12-15-2019, 06:28 AM | #89 | |
Rep 121
https://youtu.be/LnU29c7USCA |
12-15-2019, 12:14 PM | #90 | |
Rep 6,635
12-16-2019, 03:19 AM | #91 |
Rep 121
My Test Drive
I went on a test drive in an M2 Competition today. In the whole country of Kangaroos and Koalas, there is only one M2 demo car with a manual transmission. Unfortunately, it is located in another state. I thought about flying over, but the sensible part of my brain won the argument. So I ended up testing the DCT model. I drive out of the dealership carpark with a level of excitement akin to a child at Christmas. I switch the DCT into Sports mode. It seems like good, middle ground, choice - somewhere between the Grandpa mode and I-am-the-Stig mode. After all the feedback I received here, I wanted to experience for myself how the automatic mode operated. I understand that all sequential gearboxes must predict the future - will it be an upshift or downshift next? If the DCT predicts accurately, all is good in the world. If the prediction is wrong, a slightly longer shift time. I perform a u-turn and accelerate moderately. The M2 revs out quickly and shifts into 2nd gear. Once I reach the speed of 35mph (56kph), I back off the accelerator to coast. Instead of shifting up into 3rd, like all the other automatic transmissions I have driven, it hangs in 2nd gear. Thinking, it's the Sports mode, I switch to Comfort mode and try again. It isn't any better. I think the DCT gets confused if I accelerate and then back off. In frustration, I shift up manually. I stay in the manual mode but switch back to Sports mode. With the sales guy in the car, I have to behave myself. I downshift a gear. The rev gauge displays north of 3,000rpm, so I drop the hammer. The backend wiggles a little and the M2 launches. I'm smiling on the inside. Actually, I'm yelling "Ehh-Ha!" without making a sound. I try changing gears by the sound of the engine, but as I am unfamiliar with the acoustics. I end up upshifting too early, some of the time. In a quiet side street, I was able to test the 1st gear to reverse and back to 1st again. I thought the DCT shifted reasonably quickly. I can't imagine changing quicker in a manual transmission. Satisfied that I would be able to perform a 3-point turn, I get back on the road. The traditional automatic transmission annoys me because they wouldn't shift when I wanted them to change. They are either disobedient or slow - often both. I'm in 4th gear on a quiet road with no traffic. I decide that this is a perfect time to test downshifting. I pull on the -ve paddle and nothing happens for an eternity. It was horrible! I try again, and the result is the same. I can initiate the downshift and say, "0ne-Mississippi" before the actual gear changes. I'm about to take the car back to the dealership when I remember the DriveLogic button located behind the DCT. I press it twice - 3 bars appear next to the gear indicator. Now the gear shifts up and down as expected. Much better! I find my way to the highway. I turn right and rocket up the on-ramp. The 1st gear passes 6,000rpm, but I can't upshift. The +ve paddle has rotated around the steering wheel. I reach for the floor shifter and pull on it. The gearbox upshift in a blink of an eye. I like this! It is growing on me. I upshift as the revs approach the redline. It is a lot of fun! I repeat until we are cruising in 7th gear at 70mph (110kph). Knowing that the 7-speed DCT has a taller gearing than the 6-speed manual transmission, I downshift into 6th gear and maintain the velocity. I listen out for the change in engine sound. It is a little louder, but not bad. I downshift into 5th gear, and engine noise increases slightly. For the next few miles, I shift between 5th, 6th and 7th, and back down again. The majority of the cabin noise is from the contact patch of the bloody wide tyres and the wind noise. I don't think the 6th vs 7th gear made much of a difference. Satisfied that I know which transmission I want in my new car, I drive back to the dealership. It takes about 2 hours to finalise the deal. I pay the deposit, and now the waiting game begins. The estimated delivery date of Hockenheim Silver M2 Competition is late April. Thank you, everyone, for your advice and suggestions in helping me decide on the transmission. Update: Last edited by ///Driver; 12-16-2019 at 05:33 AM.. |
12-16-2019, 05:16 AM | #92 | |
Rep 425
12-16-2019, 05:40 AM | #94 | |
Rep 253
12-16-2019, 06:59 AM | #95 |
Rep 1,153
In Canada DCT is 3900$ + 15% tax so it makes the choice easier. The DCT is really nice but I would probably have gotten an RS3 or something like that if I wanted auto. If BMW sold the M340i wagon over here, I would have strongly considered it.
