08-04-2020, 04:50 AM | #309 |
Rep 553
Finished my install today. I've retained the oem boomerang braces but cut off part of the raised lip so the Carbon brace bracket could sit flush on top, I also cut off half the plastic post holding the rubber grommet (air intake) and cut 1-2mm off the top of that grommet so it wasn't pushing up on the carbon brace. Finished this leaves the carbon brace only 1mm or so higher than it would be without the boomerang braces and I've confirmed the closed bonnet doesn't touch the carbon fibre brace.
So far I've just cut/modified the original plastics, maybe a little more shaping of the cowl covers required for a better look. Have only been for a 15min drive, initial impression is the steering feels a little more direct (even thought it felt a touch lighter but I'm sure it's just the car responding more to steering input). I have Ohlins R&T but so far can't say the braces made any change/improvement to ride. Have an ///M club drive this weekend and track day next week to give me a better idea. Last edited by David.m; 01-03-2022 at 01:58 AM.. |
gphung193.50 |
08-04-2020, 08:14 AM | #310 | ||
Rep 1,314
08-04-2020, 12:45 PM | #311 |
Rep 1,389
Hmm I thought my CF brace was rubbing due to the existing brace and so removed them. Bonnet did seem to close better afterward but don't think my installer did anything to the rubber peg thing some have mentioned?
Now worried haha! |
08-04-2020, 03:25 PM | #312 |
844
Rep 1,962
It will rub on the bonnet if you leave the L-braces on. The rubber bush on the intake is what you want. The hard plastic molding that holds it to the radiator support is what needs to be removed. The intake will then be supported by the rubber bush, which is sandwiched between the radiator support and the carbon brace. HTH
08-06-2020, 12:20 PM | #313 | |
Rep 4,516
Current '22 X3M LCI.. |
David.m437.00 |
08-08-2020, 04:14 PM | #317 |
Rep 1,389
I had to cut these guys even though they're intentional? Wouldn't fit otherwise
Bit neater now with the M3/4 seals. The left scuttle doesn't fit properly now, may have to plump for the real things as looks janky AF. same for Right side I suppose, but then i'll need a whole new bit that goes under the windscreen too? CBA with that if true. |
Anthony1s755.50 |
08-08-2020, 07:26 PM | #318 | |
Rep 1,314
09-17-2020, 03:58 PM | #321 |
756
Rep 2,149
Anyone here is the one who outbid me on this? Snipped it in the last 2 seconds, while my hands were covered in BBQ chicken, so I couldn't increase my bid haha.
https://www.ebay.com/itm/2015-2020-B...orig_cvip=true |
09-17-2020, 04:54 PM | #322 |
Rep 6,938
Drives: 2018 M2 AW DCT
Why not just use a real strut bar and save tons of money?
09-17-2020, 05:02 PM | #323 |
756
Rep 2,149
09-17-2020, 05:16 PM | #324 | |
Rep 6,938
And I actually like the way it looks. |
09-17-2020, 05:27 PM | #325 |
Rep 1,466
To each his own, and I know you're happy with yours DanG but this retrofit is quite different from a simple strut bar like you've installed.
The Carbon unit provides bracing of the twist in the chassis diagonally across the front end. It's the aluminium section that you don't see in most of these photos that performs the role of the strut bar that you have. It's much beefier, and bolts on to the body and strut tops in multiple locations. You're absolutely right that it's a more expensive option, and the install is also far more involved. Whilst I've not driven an M2 with a strut bar like yours, I would be extremely surprised if it were possible to achieve the same benefits as this retrofit from a strut brace like that.
2018 ///M2 LCI, LBB, 6MT...
Saanen180.50 |
09-17-2020, 06:21 PM | #326 | |
Rep 6,938
09-17-2020, 06:29 PM | #327 | |
Rep 1,466
We all like to view what we have higher than alternatives, particularly when we've spent our hard earned cash on it. Without scientific evidence and / or reviews from those that have driven both, it's just my (our) subjective opinion against yours. What we do have, is many journalists commenting on how the M2C's 'revised' suspension (which we all know is identical except for the braces) as being a significant improvement over the OG M2. This provides confidence that the retrofit 'works', but obviously doesn't provide any evidence about your strut brace. As I said... to each his own, but you're unlikely to convince anyone in this thread because it's a thread about the retrofit.
09-17-2020, 06:36 PM | #328 | |
Rep 6,938
09-25-2020, 10:48 PM | #329 | |
756
Rep 2,149
09-26-2020, 03:31 AM | #330 | ||
Rep 4,516
This may not be too scientific or empirical but jacking up the side of my car, compared to doing it with stock brace vs retrofit m2c alloy / CFRP shows a marked difference. If using the rear jacking point, the front wheel comes off the ground that much sooner. This will also happen with a plain tower brace between the struts but I doubt the difference will be as marked than oem upgrade retrofit. This translates into my car's EPS being more direct, quicker to respond with more feel. BP
PLF693766.00 |
Tags |
bmw m3, bmw m4, carbon fiber strut conversion |
