10-13-2018, 06:59 AM | #23 |
Rep 3,315
This isn't true. The Performance Center recruits drivers from the local CCA chapter to help break-in drive new M cars.
Current Stable:
10-13-2018, 07:01 AM | #24 |
Rep 3,315
After the first 100-200 miles, the majority of the break-in is the drivetrain -- gears, especially bevel gears in the differential, clutch disc to pressure plate/flywheel interface takes at least 1000 shifts done with light to moderate loads to achieve maximum clamping force, LSD discs need a similar light to moderate activation, etc. Mechanical Engineering is actually a science.
Current Stable:
arquitecto535.50 ChrisK4449.00 |
10-13-2018, 08:54 AM | #25 | |
Rep 288
Only time will tell, parts for this thing aren't cheap. I'd like breathers and maybe upgraded twins down the line. I'm not a fan of E85. I live in the city and there are no stations near me with access to it. |
10-13-2018, 09:00 AM | #26 | |
Rep 288
10-13-2018, 09:04 AM | #27 | ||
Rep 288
Also a good friend of mine had a 2015 m4 and all he gained after the 1200 interval was launch control ect. Nothing about keeping under 5k rpm ect. |
10-13-2018, 09:05 AM | #28 |
Rep 2,577
These are STD numbers. Can be seen at the top right corner.
Pretty good results. Ask Dyno shop to convert mph into rpm though. I see the most of the pulls were in 4th gear beside one 5th. Not that 4th and 5th make any difference at all, just to show the spool up rpm. It looks 400whp dynojet STD numbers are legit for M2C.
Lemania 2320
10-13-2018, 09:22 AM | #29 |
Rep 1,092
You got better eyes than this old tired rat
So there goes about 4% vs SAE so let's say 385whp. With 15% drivetrain loss we would be at 442, even with just using 10% it's 423hp so more than BMW claims. Pretty nice! |
10-13-2018, 09:30 AM | #30 | |
Rep 2,577
Using dynojet number multiplied by 115% is not a good way of calculating crank power. Dynojet is all about comparability thanks to its consistency (comparatively speaking) across temp, humidity and altitude, when corrected. We all the time say BMW underates power. But who doesn't? Merc and Audi all show good power on dynojet. This is just about the most misinterpreted things in tuning world. Truth is BMW does not underrate.
Lemania 2320
10-13-2018, 09:38 AM | #31 |
Rep 3,888
Looks as expected (slightly detuned) when compared to an M4 dynojet run:
stock M4 - 420whp 422wtq: https://f80.bimmerpost.com/forums/sh...39&postcount=1 stock M2: http://f87.bimmerpost.com/forums/sho....php?t=1253319 IND 336whp and 371wtq on 93 http://f87.bimmerpost.com/forums/sho....php?t=1270926 Fabspeed 332whp and 378wtq on 93 (presumably) http://f87.bimmerpost.com/forums/sho....php?t=1367346 VF Engineering 329whp and 362wtq on 91 http://f87.bimmerpost.com/forums/sho....php?t=1253475 Burger 330whp and 368wtq on 91 |
cptobvious2531.50 slowestM212.50 |
10-13-2018, 01:55 PM | #32 |
Rep 288
here are the vids, please ignore how dirty the car is
https://youtu.be/igjaxYgW-5A https://youtu.be/cjRM4YiApZc Last edited by NY135ivishnu; 10-13-2018 at 02:03 PM.. |
slowestM212.50 |
10-13-2018, 02:05 PM | #33 | |
Rep 68
from mph, only rpm and load... again. For real break in you want varying rpm and load, you want to slowly and progressively increase heat, rpm, and load during I initial break-in. I guarantee you these cars are all fully broken in, driven and revved from 2k to redline at all load levels before they are shipped out Mechanical engineering is actually a science and the bulk of what’s in your owners manual is marketing science.... |
Poochie9099.00 |
10-13-2018, 02:12 PM | #34 |
Rep 68
This gives good insight. If engine break in took time and required babying for a few hundred or thousand miles professional drag Ravi f wouldn’t exist. |
10-13-2018, 04:15 PM | #35 | ||
Luxury at the redline :)
9099
Rep 7,563
You're 100% correct, forward the video below to 28:24: |
slowestM212.50 |
10-13-2018, 04:47 PM | #36 | |
Rep 7,252
10-13-2018, 05:12 PM | #38 | |
Rep 1,345
10-13-2018, 06:05 PM | #39 |
Rep 825
Wow, this is awesome. Thank you! I'd sort of intuitively figured that there was no way that break-in could really be critical for the car, but that still didn't prevent me from very strictly following the guidelines. Would HATE to be the dude whose engine blew up, and then got on this forum, complained about it, and have everyone say, "Well, you idiot, you were at redline from the get-go. Your own fault!" It stands to reason that you can't possibly release a product in 2018 and expect consumers to follow usage guidelines that require strict adherence to X, Y, and Z. That would be like Apple releasing an iPhone and telling everyone, "Okay, for the first month, you can't be on any single phone call for more than 60 minutes... or else the phone blows up." But, finally, I will also say that break-in guidelines probably saved me from killing myself. As a number of folks have pointed out, the break-in period really is more about noob's getting used to their cars. Most powerful car I owned before this was 240HP. Staying under 5500 RPM probably helped to prevent me from going off the side of a mountain during the first 2 weeks I had the car. |
Poochie9099.00 |
10-13-2018, 06:27 PM | #40 |
9099
Rep 7,563
[/QUOTE] No problem, I knew of this video and numerous other factory clips of BMW/Mini vehicles being factory tested/ broken in at maximum velocity.. I figure doubters wouldn't believe it even with proof staring them in the face, so I didn't bother posting it until now. Some people just love living the lie.. But I would add that you should take it easy for the first couple hundred miles.. However, there is no added power at the 1,200 mile service. The End. Reasons why there is a suggested break in: https://m.tirerack.com/tires/tiretec....jsp?techid=85 https://m.tirerack.com/tires/tiretec...e.jsp?techid=5 |
BAN_M2C4154.50 cptobvious2531.50 |
10-13-2018, 08:35 PM | #41 | |
Rep 3,057
It had 32 miles on the clock and it was at the M Track Day in Miami. We launched it, did full throttle, redlined it all during the 0-60-0 exercise we did. 4 groups of 20 people helped do it. Break in are guidelines and I follow them mostly to get rid of that first set of oil that has the initial particles of the engine, but these cars are ready to rock from the get go. My CA told me in the past they did have M3/M4 detuned and then fully opened up after break in service but that had gone away for quite some years now. They just enable the launch control and RIS.
Follow me on IG
10-13-2018, 08:51 PM | #42 | |
Rep 2,577
There's a certain level of honing with any kind of machinery fit. More precision it has, more chance you'll get away with doing that in a hard way. Just 1200 mile or 2000km, not taking the risk isn't a bad option for a personal car. Media or bmw training stuff sometimes just had to risk it to do their job, and they don't care because none of these cars are personal and they don't take the consequences.
Lemania 2320
cptobvious2531.50 akkando5860.00 |
10-13-2018, 08:56 PM | #43 | ||
Rep 3,057
These cars (BMW) I follow it because I am pretty sure if something bad went wrong before 1200 miles the has to be some data log they could look at and confirm how many redlines, launches and all that other fun stuff the car had. I wasted money doing Blackstone analysis on the first 3 oil changes in the M2. Every time it came back saying it was perfect and I was babying the car. When I was actually roughing it up every single time I pulled out of the garage.
Follow me on IG
10-13-2018, 11:05 PM | #44 | |
Rep 7,252
BAN_M2C4154.50 |
