03-25-2023, 12:08 AM | #1 |
Rep 618
AA Single Midpipe drone at 1k rpms
I just installed my AA Single Midpipe for my M2C but I’ve noticed that it drones/makes a vibrating noise at 1k rpms but not at any other rpm. I originally thought it was the sphere clamps touching the heat shield so I retightened it so that the bolts are nowhere close. I also retightened the downpipe just in case (and I used new downpipe gaskets). However, it still seems to be happening. It’s annoying when I’m trying to cruise in efficient and the dct automatically upshifts to stay at like 1k rpm so I constantly hear it.
Anyone else have this issue? What can I do to fix it?
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
03-25-2023, 02:21 AM | #2 |
Rep 618
I have recorded a video from under the car where I think it is causing the problem. The front part of the midpipe (close to the downpipes) is fully seated against the heat shield, which rattles when I hit the midpipe. I am not sure how to reposition the midpipe so that this doesn't happen. Any ideas?
Here's the video. I also got some clips from my dashcam of what the rattle sounds like from inside the cabin if that helps anyone recognize the sound. All help is appreciated, thanks Edit: To sum it up, it kind of sounds like a sad trombone lol
03-25-2023, 02:24 AM | #3 |
Rep 618
Also can confirm that the brace is not causing the issue, I'm using the one provided by AA and it has a lot of clearance between the midpipe and the brace so there's no chance it's hitting that and rattling.
03-25-2023, 04:46 AM | #4 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Just push the heatshield in a little bit. Dont push it in that much but if everything is tightened down and your exhaust setup is solid…. You just need a few mm of clearance.
Only push it in where it slightly touching
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
03-25-2023, 09:25 AM | #5 |
24238
Rep 190,879
+1
03-25-2023, 12:05 PM | #6 |
Rep 618
Did what you guys told me to do and now it just rattles whenever it moves, what do I do now?
03-25-2023, 12:09 PM | #7 |
Rep 618
Is it possible that the heat shield is hitting the driveshaft now?
CoffeeLife397.00 |
03-25-2023, 02:35 PM | #8 |
Rep 618
Update: It’s 100% the driveshaft making contact with my heat shields. Fml. Now I have to undo everything just to rebend the shields back to their original form.
https://youtube.com/shorts/XEUnikFAjWc?feature=share
CoffeeLife397.00 |
03-25-2023, 07:26 PM | #9 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Oh yea. Definitely pushed it in too much.
You’re just pushing in the width of your fingertip enough to make a gap. The gap size youre making would be big enough for say a slotted screw driver to fit. Dont try to create a large gap.
-2021 M2C, HS, 6MT
03-25-2023, 08:32 PM | #10 |
Rep 618
That’s exactly what I was doing, the gap was only about the weight of a flathead screwdriver
03-25-2023, 08:36 PM | #11 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Ah dang thats frustrating. Did you drop the heat shield and bend it all back, then try again? Hope you had a lift available and not just a jack and stands…else thats extra annoying
-2021 M2C, HS, 6MT
03-25-2023, 08:45 PM | #12 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Another question. Is the midpipe pushing against the downpipes upward? Wondering if you can bend the first side mount connected to the midpipe.
Else ive had to cut and weld an extra 1/2” to my AA where it connected at the downpipe. Since it was pushing hard against the front heat shield area.
-2021 M2C, HS, 6MT
03-25-2023, 11:40 PM | #13 |
Rep 618
Doing that tomorrow… On jack stands.
03-25-2023, 11:41 PM | #14 | |
Rep 618
03-26-2023, 12:04 AM | #15 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Or what about the first mount (2nd arrow) any chance you can slightly bend it to give you that extra mm clearance?
-2021 M2C, HS, 6MT
03-27-2023, 01:46 AM | #16 |
Rep 618
Ended up fixing the problem, got sick and tired of it so we poked a hole in the heat shield and yanked that shit down till there was enough clearance, now runs like a charm, no rattles.
I still have exhaust leaks on the two big clamps connecting the stock muffler to the midpipe where water drips out. I was considering using a muffler tape solution like tiger patch below the clamps to solve the problem. only thing I’m concerned about is if it’s flammable. Should it be safe to use on our cars?
CoffeeLife397.00 |
03-29-2023, 05:00 PM | #17 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
What part leaks? Is there a gap between the clamps? I wouldnt put any tape down, if its just occasional water make sure the clamps are torqued to whatever spec AA recommends first. If clamped down too hard you can bend the pipe leaving a small gap under the clamp wherever the bolt pressure is concentrated on.
-2021 M2C, HS, 6MT
03-29-2023, 07:21 PM | #18 | |
Rep 3,808
