12-14-2021, 09:39 AM | #89 |
Rep 2,989
Drives: 2019 M2 Competition
thanks man, and so much more to come!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
cdavis93140.50 |
12-15-2021, 09:30 AM | #90 |
Rep 2,989
Full midpipe sound comparison video is up!
12-29-2021, 09:58 AM | #91 |
Rep 2,989
Intake wrap DIY is up!
IM2C2065.00 |
12-29-2021, 02:49 PM | #92 | |
Rep 51
Present
20 M2CS HS | 23 i4 e35 Past 19 Z4 30i | 21 M340i MPE BSM | 17 M2 MGM |
12-29-2021, 07:04 PM | #93 | ||
Rep 2,989
///M TOWN13119.00 |
01-05-2022, 09:41 AM | #94 |
Rep 2,989
The downpipe blanket DIY is up!
trainerjon48.50 |
01-12-2022, 10:18 AM | #95 |
Rep 2,989
the install is up for the Armaspeed CAI and man it is great! Just gorgeous!
01-26-2022, 09:48 AM | #96 |
Rep 2,989
The Active axle back exhaust is installed! This is amazing!
trainerjon48.50 |
01-27-2022, 07:36 AM | #97 |
Rep 180
Drives: 2017 BMW M3 Competition (LCII)
Interesting content and great car man. I wonder if you could tell me the difference between Soundskins Pro and Soundskins Pro Plus?
BMW DIY Guy3001.50 |
01-27-2022, 09:09 AM | #98 |
Rep 2,989
The only difference is just size of the material itself. The Pro Plus is a bigger roll in volume and dimensions. The Pro is about perfect for door vapor barriers and smaller work, while doing things like the cabin basin and much larger areas, the Pro Plus is better. Material is the same, its just relative for the size of space you are working with in your car.
TheHunterHofman225.50 |
01-27-2022, 07:58 PM | #99 |
Rep 2,989
This really was the final missing piece for my exhaust setup, and couldn't be more pleased in the result. Every piece built towards the whole, downpipes, EL midpipe and now axle-back exhaust.
The whole octave range is shifted down, sounds much more aggressive and a deeper note throughout. I am really impressed by this change, and also uses the OEM valve actuators so you don't loose that functionality, or have to use a new remote. Really impressed.. FULL exhaust suite comparison, every single component, will be out next week!
02-09-2022, 09:13 AM | #100 |
Rep 2,989
Ah yeah... the flex fuel sensor is in!!!!
02-20-2022, 02:29 PM | #101 | |
Rep 323
How were you able to flash the CS calibration? Thanks. |
02-20-2022, 02:30 PM | #102 |
Rep 2,989
It's an available tune through BM3
02-20-2022, 02:39 PM | #103 |
Rep 323
02-20-2022, 02:43 PM | #104 | |
Rep 323
What do you think I can expect ? Just sus to your YouTube channel. Fantastic content! |
02-20-2022, 04:30 PM | #105 |
Rep 2,989
4th gear rolling starts.. and yes on the dyno types
03-02-2022, 08:51 AM | #106 |
Rep 2,989
Ok.. first of the exterior CF series is up!
happyjack1657.00 |
03-16-2022, 09:14 AM | #107 |
Rep 2,989
Crap.. realized I had fallen behind on the build info here.
Rear spoiler Rear diffuser
03-17-2022, 04:37 PM | #108 |
Rep 2,989
Ok yall.. the INITIAL results are in for the Mosselman turbo installed, with Cary Jordan tuning.
PLEASE READ FIRST - 1. Massive tire slip on every run, so torque is actually underrated a bit. Nothing we could really do about it at the time. 2. My stock HPFP absolutely falls off a CLIFF after about 6400rpm running E85 (I was reading E65 on the BM3 sensor) with every run. Cary did an amazing job working with that, but its clear the HPFP needs help to get really serious on E85, so we dialed the tune back for now. There is clearly significant head room with proper fuel support. Custom S2 Mosselman turbos with pump/flex fuel tune from Cary Jordan, on a Dynojet at CarbConn in Kirkland WA 92 octane RWP averaged STD corrected - 588.12 92 octane Torque average STD corrected - 484.09* (serious tire slip throughout) E85 RWP averaged STD corrected - 632.35 E85 Torque average STD corrected - 573.78 (still tire slip)
tkl64.00 |
03-24-2022, 10:03 AM | #109 |
Rep 2,989
The DIY for the final piece of the set is up and ready! Really love the way this brings the whole car together and was absolutely worth it!
happyjack1657.00 |
04-27-2022, 12:05 PM | #110 |
Rep 2,989
Now.. I am going to say it a BUNCH of times.. these are INTERIM results only, not final! Not only did I have massive tire slip throughout every single run, we ran into my HPFP just not handling E85 well at top RPMs. My Mosselman Turbo Systems turbos from Kies Motorsports install went flawlessly with the help of Ivan Hernandez, and time to get on the dyno for tune updates!
So.. this was a blast to do, incredible to see the jump in power and as always working with Cary Jordan and JordanTuned, LLC is an honor. Cary is a consummate professional, and has tuned thousands (like 5k plus!) of S55s, with more to come from mine once I upgrade my fueling! I hope you enjoy this, as I certainly did with the awesome support from Ivan Hernandez, and stay tuned for even MORE once I have better fueling on tap from Dorch Engineering!
