, and each change affects many variables. I don't know anything about the BMW adaptive system, but I can't imagine it would be happy if you introduced shorter, stiffer springs, along with swaybar bind. With all that being said, lowered cars do look badass! |
8
AUSf222692.50 Hedoniste3880.50 black ming59.50 Bimmed Out1908.50 Artemis29967.50 MadBimmeRad7124.50 ///M TOWN21717.00 krm347.00 |
01-26-2021, 12:39 AM | #50 |
Rep 1,407
01-26-2021, 08:22 AM | #51 |
Senior 1Addict
5164
Rep 2,426
Drives: BMW iX, Porsche GT4 RS
Harris response
01-26-2021, 01:47 PM | #52 | |
Rep 1,657
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy) |
01-27-2021, 11:57 AM | #54 |
Luxury at the redline :)
9108
Rep 7,563
God, $300 Eibach springs on a 85k car, with unmatched fine-tuned electronic dampers, which is the distinguishing feature of the CS, over the Competition..
It must be a strange, contradictory sensation to have more money than brains... |
01-27-2021, 12:55 PM | #55 | |
Rep 1,657
I hope the finely tuned shocks don't explode from all the pressure. I'll check for leaks when I return. I may not even choose to wash it upon my return. I would type more but I gotta go drive my Eibach lowered suspension M2CS.
MadBimmeRad7124.50 hplc481.50 |
01-27-2021, 12:56 PM | #56 | ||
9108
Rep 7,563
You win bro, enjoy your eBay springs and new car.. |
MadBimmeRad7124.50 bngcruiser277.00 |
01-27-2021, 01:15 PM | #57 |
Rep 1,657
Eibach Springs. Made in Germany. Enjoy whatever your driving today
MadBimmeRad7124.50 |
01-27-2021, 01:26 PM | #58 |
9108
Rep 7,563
They are not but that's the least of your problems, when mismatching spring and dampers that are not design to work together, especially the electrical variant, that operates in tandem with the DSC, braking and overall vehicle dynamics but I'm not even trying to rain on your parade, you just keep on trucking
01-27-2021, 02:00 PM | #59 | |
Rep 1,657
But please respect others opinions especially his. I think he has earned it.
M2 CS: CF Buckets & more (track toy) Last edited by ptgltw; 01-27-2021 at 02:46 PM.. |
01-27-2021, 02:11 PM | #60 |
We've landed on the moon!
1449
Rep 906
Drives: 2011 1M (AW)
Poochie You crack me up man, I do love ya. But the argument is not that simple.
I called Eibach and spoke with them about their springs for the F80/F82 and F87. I was told that these spring are made in Germany where they are developed and tested to work with the factory dampers (adaptive or static). I was told that some springs are manufactured here, but ones that have already had the development done at Germany HQ are carried over to US market (albeit sometimes with a changed part number). I do understand the point of the "these weren't engineered for the car" argument, but to imply that they are equivalent to some knock off eBay springs is simply not accurate. Furthermore, the fact that BMW produces (via KW) a lowering option for their F80/F82 is further evidence that it can't be wholly detrimental to the handling. For example, why would the BMW kit have a limit on how much it can be lowered versus the KW kit if they weren't managing that parameter to ensure it's up to their standard and would not be doing harm to the car? For what it's worth: Eibach Springs: F82 M4 Coupe E10-20-037-01-22 Front: Linear 182 lb/in Rear: Progressive 360-628 lb/in F87 M2 Coupe E10-20-035-01-22 Front: Linear 200 lb/in Rear: Progressive 436-657 lb/in
F87EVO4059.50 MadBimmeRad7124.50 |
01-27-2021, 02:41 PM | #61 | |
Rep 1,657
Thanks for your logic thoughts and deeper research. All I know is my box of Eibach springs says made in GERMANY.
01-27-2021, 02:56 PM | #62 | |
9108
Rep 7,563
It reminds of that time a call girl told me she really likes me for my personality.. OEM shocks were not designed to work with lowered springs. It comes down to travel. Coil springs will allow your suspension to go through a certain amount of travel — both up and down — before it ends up neutral in the middle. The shock absorber has to have the same range of motion as the coil, that way it's able to keep it under control. Now, here's where the lowering springs come into play: A lowered car typically has less travel than a stock vehicle is design to rebound. Lowering the springs will lead to faster shock wear & tear, harsh noises, as it slams against the stock bump stop, due to the reduce travel, possible causing handling issues and in the case of the CS, possible check control errors. Basically, the vehicle's dampers will be operating from a point below where it's comfortable or harmonic, as originally intended for. If you want to drop your vehicle, the proper way to do it is purchase shocks and springs that are matched together, such as KW coilovers, code out the EDC and get an appropriate alignment. The half-ass, ghetto way of mismatching springs and shocks are reserved for your typical $500 hoopty, not a high-performance BMW, with electronic dampers, tuned to work with the vehicle's set dynamics. Hey, It's your funeral but just know that each one of those shocks for the CS cost a $1,000 per side, so just put some Benjamin aside for when you have to replace them in six months or so.. . |
01-27-2021, 03:08 PM | #63 | |
Rep 1,657
Anyway, let's agree to disagree on this one. 1st place pissing trophies for everyone. I would like to know one thing. Have you ever modified a car? Maybe you have replaced BMW approved and designed tires with non BMW Tires? Gotta love the hypocrites in this world. They do allow me to drop $4000 on shocks every six months so I can't complain that much.
M2 CS: CF Buckets & more (track toy) Last edited by ptgltw; 01-27-2021 at 03:20 PM.. |
01-27-2021, 03:22 PM | #64 | |
1449
Rep 906
I understand the argument behind your point. And if we were talking about slamming the car, or getting out the hack saw to cut springs then all of those points make sense. But that's not what we're talking about. If lowering you car is ALWAYS a bad idea, and ALWAYS messes up handling and ALWAYS ruins your stock shocks then why does BMW make a kit to allow you to lower their car *within a range* that they approve to their standards?
Poochie9107.50 |
01-27-2021, 03:22 PM | #65 | ||
9108
Rep 7,563
Happy for you bro but my original comment wasn't intended for anyone here specifically but you seem to latched on and took it personally.. |
ptgltw3779.50 |
01-27-2021, 03:26 PM | #66 | ||
9108
Rep 7,563
With that said, let's just leave it here and move forward. Best wishes.. |
ptgltw3779.50 |
