10-06-2020, 11:24 AM | #1 |
Rep 501
Future Classic license plate bracket
I purchased this slimline license plate bracket from Future Classic recently: https://futureclassic.us/products/fu...se-plate-frame
I wanted a bracket that was slim, made out of billet aluminum, and sturdy. Much to my disappointment, when I went to install it, it won't fit the standard IL license plate. The bracket is too small - in both length and width - by a few millimeters. I'm not sure if the plate grew in size (quite possible) and they never adjusted the size of the bracket they sell. I sent multiple emails to them about this issue and heard no response. Is this common? - Their website doesn't list a phone number either. I filled out the contact-us form, as well. |
10-06-2020, 01:13 PM | #3 | |
Rep 501
I'm guessing they didn't test-fit the bracket with the latest plates. And that's ok. I just reached out to them several times to see if they can remedy this, but frankly I'm a little put off by their lack of response regarding this matter. I also texted them several times using their website's "chat now" feature, only to be left stranded with no response after I explained the issue. |
10-06-2020, 01:38 PM | #4 |
Future Classic
261
Rep 995
Chiming in here, not sure why our e-mails are not reaching you but we've responded twice (once after receipt of your e-mail yesterday and again today). Sorry for the difficulties you're having—putting a plate frame on should certainly not yield any frustration. Please see the following as our latest e-mail response to you (11:17AM):
Hi Maciej, We sent you an e-mail yesterday in response. Please see below: Hi Maciej! Thanks for the message. Sorry for the difficulty—the plate should actually sit flush with the frame, not reside within it. Here is a photo album illustrating how it should mount: https://www.flickr.com/photos/mikem5...57715890899478 For clarity, I will post some photos here for reference. We have installed this plate frame on a plethora of IL plates—both standard and specialty for years. We will be happy to compare measurements of your plate versus any of the cars at our immediate disposal to help remedy your issue. The current series of IL plates appears to be unchanged since January 1, 2017: 12 in x 6 in so please verify that your new plate does indeed conform to these measurements. Pictured installed with a standard IL plate (Old) Pictured installed with a specialty IL plate Pictured installed with a standard IL plate (New) If you need further assistance, please let us know.
FUTURE CLASSIC | | Follow Us on Instagram
Melbourne E90 M3 | Jet Black E46 M3 | Techno E36 M3 | 997.2 C2S | 958 Cayenne GTS Last edited by MikeM5; 10-06-2020 at 01:46 PM.. |
10-06-2020, 01:56 PM | #5 | |
Rep 501
Anyway, I appreciate your feedback. It is not immediately obvious that the plate is suppose to sit flush with the bracket given the design. The website description of the bracket doesn't mention this anywhere either. Additionally, the screws I received don't work with the stock rear plate mount. |
10-06-2020, 03:00 PM | #6 | |
Rep 433
As you noted, the screws don't work with the stock rear plate mount I e-mailed Future Classic on 9/25/2020 about the issue Unfortunately, like you, I never received a reply and as you mentioned before they don't list a phone number to contact Here is a copy of the text in the e-mail I sent "Dear Future Classic I'm hoping you might be able to help me I purchased a Slimline Aluminum Plate Frame + Hardware Kit in Hyper Black for my 2020 BMW M2 Competition a few months ago Order # 1556 Unfortunately, I don’t think the hardware kit (which appears to be M5 x 10mm machine screws) is going to work with my factory license plate holder which is made entirely of thin plastic I believe I will need tapping screws to secure the license plate frame to the holder Is there any chance you can supply me with some black tapping screws of a similar size? I would be extremely grateful for any assistance you can provide Kind regards George" |
10-06-2020, 03:25 PM | #7 | ||
Rep 501
As for the plate, I just went to install it on the rear. I can't believe I'm saying this, but this bracket is impossible to install. It is the most confusing and weirdest design I have ever come across. If you want to install the way they recommend, it means that one of the screws will have to be longer and under great tension. It's hard to explain, unless one sees this in person. And the screws they provided don't fit at all. The stock screws are too short for them to work in one of the holes. I'm very disappointed in this bracket. I mean this shouldn't be rocket science. I'm stuck with an $80 bracket that's unusable. There's no way they used the stock screws for this. They won't grab the threads in one of the holes. Physically impossible. The included screws don't work at all. Plate description on the website says nothing about how this bracket works. One can only assume it's a normal everyday license plate bracket, but it's not. |
StephGOD218.50 |
10-06-2020, 03:53 PM | #8 |
Flavor of the month
840
Rep 692
Drives: BMW F87 M2C
You guys paid $80 for that?
