12-31-2019, 09:05 AM | #1 |
Rep 232
Tuned N55 crank hub issues
Curious if anyone has ever heard of a N55 crank hub spinning? Now that I am back in my og M2 I am contemplating doing some preventive maintenance, but I can't find anyone who has ever had an issue. Has anyone else heard anything?
08 E92 M3
16 M4 17 M2 17 M4 ZCP 18 M4 ZCP ( Current ) |
12-31-2019, 02:11 PM | #3 | |
Rep 7,428
Power might not be the only relevant factor, if the hub spins it can spin at any power level and any rpm in the s55. The n54 shares the same hub and most tuned N54's and even high power turbo upgrade ones don't see the spinning hub issue. The only case I have heard was the VTT car, but they announced that as soon as they made their CBC so take that as you will... They could be a very rare case because they do make an exceptionally high amount of power. I think the s55 spins easier due to a few features: the timing system drives two hpfps instead of one, the timing system also drives a larger oil pump, timing system also drives a water pump which is not electric on the s55, and the dct down shifts alot harder than non dct equipped N54's and n55's. This makes some sense since the s55's have been reported to spin even while cruising. I've also seen higher horse power s55's soon easier than non s55 cars, though there has been a lot of debate as to why.
01-07-2020, 07:55 PM | #4 | ||||
Rep 232
This makes sense. I have yet to find one single person who has ever spun the crank hub on an N55 even when running PS2. I have seen a couple of cases where this happened on N54 but the power levels were just insane and still it seems to be extremely rare. Do you think the this could also be due to being a true twin turbo vs just a twin scroll?
08 E92 M3
01-07-2020, 08:54 PM | #5 | |
Rep 7,428
Anyways no imo being a twin turbo car vs. single turbo shouldn't have much of an effect if any. Edit- twins could allows for faster spooling and more power down low when upgrading to larger turbos, but any effect would be minimal and shouldn't contribute to spinning the hub imo.
01-09-2020, 11:38 AM | #6 |
756
Rep 2,149
I did see a TSB for the N55 bedplate. I didn't look into it much, so I don't know what model years it's for. But I remember someone said it's related to the crank hub.
EDIT: here is what I'm talking about. |
01-10-2020, 03:19 AM | #7 | |
Rep 7,428
Btw where do you get TSB info from?
01-10-2020, 09:54 AM | #8 | |
756
Rep 2,149
jk, I get theom from here. http://www.carproblemzoo.com/tsb/bmw/m2/ |
F87source7250.00 Bavarienne6.00 |
01-10-2020, 04:46 PM | #9 | |
756
Rep 2,149
Bavarienne6.00 |
01-10-2020, 05:18 PM | #10 | |
Rep 7,428
I wonder how much work it would take to diy it.
