M2 Technical Topics > Track / Autocross / Dragstrip > Issue swapping back and forth between OEM and PFC-08 Pads
      11-27-2022, 07:37 PM   #1
fleetfoot
fleetfoot's Avatar
Drives: 2017 M2, 2013 E92 328i
After putting PFC-08 pads on my car for track purposes, I decided they were too noisy for daily driving, especially with the windows down. So I swapped back to my OEMs between track events. After 2 months back on the OEM pads with mostly city driving, I took the OEMs off and found fairly significant chunks missing from all the front pads (no issue with rears). The chunks look like they line up with the cross-drilled holes.
Two questions:
1) My brakes felt fine, so I'm hoping it's ok to keep driving these pads on the street?
2) Any idea why this might have happened? My hypothesis is that there was PFC-08 pad compound packed into the cross-drilled holes, and that compound worked its way out and tore up the softer OEM pads. I wonder if it might be helpful to clean the pad material out of the rotor holes between swaps?
Anyone else had this happen?
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9"
      11-28-2022, 04:47 PM   #2
///393
///393's Avatar
829
Drives: X6
No Fn Way!
I literally could have written this entire post word for word. Same thing happened to me. Exactly. PFC08 and stockers.
Found it just ahead of my last event which was the 3rd time going back/forth.
FWIW I put the stockers back in and they work fine while I wait on replacements to come. I’m going to just bite the bullet and pay $80 more via FCP ($330) with the lifetime guarantee.
I also noticed a lot of material in the cross-drilled holes of the rotor so I suspect that’s where the missing material is going. Wish I knew the root cause so I could mitigate it but since it’s clearly a thing, lifetime pads from FCP will suffice.
      11-28-2022, 04:53 PM   #3
fleetfoot
fleetfoot's Avatar
Originally Posted by wilson kop View Post
No Fn Way!
Ha well I guess I'm glad I'm not the only one? I'm assuming you've never had any trouble with the PFC pads tearing up like this? Your FCP Euro approach is a decent workaround for the street pads, but I'd really like to keep this from happening in the first place.
      11-28-2022, 06:55 PM   #4
///393
///393's Avatar
829
Drives: X6
Misery loves company so here I am friend
The PFC08s have held up beyond my wildest expectations. 4 weekends on them and they’re seemingly like new. Considered moving to Ferrodo DS3.12 but I’m going to continue to build experience with these for consistency sake as well as for my wallet.
Re: root cause…
I suspect it’s related to either overheating the stock units pads during street driving (I do enjoy the occasional spirited weekend outing) or something to do with the disparate compounds. Lacking any applicable adjustment on my end, FCP Euro lifetime replacement will have to do.
      11-28-2022, 09:55 PM   #5
fleetfoot
fleetfoot's Avatar
Good to hear on the PFCs. I’ve only got 2 days on them so far.
FWIW, I haven’t had any spirited driving the past couple months with the OEM pads on. So I’m pretty confident it’s not from overheating them. But one of my track buddies suggested that the pitting could be from not re-bedding the OEM pads. That seems like a reasonable hypothesis, so I’ll try to do that next time I swap if I can find a decent road nearby…that’s been challenging in the past.
      12-03-2022, 08:20 AM   #6
M2_MEDUSA
M2_MEDUSA's Avatar
Drives: 2021 M2 Comp. SpecialEdition
Wow Im glad to have stumbled upon this thread because i was looking to run PFC-08 as an upgraded pad with my stocks. Saved me this future headache
Instagram: M2_Medusa
      12-03-2022, 08:55 AM   #7
fleetfoot
fleetfoot's Avatar
I chatted with an M4 CS guy at the track yesterday on this topic. He's got the same brake hardware as us. He also swaps between PFC-08s and OEM pads between track days and has no issues. He doesn't bed the OEM pads either. I'm starting to think there's some edge case that causes problems a small percentage of the time since many folks seem to have zero issues.
Sidenote: even with my M2 having an AA tune, downpipe, and intercooler with a claimed 395hp at the wheels, the stock M4CS (454hp) was WAY faster than me on the back straight at Road Atlanta. We seemed to be coming out of turn 7 at comparable speeds, but I'd top out around 138mph while he was hitting 155+mph. This scenario clearly indicated to me the significant top end performance gains you get with just a stock S55. But of course my M2 costs about half the M4CS
      12-03-2022, 06:15 PM   #8
///393
///393's Avatar
829
Drives: X6
M4CS is likely laying all of 450 down at the tire and you’re closer to 380whp than 395whp. 80whp have that effect. A base M4 wouldn’t have disappeared like that.
Sounds like it’s time for a HPFP, Carbahn turbo, and a custom tune.
      12-03-2022, 09:26 PM   #9
fleetfoot
fleetfoot's Avatar
My m2 is already more capable than the average track car. I’ll probably spend the time/money becoming a better driver so can carry more speed through turn 7 and hit 155mph that way
      12-04-2022, 08:33 AM   #10
PackPride85
You're better off spending the money on proper safety equipment if you're aiming to go that fast. I typically limit myself to 120-130 during HPDE's. Hitting a wall at 160 without a proper harness and HANS can do some serious damage. Even with all the airbag and srs systems.
      12-04-2022, 07:21 PM   #11
fleetfoot
fleetfoot's Avatar
Sounds like it's time for a HPFP, Carbahn turbo, and a custom tune.
My m2 is already more capable than the average track car. I'll probably spend the time/money becoming a better driver so can carry more speed through turn 7 and hit 155mph that way
I got a hybrid HANS right after my first track day back when I was driving my much slower 328i. I wouldn't go on track without it. A quickfit harness is next on the list. Any pro tips from your experience with harnesses?