Samuel of the Internet
2023 F98 X4M Comp 2023 F95 X5M Comp 2020 F87 M2 Comp |
10-06-2020, 04:06 PM | #9 |
Rep 501
10-06-2020, 05:01 PM | #11 |
Rep 333
10-06-2020, 05:07 PM | #12 | |
Rep 433
A few of things I don't like about it It uses plastic spacers between the stock plate mount and the license plate so the plate is not as flush with the trunk as before The hardware hiders are also plastic and prone to break You will need to use them or washers because the head diameter of the hardware is not large enough to secure the frame It rattles when I close the trunk (although I might be able to get rid of this by tweaking the frame and/or license plate a bit) |
10-06-2020, 06:03 PM | #14 | |
Future Classic
261
Rep 995
George, please shoot me a PM to get your the screws you need. Will have to sort out our online chat / e-mail issues.
Melbourne E90 M3 | Jet Black E46 M3 | Techno E36 M3 | 997.2 C2S | 958 Cayenne GTS |
2020M2Competition429.00 |
10-06-2020, 06:08 PM | #15 | |
Future Classic
261
Rep 995
We used this particular design to accommodate for some vintage models (both BMW and otherwise) that have a protruding trunk lock which does not allow us to achieve the thin perimeter that we wanted without mounting the frame as such. They've been a popular choice for several marques, but apparently the new BMW crowd would very much appreciate another design specifically designed to accommodate the plate within the frame. Thanks for the feedback.
10-06-2020, 06:20 PM | #16 | ||
Rep 501
Others (like the OEM M2 Competition mount) don't have these: https://www.ecstuning.com/b-genuine-...r/51139448724/ As a result, your hardware won't work. You need to send out tapping screws that cut into the plastic. That's how OE BMW plate screws look that came with my car. But because the OE BMW tapping screws are relatively short and the plastic they dig into is flimsy, it is not physically possible to mount your frame to our mount using either the provided screws or the OE tapping screws. Go try it on an M2C and see for yourself. At least one or two of the OE screws won't fasten your frame to the mount because at least one corner is too far apart from the plate due to the "flush" design. Quote:
StephGOD218.50 |
10-06-2020, 06:26 PM | #17 | |
Rep 433
10-06-2020, 06:38 PM | #18 |
Rep 3,254
I can recommend a Los Angeles Lakers license plate frame. However, you’ll get cut off. A lot. Also, you can forget about people letting you in to merge.
2020M2Competition429.00 j23654.50 |
10-07-2020, 01:46 AM | #19 |
KYHOMPB
219
Rep 461
Drives: Only BMW's Ja
FWIW I had the same exact issue(s) with my frame as well a few months back & their communication was really lacking. Ended up just trimming my plate to make it sit flush inside the frame like it should've been designed to do in the first place IMO. With that said, glad to see MikeM5 is stepping in and trying to make things right at least. PM headed your way as I need a set of the correct screws as well if at all possible.
10-08-2020, 09:02 AM | #21 |
Future Classic
261
Rep 995
Just wanted to update everyone with our plans to ensure the M2C community gets sorted:
What I will do is order some new plate frame hardware (self tapping) from the dealer and then verify the length / pitch required for the new bracket—there is no definitive screw as noted by BMW. We are amidst a testing program for some E9X and F8X product, so please bear with us for a week or so as we are trying to take advantage of the nice Chicago weather before winter barrels down upon us. The bracket changeover occurred on 01/19. That said, both P/Ns strangely have the exact same application lists: https://bimmercat.com/bmw/en/parts/i...0607/appliance https://bimmercat.com/bmw/en/parts/i...8724/appliance Because of this, there wouldn't have been any way we could've known about the switchover to self tapping unless BMW released some sort of bulletin for such a small part, which they wouldn't. That said, we will be putting in the work to ensure we source the self tapping variant in anodized form and then adding a dropdown for users wherein you can select the right hardware type for your needs. Affected users will certainly get these new units at a discount once they are available to help quell some of the frustrations that we did not foresee. We feel bad that M2C owners have been so heavily inconvenienced by this and it's painful to see our reputation for excellence tarnished by screws. Nevertheless, we consider our hardware offering to be a really nice icing on the cake with our beautifully machined / hand-brushed frame and we will get a hardware type dropdown implemented as soon as possible. Thank you all for your support and help!
10-08-2020, 09:19 AM | #22 |
Rep 32
Mike, appreciate the update. I was affected by this too. I got around it by slightly drilling out the backing plate holes, which allowed me to use the screws included in the FC frame kit. It feels sturdy, but I'm sure self-tapping screws would be the way to go.
Edit: Mike, I purchased my frame through IND in June of this year and originally emailed them about the included hardware. They replied, CCing info@futur..., but it doesn't look like I ever got a response. Just another data point for you in case it helps track down any issues on your end. |
MikeM5261.00 |
