02-15-2020, 01:45 PM | #133 |
Rep 243
Great news, I also need to go back to my dealer as they recently replaced them with new (old) style tips, but as expected, still with the rattle. Could you also make a picture of the tips installed on your car? I’m curious how they look
02-15-2020, 09:42 PM | #134 |
Rep 492
Had a crazy cold start rattle but no other issues when I first bought my 2018. They replaced the bushings and it was still a small rattle for a while but acceptable. Winter came and it started going nuts again on cold start (my car is garaged but passive heating, usually above 50*). One day it started a horrible noise 1700-1800 rpm's which was driving me nuts. Took it in to have it checked out and the tech put his hand over the valve solenoid on the top of the tips on the passenger side during startup and it stopped. They replaced my whole exhaust under warranty, problems gone. Said if it comes back they'll replace it again.
Nice to be taken care of, and clear they aren't willing to accept the rattle just like I'm not. |
02-22-2020, 09:31 AM | #135 |
Rep 123
Success! The new style 2019 M2C carbon fiber exhaust tips with clamps fixes the cold start rattle. The part # is 18302456072.
I couldn't be happier with how my dealer handled this. They went above and beyond, acknowledging from the beginning the noise wasn't acceptable. They replaced the whole exhaust system, then tried more of the old style tips, and eventually agreed to upgrade me to the new M2C version tips, which solved the 20-30 second cold start noise. Here are some pics of the new style tips as requested. You cannot see the clamps unless you get down really low. |
04-23-2020, 02:39 AM | #137 |
Rep 291
Drives: 2023 BMW M2
M performance exhaust rattle solved?!
I've had the mpe for about 6 months now and I wouldn't trade it for anything else. It sounds and looks amazing and was easy to instal. The only downside is the rattle it makes during cold starts and a low rpm (1000-1500). Many members here say the tips cause this bit I removed them and still have the rattle. I then started the car without the tips again and listened closely, the rattle came from the right side or passenger side of the exhaust. I thought it was a hanger but turns out it's the exhaust valve. I did some research and found that it's the metal wire pin that connects the motor and the actual valve together. Apparently this is a common bmw issue. I plan to solve it this weekend by removing the exhaust and replacing the pin. I will update when I'm finished.
04-23-2020, 02:41 AM | #138 | |
Rep 291
Drives: 2023 BMW M2
Picture attached
cncmastr1590.00 |
04-23-2020, 10:19 AM | #140 |
Rep 291
Drives: 2023 BMW M2
04-24-2020, 05:26 PM | #142 |
Private NumNuts
522
Rep 321
If it’s not the tips it’s usually the slip joint at the mid pipe connection (on the OG):
https://f87.bimmerpost.com/forums/sh...2&postcount=59
Connors5453467.00 Sungillest101.50 |
04-24-2020, 10:07 PM | #143 | |
Rep 291
Drives: 2023 BMW M2
04-25-2020, 03:28 AM | #144 |
Rep 149
I came across this video, they just removed one of the of the rubber washers on the rear passenger side (RHD car) exhaust valve:
Connors5453467.00 |
04-26-2020, 02:53 PM | #146 | ||||
Rep 20
Connors5453467.00 |
04-26-2020, 07:55 PM | #147 | |||||
Rep 358
Drives: 2018 M2 Road & Track Build
It's a CS style spoiler. I believe Autoteknic sell them on their website. |
Connors5453467.00 |
04-27-2020, 02:24 AM | #148 |
Rep 291
Drives: 2023 BMW M2
04-27-2020, 02:25 AM | #149 | ||||||
Rep 291
Drives: 2023 BMW M2
04-27-2020, 02:30 AM | #150 | |||||
Rep 291
Drives: 2023 BMW M2
05-14-2020, 11:12 AM | #151 |
Rep 291
Drives: 2023 BMW M2
Update! Fixed!
Update on my fix! Turns out the mpe doesn't have the pins the help the valve and it's a direct drive, this was not the problem but what was the problem is the small metal heat shield between the valve motor and the actual valve on the exhaust, it's a metal plate the same size as the valve motor and when not torqued down hard enough it will rattle! I tightened the 3 bolts on the valve motor and it's fixed!
05-15-2020, 02:42 AM | #152 |
Rep 243
My valve rattle is also fixed. The dealer replaced the whole exhaust. I also replaced the exhaust tips screws, these seem to have a greater surface connection. They also look better
jas159898.50 |
05-18-2020, 05:10 PM | #153 |
Rep 450
Where did you get those little bolts?
05-19-2020, 02:58 AM | #154 |
Rep 243