Analytical digression: Safety equipment is obviously a good call, but I'd like to avoid an incident from happening in the first place. I would think that solid driving skills (especially car control) and being mentally sharp on the track (well-rested and focused) could be an even better risk reduction method than a HANS+harness. I doubt numbers exist, but it would be super interesting to see catastrophic injury rates for HPDE vs HPDE with HANS+harness vs just driving on the interstate. Honestly the risk on the interstate scares me the most. Sleepy folks on their morning commutes are wild!
      12-04-2022, 07:44 PM   #12
PackPride85
With regards to a harness, I've been doing a lot of research myself as I've been looking to add one. You'll a lot of guys in the forums here using the Schroth Quickfit Pro 4 pt harness. I chatted with both Schroth and HMS (distributor) and they ABSOLUTELY DO NOT RECOMMEND using the 4 point harness in the M2. The reason being due to the downward angle the back straps are at requires certified testing on the stock M2 seat to ensure it won't actually collapse under load. Even though the harness will fit they HAVE NOT tested the M2 seats under extreme load to ensure they won't physically break.
I was recommended the Schroth Rallye 3 which has one back strap going back to the C pillar. Otherwise, to use the 4 pt a harness bar or cage is recommended.
As for injury risk, global crash test ratings are certified at 40 mph. Even on highways crash impact typically isn't at full interstate speed. I've seen some gnarly crashes at the track into walls and its not pretty.
      12-05-2022, 09:27 AM   #13
///393
///393's Avatar
829
Drives: X6
Do both. Seat time mod, plus power&grip mods. And come on over to Barber already. It’s beautiful and you’re not worried about how hard it pulls above 130.
      12-06-2022, 06:45 PM   #14
fleetfoot
fleetfoot's Avatar
I was recommended the Schroth Rallye 3 which has one back strap going back to the C pillar. Otherwise, to use the 4 pt a harness bar or cage is recommended. .
I just browsed through the Bimmerworld harness guide. It looks like the Rallye 3 isn't recommended for use with HANS devices. So seems like that isn't a good option if you're planning to do both HANS and a harness?
My first track day in my M2 was at Barber...but it was in the 30's and raining, so not a great experience. I'm definitely planning to come back! Tentatively June 3/4 with JustTrackIt.
      12-07-2022, 05:50 AM   #15
PackPride85
Unfortunately without adding a harness bar or cage, there is no approved M2 harness setup that works with HANS devices as far as I'm aware.
      12-07-2022, 11:39 AM   #16
zinner
zinner's Avatar
Drives: `17 X5 35d/`15 335i/`18 M550IX
I swap back and forth all the time between PFC-08 and street pads for maybe 3 years now and I never seen this. I use a solid vented rotor.
      12-07-2022, 11:48 AM   #17
zinner
zinner's Avatar
With regards to a harness.
If you are in a crash would you rather?
1) three point street belt
OR
2) 4 point Quick Fit Pro with a Hans devices
I understand the will the car/seat collapse argument, Do you think the F chassis/seats in general are worse than the E chassis? The F chassis was left behind cause the M3 seats don't have a pass through to make the quick fit an option at all.
I have a Simpson Hybrid-S which will do 3 point and it's way more secure in a 4 point (shoulder belts over yoke) than the 3 point configuration (that strap around your chest).
      12-07-2022, 11:51 AM   #18
PackPride85
OR
I understand the will the car/seat collapse argument, Do you think the F chassis/seats in general are better than the E chassis?
Can’t really answer about the seat. That’s why testing is required to be certified. I’m personally not going to take that risk but many others on here do.
      12-07-2022, 05:38 PM   #19
fleetfoot
fleetfoot's Avatar
Unfortunately, it doesn't look like they make a solid vented rotor for the M2. Everything is cross-drilled...unless you buy slotted rotors which start at $1300 a pair.
https://www.bimmerworld.com/Brakes/#/filter:sitecategory_hierarchy:Brakes~Brake$2520Rot ors/sortrice_min:asc
      12-07-2022, 05:45 PM   #20
fleetfoot
fleetfoot's Avatar
OR
I'm also wondering which combination leads to greater risk. My concern is that we (people not trained as crash safety engineers) might not have a complete understanding of all the factors involved in a crash. On the surface it seems like more belts would be safer, but then folks start talking about body folding/twisting in roll-over situations, and I realize that crashes can be very complex.
It sounds like there are two potential issues with the Quickfit Pro in the F87:
1) the untested strength of the F87 seat
2) the angle of the straps going to the rear seat
It seems logical that if the E92 front seat was ok, then the F87 seat would be ok too. But I don't fully understand the implications of the rear strap angle, and how much it differs compared to the E92. Can anyone enlighten me there?
      12-07-2022, 08:01 PM   #21
///393
///393's Avatar
829
Drives: X6
You’re way overthinking this. I run a E92 QFP in my F87 without Hans, but will be running a Simpson neck restraint soon. Safety gets people weird so you do you.
I had an instructor give me guff for NOT having a matching QFP for passenger so I bought one for passenger and then my very next instructor told me that he won’t wear any four point to avoid the risk of submarining under.
I see this as a business issue for Schroth not an engineering problem. To get their belts TUV certified for the F87 the business case must not have been there so it didn’t get executed. I lap regularly with a buddy that has the same harnesses in his E92 and the angle and fit is identical. YMMV
      12-07-2022, 09:54 PM   #22
zinner
zinner's Avatar
The bummer of having the 380mm rotor vs the 370mm rotor on the non M cars, you can't swap pads easily :-D I think everything else is darn near the same on the Msport brakes but that rotor size. You know what seems to help my squealing if I am street driving on PFC's, I nice romp on the brake pedal.
