08-30-2018, 01:31 PM | #24 | |
Rep 660
On a normal racecar, if you're too critically damped, then the car will tend to "hop" (imagine if your car had a solid bar in place of your shock, it would be extremely harsh and bounce off of bumps). Thus, your wheel will constantly be losing traction. The same happens on the other end of the spectrum - if your compression is too low, then the wheel wont reset fast enough, so on bumps it will spend a lot of time in the air, thus losing traction. |
08-30-2018, 01:50 PM | #25 |
Gone Fishin’
7316
Rep 12,125
08-30-2018, 03:41 PM | #26 |
Rep 3,659
Drives: 981 Cayman GTS
I was planning to get Ohlins but was recently told that they require a rebuild every 19K street miles or 10hours of track time. I can't imagine getting them rebuilt every year.
08-30-2018, 03:55 PM | #27 |
Rep 276
Used to run Nitrons S.A on my Exige S 34000 miles 10k of it on track, they were sill perfect. The make them in single,double and triple adjustable. carl
http://www.nitronracingshocks.com/BM...PER_c_468.html Last edited by carl44; 08-30-2018 at 04:02 PM.. |
08-30-2018, 04:05 PM | #28 |
4143
Rep 6,926
That is the one big advantage of the Mperf coilovers. Get them installed at dealer and they are covered under warranty. Plus you can get them for $2k, about $1k less than R&T.
08-30-2018, 08:46 PM | #29 | |
Gone Fishin’
7316
Rep 12,125
08-30-2018, 10:33 PM | #31 | |
Rep 7,294
https://www.dscsport.com/porsche/#981 Last edited by chris719; 08-30-2018 at 10:46 PM.. |
09-14-2018, 12:53 PM | #32 |
Rep 2,448
Its coming for f8x.
I wonder if the tractive coils for the F80 will work on the M2. Then you can install the DSCsport with it.
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 |
09-14-2018, 12:54 PM | #33 | ||
Rep 2,448
09-19-2018, 07:15 AM | #34 |
Rep 44
I have got the m performance coils on my m2c.
With my setup and adjustments they are not as stiff as the stock suspension in the lowspeed fraction but when the dampers need to work fast, it is stiffer and firm. Exactly what I want. |
09-19-2018, 08:49 AM | #36 |
Rep 4,512
Are you using OEM ride heights 595/600 F&R and any photos ?
Current '22 X3M LCI.. |
09-21-2018, 06:54 AM | #37 |
Rep 44
09-21-2018, 10:19 AM | #38 |
Rep 4,512
Not an Insta user
09-22-2018, 04:05 PM | #39 |
Meh
926
Rep 781
Drives: M3CS & Cayman S
unless you're a pro racer, the difference between ohlins r&t and kw v3 will not be felt by the average driver. they are basically in the same class. m perf coils also fall into this category, but there's a limit to how low the height can be set, most likely to preserve warranty if installed by bmw.
i had the v3 on my m2 base, but will be getting the ast 3 way setup with a little stiffer front spring for the m2c (also a true coilover in the back). the dampers on the v3 were good enough for a occasional track days, but the spring rate was a little too soft for the track. ohlins rt, kw v3 and m-perf coils are all tuned for street-first, track secondary use. they're great for spirited canyon carving and the occasional track day, while being able to live with them on the daily commute. however if the ohlins do require rebuilds every 30,000km, that seems pretty poor for something labeled "road and track". |
09-23-2018, 12:04 AM | #40 | |
Rep 4,512
09-23-2018, 01:33 AM | #41 | |
Meh
926
Rep 781
seems ast provides a plate to disperse the force to the body. the 5200 rear design looks similar to the front top hats, but with three bolts. |
Bee Pee1775.50 |
09-23-2018, 07:40 PM | #43 |
Rep 72
Drives: i3
Nope, the stock top shock mount is with three bolts. The AST is just a top mount adapter for their spherical end shock. Its best quality is the road noise.
09-23-2018, 08:21 PM | #44 | |
Rep 4,512