12-16-2019, 08:17 AM | #96 | ||
Rep 1,049
**BTW, you don't need to remove any panels to install the clutch stop. Lay down in the floor board and look up behind the clutch (between the rubber cutout). You will see a small white rubber nipple, that's the stock clutch stop. Just pull it out, and slide the BMS one in place. Takes all of 30 seconds, once you see where it is located. |
12-16-2019, 09:41 AM | #97 |
Rep 1,263
Get the UCP...It solves this...My pedal now engages right off the floor w/o using a mickey mouse Clutch Stop....
12-16-2019, 09:54 AM | #98 |
Rep 1,049
12-16-2019, 10:37 AM | #99 | |
Luxury at the redline :)
9105
Rep 7,563
Not that I have a problem with shifting but I can't wait until the springtime so I can try this mod to discern the difference, without the risk of wearing out the synchronizers. *Newer* CDV Delete Method (Easier Way!) https://f30.bimmerpost.com/forums/sh....php?t=1666477 |
12-16-2019, 10:52 AM | #100 |
9105
Rep 7,563
And to the OP, if you picked the DCT, you always wanted one.
No one gives up a manual because the DCT is better. Yes, the DCT is more effective but the manual is more enjoyable. Why do thing there is a "manual" mode in the DCT; there is no "auto" mode in a manual. But I'm not even trying to crap on your decision, enjoy the car, they're both fast and fun, nonetheless. |
12-16-2019, 11:21 AM | #101 | |
Rep 6,635
12-16-2019, 11:25 AM | #102 | |
Rep 6,635
Poochie9104.50 |
12-16-2019, 11:28 AM | #103 | ||
9105
Rep 7,563
That's what I get for skimming through Bimmerpost, at the stop lights |
12-16-2019, 02:55 PM | #104 |
Rep 121
Sorry about the tease... I couldn't help myself.
I did choose the manual transmission. The DCT might have worked for me IF I could have driven it like a regular automatic at times. The moment M2 moved off the set of lights (gently) with other cars in full automatic mode, it clunked and jerked forward (when the clutch engaged?). I have read that DCT can do that if I didn't let the car roll forward a bit before applying the gas. I didn't want to re-learn how to drive. However, it did behave itself in manual mode. So, I would classify DCT as a clutch-less manual transmission in its mannerism. If I owned DCT M2C, I would have to ignore the automatic mode even existed. Combine that with unexpected behaviours during the test drive, DCT was discounted as a viable option for me. I have visited 3 dealerships, but no one had a manual transmission M car - not just M2 but M3 or M4 or other. I even asked about a regular 2-series in manual transmission but none in stock. I have never purchased a car without testing the transmission, as much as the car itself - but there is the first time for everything! I laughed out loud when I read the sales contract - 'Factory Option: S0Z9A Delete automatic transmission'. I will post my impression of the manual transmission - nothing you guys don't already know, but it might help another newbie. That will be in April or May 2020. Thanks again, everyone! All your comments, pro-DCT and pro-6MT, all helped me heaps. Last edited by ///Driver; 12-16-2019 at 03:22 PM.. |
12-16-2019, 02:59 PM | #105 | |
Rep 1,263
http://www.ultimateclutchpedal.com/ I know this because I ran a clutch stop on my E36M3 for many years. My 1/2 syncro was toast after lots of auto x and track work. I had to swap in another used unit. I can't think of any other add on that would have caused the tranny to act up.... So I will never use one again..
Conissah1576.00 |
12-16-2019, 03:05 PM | #106 | |
Rep 1,049
12-16-2019, 03:41 PM | #107 | |
Rep 121
I did think about the RS3 briefly, but like many AWD cars, they are prone to understeer. But the real deal-breaker for me was their reputation (after sales support). They still sell plenty of cars to average punters, but not many people go back for the 2nd round. And car forums like this are valuable resources for folks who research before buying goods. If we review hotels on TripAdvisor for $150, it makes sense to ask past and present owners. |
12-16-2019, 04:40 PM | #108 |
Rep 463
I have seen many, many people who regret buying a DCT (or automatic) but not a single person who regrets buying a manual.
///Driver59.50 BMWF87Melb201.00 |
12-16-2019, 05:01 PM | #109 | |
Rep 1,602
Incidentally, that DCT transmission is pretty expensive here in the states as well at $2900 USD. But quite frankly, i would've paid more for a manual if i had to. Anyway, good luck with the waiting, i'm guessing now you'll be off to obsessively watch every single search result for "M2 Competition" in YouTube. I know I did! |
